Price of RW3 Rockwool...
Post by molecular »
... is £18 for 5.76m2 from an online insulation dealer: http://www.insulation4less.co.uk/rw3-50mm.html
... and £43 for the same amount from studiospares: https://www.studiospares.com/Studio-Gear/Sound-Insulation/Rockwool-RW3-(8-Pack)_401982.htm
I've never been a big fan of them as they are a company that refuse to do anything about some fairly insane delivery charge issues, but am I missing something or is this a real swindle?
molecular
Posts: 1318 Joined: Sat Dec 13, 2003 12:00 am Location: Skye / Stroud / Seyðisfjorður
Anto mo Ninja, Watashi mo Ninja http://www.hectormacinnes.com
Re: Price of RW3 Rockwool...
I've found that if you want small quantities you'll end up paying a hefty delivery charge from the trade suppliers so the Studiospares price is reasonable for a single bale if they don't charge for delivery.
Haven't bought anything from Studiospare for years as I found their delivery times slowly getting longer. CPC do many similar items and you can't argue with free next day delivery (they say it may take longer but I've never known them not to do next day).
Posts: 16373 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Post by molecular »
Well my main gripe with studiospares has always been delivery, which is punitively expensive for the Highlands. Sure enough they want another £22 to deliver 1 pack and £60 to deliver four, so even the delivery is twice the competition... All in it's £233 for four packs from studiospares and £103 from insulation4less...
I'm always uneasy about buying anything with "4" in it like that - including prince albums - but I can't really argue with that price difference!
molecular
Post by Strangy »
Rockwool and similar insulation products are common materials for the building trade. Do you have a builders merchants nearby? something like Travis Perkins or Jewson etc. Some local merchants might deliver it for free/cheap or if you can drive/have access to a large car you should be able to squeeze a couple of packs in. No need to buy raw from a dedicated studio supplier if you are going the DIY route.
Strangy
Posts: 156 Joined: Mon Dec 27, 2004 12:00 am Location: Cardiff, UK
Post by siderealxxx »
That's a fair price but you may well find it locally depending where you are. I found it near me after some hunting and it was cheaper than studiospares. I'd imagine it's a combination of not buying baulk and the fact that studiospares are often too expensive.
siderealxxx
Posts: 647 Joined: Sat Jan 24, 2009 12:00 am Location: Cambridgeshire
Excess makes the heart grow fonder
Mine came from Travis Perkins' insulation company, CCF, who were similarly competitive on the first load but added a £25 delivery charge when I wanted a smaller second load. Other people have reported good prices from Sheffield Insulation - despite their name they have depots all over the country.
Post by SafeandSound Mastering »
I bought 100mm RW3 slabs from here years back, same old with the delivery charge, the 50mm RW3 is a shade cheaper than the link you posted:
http://www.just-insulation.com/002-brands/rockwool-mineral-slabs-flexi-rwa45-rw3-rw5-rw6.html
I found locally you tend to pay significantly more or they do not have it in stock.
Posts: 1633 Joined: Sun Mar 23, 2008 12:00 am Location: South
Zombie thread from beyond...
Anyone got any good suggestions for RW3 suppliers?
Have tried the ones listed in this thread and they either don't have anything available to deliver (or collect) to my postcode, or have a minimum order that's way too high.
Best I've found is: https://www.insulationexpress.co.uk/roc ... 8HEALw_wcB
with a £25 delivery fee.
Posts: 28834 Joined: Sun Jul 05, 2015 12:00 am Location: York
Post by Kwackman »
Jewson's are a Rockwool stockist, and from their site there's a branch in York.
https://www.jewson.co.uk/building-mater ... nsulation/
Not sure if all branches do it, but worth a call?
Also..
https://www.selcobw.com/products/insula ... insulation
Kwackman
Posts: 3570 Joined: Thu Nov 07, 2002 12:00 am Location: Belfast
Cheers Kwackman, will give them a look now.
Thanks :thumbup:
Irritatingly that Selco link looks like the best bet but doesn't give a density. :(
Will try giving them a call tomorrow but doubt I'll get a sensible answer on that one...
Like you I suspect Selco won't be able to give you an answer but I'm sure RTockwool themselves will, bung em an email. Failing that take some scales and weigh a pack (or ask Selco what the packs weigh, they may have the info available for H&S reasons?).
Posts: 22219 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Good shout. Will do.
Just under 16kg for the pack so about 35kg/m3.
Not enough irritatingly. Will give Jewson a call on monday but not sure if they sell direct to the public?
Ho hum. Didn't expect this to be easy but thought this bit might be a bit easier! :)
Post by Luke W »
From what I remember they do. Around here they're a far better company to deal with than Travis Perkins as well, prices are usually a lot better too. Not sure if that's the same everywhere, but I suspect it might be...
Luke W
Posts: 1680 Joined: Thu Feb 19, 2009 12:00 am Location: Northamptonshire, UK
Post by Kwackman »
I went to a local building supplier (they were on Rockwool's list) and asked for RW3 as that's what I wanted. I can't remember if they had it in stock or they got it for me, but it wasn't a difficult process!
I may have missed something in the earlier discussions, but I'm not sure why you are getting weights to work out density etc.
Why not just ring, or better still call if it's not too far, and ask for RW3 (if that's what you want) in the thickness you require?
You can go on to Rockwool's site and find dealers by postcode if you want to try other companies closer to you.
https://www.rockwool.co.uk/about/stockist-finder/
Kwackman
Luke W wrote:From what I remember they do. Around here they're a far better company to deal with than Travis Perkins as well, prices are usually a lot better too. Not sure if that's the same everywhere, but I suspect it might be...
I'm pretty sure I got my 45Kg/m3 via Travis Perkins down here in north cornwall, and they even delivered it free of charge!
I'd go for 60Kg/m3 nowadays though if I bought any more.
Posts: 22121 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
Kwackman wrote:I may have missed something in the earlier discussions, but I'm not sure why you are getting weights to work out density etc.
Selco have Rockwool in stock locally but it has no reference number on the packet - hence establishing the density by weight.
Kwackman wrote: You can go on to Rockwool's site and find dealers by postcode if you want to try other companies closer to you.
Having a shufti now, thanks again. :)
I have a product code for the stuff the local places are carrying - but it's not a code that appears on the rockwool website. :headbang:
Email sent to rockwool, will let you know how I get on! :crazy:
Don't let them pull the rockwool over your eyes! :D
Posts: 18696 Joined: Thu May 29, 2003 12:00 am Location: Reading, UK
Post by Logarhythm »
blinddrew wrote:Just under 16kg for the pack so about 35kg/m3.
Jewsons definitely do - I cycle past the Exeter branch most days, and they have an enormous sign hung on their fence advertising exactly this.
Logarhythm
Posts: 1093 Joined: Fri Mar 30, 2012 12:00 am Location: On an intergalactic voyage to collect fresh electrons
Cheers, will give them a call tomorrow. Should be getting a quote from Selco as well.
P.S. Wonks, I'm ignoring that... ;)
Last edited by Drew Stephenson on Sun Sep 15, 2019 4:36 pm, edited 1 time in total.
The density of RW3 is 60kg/m3 whereas RWA45 is 45kg/m3. Both are available in various thicknesses from 25 to 100mm and the sheets are generally all 600/1200mm wide/long. Both are class A1 non-combustible, of course.
It's frustrating, but understandable that most building suppliers insist on selling pallet loads, which is a lot of rockwool! And shipping will always be pricey because it is both bulky and heavy... But you can always put the left-overs in the loft! ;-)
For the Studio SOS jobs we generally use Rockwool Sound Insulation Slab packs from Wickes just because it's always in stock and can be bought in small quantities of one or two packs etc...but I'm not sure of its density to be honest... and the website doesn't seem to say.
Posts: 42812 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Drew is referring to Rockwool Sound Insulation Slabs https://www.selcobw.com/products/insulation/acoustic-insulation/rockwool-sound-insulation-slab-1200-x-600-x-50mm-8-64m
Maybe we get a little too anal about the specifics sometimes :blush:
Sam Spoons wrote:Maybe we get a little too anal about the specifics sometimes :blush:
Yeah, I did wonder about that. And then I thought, "but I only want to do this once. And furthermore, if Max says 60kg/m3 is the best compromise, then I'm not going to argue." :D
