Yamaha 02R digital mixing console.
Fancy yourself as an SOS Reviewer? Use this dedicated forum to post your self-penned user reports/reviews of equipment/software/instruments that you own and/or use regularly.
NOTE: before posting a new User Report (topic) please check whether one is already in existence for your product.
Re: Yamaha 02R digital mixing console.
Post by VTypeV4 »
Thanks, Mike. :clap::sos:
VTypeV4
Posts: 216 Joined: Mon Nov 21, 2016 1:34 am Location: Stoke on Trent
Synkronize Music Group, part of the Sun Street Studios building in Hanley: Studio and Live Multi-Track Recording, Mastering House and bespoke Tuition Services.
www.synkronize.co.uk & www.facebook.com/synkronizemusicgroup
Post by Bme »
Hello folks,
I've a couple TC unity cards for my 02R console.
Unfortunately I lost the license codes.
I tried TC electronic but they destroyed their codegenerator and their archive.
Now I'm reengineering; based on the serial number I try to find out the license code.
But I need some valid licence codes (M2000 and/or Finalizer) with the according serial numbers.
Who can help me with this information.
If I found out I can probably help others who also lost their license code or maybe want to enable the M2000 or Finalizer.
Thanks.
Bme
Posts: 13 Joined: Sat Apr 20, 2019 10:40 am
Post by VTypeV4 »
I'll fish mine out in the next few days, this might be helpful if you can work it out.. :bouncy:
VTypeV4
Post by Bme »
@VTypeV4: That would be great!
Thanks in advance.
But probably I need some more combinations of serial numbers and license codes.
Every help is more than welcome.
Bme
Post by VTypeV4 »
UnitY Option License
Serial Number :6300234
Option :M2000 D.C. Set To ON
License Code :LIC5476D48A57341EEEF9C5
Serial Number :6001327
License Code :LIC54C6D48A500FFBEEF935
Option :Finalizer D.C. Set To ON
License Code :LIC54C6D58A500FFBEEF936
BME, let me know how you get on.. Cheers, Matt
VTypeV4
Post by Bme »
@ VtypeV4
Thanks!!
I'm quite sure about the missing Finalizer lic code:
License Code :LIC5476D58A57341EEEF9C6
Please try this code and give me feedback if it is accepted in your machine.
I'm still working on the algorithm. Quite a puzzle
By the way: are you sure about the serial number of this card.
Is this number written on the card?
This is the first time I see the serial number starting with 63...
And can you give me the details of the interfaces of your cards (input ADAT and so on)
To others: I can use some more license codes and serial numbers.
Bme
Post by VTypeV4 »
This will be superb if you can work it out. :clap:
I have a different card in the other 02R so I'll get the serial from that too - I don't have the codes for it but it seems happy to operate both M2000 and Finalizer sections..
I think the serial is on the load up page - I've got it written down how to check them. And yes, I'm quite sure as I got these straight from TC themselves a few years back after giving them my serial numbers.
Both my cards have the ADAT / TDIF I/O section and have the latest (2.12?) drivers.
The 02Rs are themselves are loaded with the Unity cards in SLOT 3, a standard Yamaha ADAT card in SLOT 1 & 2 and an AES in one and a TDIF in the other installed in SLOT 4, Both run v2.16 operating chips.
VTypeV4
Post by Bme »
@VtypeV4
Thanks for your answers.
I'm still working on the codes.
Is the code working which I gave?
Maybe I need the dealer codes as well. These codes can be obtained from the TC unity status screen on the 02R.
@ others: I like to have more license & serial codes. Please help me.
Another question: I have a Digital Surround Panel from Soundware SP02.
A special unit for the Yamaha 02R.
But I have no manual. There is nothing on internet. The company is not responding.
Who can help me?
Bme
Post by VTypeV4 »
BME, I'll post a proper reply Sun / Mon but thought these may help too.. I'll get the reference codes next week too..
ImageTc serial by VTypeV4, on Flickr
Cheers, Matt :thumbup:
VTypeV4
Post by Bme »
@Matt,
Thanks.
The "ST" command gives more details about the card (dealer code and so on).
The second image gives a new serial number (without a license code I presume).
Bme
Post by VTypeV4 »
BME, not sure if you still frequent the forum - I've got two more Unity cards if you're still interested in code cracking? :sos:
Image02R unity updates by VTypeV4, on Flickr
This 02R is now a mixing monster! :beamup:
VTypeV4
Post by Bme »
Hi,
Sure! I’m working on it and I can still use more combinaties of serial codes and licence codes.
Bme
Post by VTypeV4 »
Ok, brilliant.. I've got the serials on Flickr but it won't let me connect right now (train wifi) so will post when I can. I'm working away for a few days now so I'll do the ST command thing when I get back near the 02r..
Thanks. :thumbup:
VTypeV4
Post by VTypeV4 »
Slot 3 and 4 respectively..
VTypeV4
Post by Bme »
And do you have the licence codes for me?
Bme
Post by VTypeV4 »
They weren't supplied with the cards but I'll do the 'ST' command when I get back near them - I'm away till monday..
VTypeV4
Post by VTypeV4 »
I've hit a stumbling block.. I thought the ST command would display the codes (because they're active) but seems it doesn't, frustratingly. :thumbdown:
The dealer codes are both CF17 but that's about all I can get out of them..
I didn't dare press the initialize button just in case it asked for codes..
What do you think, BME?
VTypeV4
Post by Bme »
You need only the licentie-codes if you reset the card (sometimes if you change the Batterij).
Or if you want to enable an extra engine on your card.
Are both engines on both cards enabled?
Sometimes the licence codes are written in the manual by hand.
If not, you have to ask the seller.
This issue is the main problem: there is no easy way to discover the codes. TC Electronic doesn’t provider the codes anymore. That’s why I try to find the relation between the serialnumbers and the licence codes.
Hopefully you can provide the combinations.
Bme
Post by VTypeV4 »
Pending a reply from the seller at this point - fingers crossed. :tongue:
VTypeV4
Post by VTypeV4 »
BME, I put a post here too - maybe that will shed some light?
https://www.facebook.com/groups/1494173914205235/
I changed the battery on one of the Unity cards this evening but hooked up a dummy battery to keep the memories / codes intact..
VTypeV4
Post by digis5000 »
recently, i changed the battery of the Unity card. Now, it shows "No valid Software found on the Unity card, please upload...". Does anybody have the Upload Software "TC-Unity Software.asp", so i can upload via 02R Host port?
digis5000
Posts: 2 Joined: Wed Jan 15, 2020 9:30 pm
Post by VTypeV4 »
PM me your email - not entirely sure if it's what you'll need but I'll send it over - I downloaded this folder a while back from the TC site.. :sos:
I changed the battery on one of mine a few weeks back but hooked up a temporary battery to the terminals whilst I had the old one out just in case it threw a wobbly - I appreciate that doesn't help you now but might be worth considering for next time.
Lastly, not sure what version of Windows you're running but last time I used the software, it was on XP..
Best of luck. :thumbup:
VTypeV4
Post by digis5000 »
here is a license code:
Serial Number :6300270
License Code :LIC5476D58A57343AEEF9E2
digis5000
Post by VTypeV4 »
Files sent so let us know how you get on - best of luck. :thumbup:
VTypeV4
Post by VTypeV4 »
Serial Number :6000973
License Code :LIC54C5D48A570F19EEF9AA
Serial Number :6000801
License Code :LIC54C4D48A500FF5EEF905
Serial Number :6002353
License Code :LIC54C2D48A500FE5EEF933
For anyone who is good at cracking codes?
VTypeV4
