Cost effective compressors / gates for 32 channels of a Mackie 32-8?
Post by Kevin Nolan »
I still use a Mackie 32-8 mixer for coping with many hardware synthesizesrs and effects processors.
I'm considering putting a compressor / expander / gate on every channel, and wonder if anyone has done this; and if so whether you can recommend a cost effective solution.
I'm looking at something like 8 x Behringer MDX4600's - and wonder what you'd think about that?
I don't want to spend a fortune on this - the primary goal is to have a gate on each channel to manage the noise floor(s) of a lot of old analog synths (even a Juno 106 with the Chorus unit activated can be noisy) - so a cheap-and-cheerful solution is goal - but one that works!
Thoughts and recommendations appreciated (keeping Behringer bashing to a minimum :-) )
Kevin Nolan
Posts: 844 Joined: Sun Jan 12, 2003 12:00 am
Re: Cost effective compressors / gates for 32 channels of a Mackie 32-8?
TBH I'd be looking at replacing the mixer with a digital variety (X32?) that would include all the channel processing you would ever need. Maybe not the solution you're hoping for, but one with more longevity?
I love hardware and have used Berry gates live (they do exactly what they say on the tin) but, TBH, it's probably better done in the box.
BTW is this for tracking or mixing?
Not the answer you want to hear, I expect, but I'm with the Elf on this one -- I'd ditch the vintage Mackie for a rack-mount digital mixer. You're looking at blowing £800 on a lot of pretty so-so gates when for not much more you could get a digital mixer with better facilities and sound...
Posts: 43689 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Post by Luke W »
Another vote for the digital mixer route here. By the time you've added the cost of cables on top of the units themselves (even cheap ones) you're well up into the sort of numbers that will get you perfectly decent mixer. You'll save space too, more room for synths :thumbup:
Luke W
Thanks for your feedback.
Not to bore you with the details (but I'm going to :-) ) - but this room (being setup) has a lot of hardware gear over two 'synth setups' - over 30 synths and about 8 hardware effects. One of the two synth setup is already primed to use two cascaded O1V96s (still trying to figure out how the hell that works!) - and the second setup uses the Mackie. They each route into a MOTU interface via 8 channels (each) and into DAW.
So I'm trying to use the equipment I have - and the gates are just an after thought.
FYI there are several reasons why I'm not ditching the Mackie
Firstly it's so versatile in terms of I/O - 32 physical inputs (routed to a MOTU interface via its 8 busses) - but - also it replicates its bus outputs three times; and also has the inline MIX-B capability - providing for up to 64 physical inputs.
So all told - it caters for a huge number of old analog synths very well - and perfect for hardware monitoring when recording to DAW (I'm using 8 channels for hardware effects too which can be used during hardware monitoring when tracking or as effects via auxes in Logic Pro)-
But because of the sheer number of of inputs and outputs, I've figured out a mechanism to also simultaneously cater for permanent routing of the tape-backup inputs and outputs for a Jupiter 6, Prophet T8, Trident Mk2, CS40M and Juno106 (and others if needed) - enabling backup/restore on the fly from any of those synths on a per-piece / as needed basis. I'm hoping this will enable those synths in exciting new ways because frankly I haven't programmed a new sound for them in years because their memory banks are full and it's otherwise so much hassle making backups and restores. But using both the Mix-B In-line inputs and the replicated bus outputs - I've figured out a way to have the synths permanently linked to Logic Pro for backup/restore while not interfering with the more usual role of the mixer for tracking.
Finally, I have to say, however contrived in use because so much will be done in the box - I _love_ mixing at the Mackie. I make no claim to being expert in this arena - but just above the Mixer are a pair of Genelec 1030A's and just above them tilted slightly down so acting as near fields are a pair of huge JBL 4412's - and it is nothing short of bliss to sit at the Mackie, mixing a piece over those speakers. I just love the experience of sitting comfortably at the mixer, making tweaks because it's such a joyous listening experience.
So although not fully worked out yet routing wise - and perhaps a little old-fashioned these days - I intend taking 8 DAW outputs as tape returns through the Mackie and indeed routed to a Finalizer 96k for mastering (because I know it well too). Even if it's just for stereo mastering (that's 'mastering' with a small m :-) ) - I just love being at the Mackie and want to keep it in the setup. I could honestly live permanently in that seat !!
So the Mackie is doing a lot of 'heavy lifting' over various roles - it took ages to work out the tricky routings for its various roles and there just isn't a digital mixer available with the sheer quantity of both inputs and outputs needed.
Sorry for such a long winded reply - it's a along winded room! I'm trying to use every last morsel of equipment I already own - and as said - find the Mackie more than useful in a hardware laden setup. (I have a second room in development too and it with a lot of hardware synths too - but I'm going totally MOTU AVB interface in that setup)
If I read you (all) correctly , you have no fundamental objection with the Behringer equipment(?) To Sam - I haven't heard of the "Berry" gates and a Google reveals nothing on them?
Thanks for your time and replies - I totally get the digital mixer suggestions and as said am in part doing that - but just want to keep the Mackie too.
Kevin Nolan
I get that, as I said I love hardware and use an X32 Compact as my studio desk and interface for the little recording/mixing I do (live sound guy here).
The Berry gates worked fine, unsophisticated and simple but got the job done for a given definition of 'got the job done'. Not the best available but not one of Berry's horror stories either.
Post by CS70 »
A little Mr. de la Palisse here, but when Sam says "Berry" he means "Behringer" I think (do you, Sam? :))
Plenty results googling "behringer gate" :-)
i do indeed mean 'Behringer' CS and apologies to the OP for not using plain English.
Post by Mixedup »
I've not used them, but there are eight-channel dynamics processors by Klark-Teknik, Presonus and SM Pro, amongst others. (Some are out of production, though). Eg. you can pick up a KT SQ1D for about 250-300 second hand. So 750-900 for 24 channels.
But you could probably pick up a digital mixer for that money, or an old computer and an old 24 channel interface (eg MOTU), and run 24 channels of plug-ins as processors...
Mixedup
Doh!
(thanks! :oops: )
Kevin Nolan
My opinion of the "Berry Gates" :D is that they do tend to sound a bit cold, glassy, I'd go for two secondhand BSS quad noise gates, that'll cost you about £500 tops for good used units.
Classics too.
I would suggest Alesis 3630's, but the gates are awful, they have very poor release times, and always cut low level signals off too soon, even the Berrys are much much better in this respect.
I think given the "situation" getting a bunch of secondhand Behringer Composers might be a vote winner, why not? I think the glassy sound could be avoided if you're careful with EQ etc, and always keep that tube button depressed, it does actually do something nice, and anyway, who on Earth is going to have the same set up as you! Could be cool.
8 secondhand Composers? Maybe £250?
Posts: 21929 Joined: Sat Jul 12, 2003 12:00 am
Post by Studio Support Gnome »
the mackie sounds shit...
nasty hard EQ.
and a PCB fault , that behringer copied , thus mackie could prove their case...
plus they tend to get flakey in the middle due to poor design in supporting the main mix motherboard PCB
stuff adding shit gates and compressors to it...
32 channel digital console, and expansion ADDA ....
OR
find a decent analogue console, WITH MIDI MUTING
Examples, Allen and heath GS3, GS3V and GS3000 , Soundcraft Ghost. , Soundtracs Topaz.
get it serviced, and you'll have better EQ, better Pre-amps, and better control of noise floor.
or find an Ottomix. (google it.... rarer than hens teeth , and even finding anything other than a control module reference in google takes a fair bit of effort.... so much for obsolete analogue hardware being always searchable in google....
and plug that in to your existing system
Last edited by Studio Support Gnome on Sat Sep 07, 2019 10:26 pm, edited 1 time in total.
Posts: 3025 Joined: Tue Jul 22, 2003 12:00 am Location: UK
Mostly Retired from Audio.... If I already know you I'll help,  if not....    Ask Hugh Robjohns, unless that is you're in need of 80's shred guitar... that, I'm still interested in having fun with...
Studio Support Gnome wrote:the mackie sounds shit... nasty hard EQ ... and a PCB fault
Don't sit on the fence Max, tell us what you really think :D
Posts: 9975 Joined: Wed Sep 01, 2004 12:00 am Location: Brighton & Hove, UK
I think the sensible solution here, if we are all honest, is a digital mixer.
Post by James Lehmann »
Kevin Nolan wrote:I still use a Mackie 32-8 mixer for coping with many hardware synthesizesrs and effects processors... I'm considering putting a compressor / expander / gate on every channel, and wonder if anyone has done this.
Gate & Compressor on every channel of a Mackie 32:8 at a reasonable cost?
Hmm... a fun challenge!
Whether it can be 'cost-effective' or not is something only you can determine because 'cost-effective' means totally different things to different people, especially on internet Forums, which is one reason why others are trying to talk you out of your original aim.
However, if your mind is 100% made up to keep the Mackie and acquire 32 channels of analogue comp/gating then if it were me here are the units I'd be scanning the Reader's Ads, Reverb & eBay etc for, limiting my search to 1U 4-channel units with the aim of minimising 19" rack space:
  • Drawmer DS404
    Drawmer DL441
    Aphex 105
    LA Audio C400
    LA Audio G400
    BSS DPR-504
    dbx 1046
    dbx 1074
It'll probably take you at least a year of hunting to assemble your 32-channel rack of doom at a reasonable cost, but all the units above do come up at knock-down prices from time to time - I've scored a number of great bargains from that list recently. (The last 3 are probably going to be a bit more expensive.) Prepare yourself for some 'cosmetic disappointments' (surprising what people advertise as 'mint' these days!) and possibly a minor repair or two – mostly this gear is going to be well-used & abused from hire/touring companies & theatres etc – but stuff like the Drawmers are built like tanks and should work for decades.
32 gates should be easiest to assemble – no-one wants those anymore – so you could first go for 32 channels of gating seeing as your first priority seems to be to gate every channel, and then perhaps 'make do' with a lesser number of compressors by using just the groups (8) on your Mackie or a patchbay (I would hope you have multiple patchbays already!) until you can assemble the full complement of 32 comps.
And when you're done please pop back here and post some photos! :thumbup:
Last edited by James Lehmann on Thu Sep 12, 2019 9:12 am, edited 9 times in total.
James Lehmann
Posts: 367 Joined: Tue May 17, 2005 12:00 am Location: Europe
I used to be a rocker, but now I've gone off it and just sit in one. (JL)
