Mike Stranks wrote:Here's the link to the audio from CC's quick test: https://www.dropbox.com/s/x00d4v7qbhxttm2/1st%20H3-VR%20test.wav?dl=0
This has been processed to binaural so best listened to on headphones.
The Elf wrote:In the same way that some poeple don't see 3D, I don't hear front/back. I can hear the L/R movement, but beyond that I would need a visual cue.
ConcertinaChap wrote:I've been listening to binaural quite a lot lately for one reason or another and what I've found is that while I can't say definitively that a sound is coming from in front or behind me I can say with some certainty it's not in the middle of my head. In fact the sense of actually being there can be quite startling. Binaural can sound far more like being in a space than any stereo recording I've ever listened to. That's the real gain for me.
The Elf wrote:Disney do (did? Still there?) an amazing headphone audio experience in 'Conservation Station' where you are aurally set down in a rainforest to hear the sounds all around you.
Stratman57 wrote:I'm wondering if I recorded some ambient sounds in the field, would I be able to realistically reproduce it with 4 separate feeds to powered speakers.
Hugh Robjohns wrote:Four cardinal outputs shouldn't be a problem.
Yes. Ambisonic recordings can be decoded to any desired number of outputs, depending on the capabilities of the decoding software. Four cardinal outputs shouldn't be a problem.
