Need help with audio quality
Post by chaseuk02 »
Hello everyone,
I am completely lost when it comes to audio. I have a audio clip where something has went bad with the first 6-7 seconds of the recording before clearing up. It sounds like the speaker is very muffled.
I am guessing that this is something that cannot be undone? Does anyone have any suggestions or could anyone clean up the audio for me? I would be eternally grateful.
https://soundcloud.com/user-353146338/foradam6/s-LKvcp
chaseuk02
Posts: 6 Joined: Wed Sep 18, 2019 11:00 pm
Re: Need help with audio quality
Post by Tim Gillett »
No that section cant be cleaned up. The information is not there. Did you make the recording or is this from somebody else? I suspect the only hope is that those first seconds were not compromised on the original recording.
Tim Gillett
Posts: 2701 Joined: Wed Jan 30, 2013 12:00 am Location: Perth, Western Australia
Post by Mike Stranks »
Had a very quick listen... mp3 only of course, listening direct on Soundcloud...
Sounded to me like the person was still coming 'on mic' as the recording started... If so it's an artefact of the mic in relation to the speaker and nothing to do with technical quality per se.
Mike Stranks
Posts: 10586 Joined: Fri Jan 03, 2003 12:00 am
Post by MOF »
I don’t think it was a delay in getting close to the mic’ it sounds like MP3 artefacts due to not enough data getting to your recording device.
Not much chance of repairing it other than Cedar audio devices and they might struggle.
MOF
Posts: 2509 Joined: Thu Mar 06, 2003 12:00 am Location: United Kingdom
It can probably be improved to be more intelligible, but almost impossible to get to match the rest of the recording.
Posts: 18690 Joined: Thu May 29, 2003 12:00 am Location: Reading, UK
Post by chaseuk02 »
Thanks everyone. I appreciate you giving it a listen.
chaseuk02
Post by chaseuk02 »
Would anyone be willing to help clean it up further even if it cannot be fixed completely?
I would pay for your time!
chaseuk02
I would if I felt I could significantly improve the first 4 seconds but I don't believe it's possible.
But I'm puzzled how what seems like a seamless section of speech could comprise two sections with such different levels of sound quality, with that abrupt change at 4 seconds in. What was the voice originally recorded on? Has this been edited in any way?
Tim Gillett
Post by chaseuk02 »
Tim, yes that is correct. It has been edited to simply raise the volume so you can hear what he is saying. In the original recording the microphone appears to cut out and you can barely hear what he is saying, then it picks up and the rest of the sound is normal.
chaseuk02
Post by Kwackman »
chaseuk02 wrote:Tn the original recording the microphone appears to cut out
How was it recorded? Was the speaker in the same room as the recording or was it someone being recorded over Skype, FaceTime, ISDN or similar technology? If so, my guess is that the recording started before the technology had locked up a solid connection.
I don't think it's fixable, but hope I'm wrong!
Kwackman
Posts: 3569 Joined: Thu Nov 07, 2002 12:00 am Location: Belfast
I'd agree with Tim on this - it wouldn't be possible to match the sound of the rest of the recording. The line sounds perfectly audible to me so it isn't a problem if this is just an audio letter, but if it is for wider circulation then the best solution would be to re-record that line and edit it in to the rest of the piece.
Posts: 16365 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Post by chaseuk02 »
It was recorded on a phone over a similar technology as you mentioned. I do believe you are correct, it looks like the connection had not had time to solidify.
Thanks for taking a listen. I just thought I would ask some folks who knew what they were talking about to see if I missed anything. I normalized the audio volume and tried to clean it up the best I could.
chaseuk02
chaseuk02 wrote: ...Thanks for taking a listen. I just thought I would ask some folks who knew what they were talking about to see if I missed anything. I normalized the audio volume and tried to clean it up the best I could.
"Cleaning up" is where mistakes are often made, for cleaning up is not always easy or even possible, let alone a perfect solution. As James said, just re recording may the best solution here. Here's an interesting short article by Nick Messite of Izotope on 8 Common Audio Restoration Mistakes.
https://www.izotope.com/content/izotope ... takes.html
Tim Gillett
Indeed!
... and thanks for that link Tim... I'll have a listen later.
(A note for old sweats here: Have you noticed how often Mr G and I are agreeing these days? Wondrous! :lol::thumbup: )
Mike Stranks
Post by chaseuk02 »
Thanks, Unfortunately, re-recording is not an option. So I just tried to make it audible and will have to live with the difference in audio quality it appears.
chaseuk02
I reckon he'll remember the message long afterwards and probably won't even really notice the first few seconds. :thumbup:
Posts: 28828 Joined: Sun Jul 05, 2015 12:00 am Location: York
Post by innerchord »
That sounds like adaptive audio codec switching. There is probably some scope for improvement.
innerchord
Posts: 212 Joined: Wed May 11, 2016 12:00 am
Post by molecular »
I suspect Drew is right and the listener will almost certainly give it a lot less thought than anyone on here...
But you could do a bit of creative editing the start if that hadn’t occurred to you... could be a way of making it start with the congratulations phrase perhaps.
molecular
Posts: 1318 Joined: Sat Dec 13, 2003 12:00 am Location: Skye / Stroud / Seyðisfjorður
Anto mo Ninja, Watashi mo Ninja http://www.hectormacinnes.com
I agree. The only alternative I can think of is to synthesise those 4 seconds by selecting the same words out of the rest of the message (if they all appear) and carefully editing them using the 4 second section as the template. But you might only discover how acceptable was the result by actually doing it.
Tim Gillett
Post by Terrible.dee »
chaseuk02 wrote:Hello everyone,
Any type of major digital audio surgery is "Fool's Gold" and a waste of your time,
Do it again, do it RIGHT
Terrible.dee
Posts: 126 Joined: Tue Apr 18, 2017 9:12 pm
Er, it pays to read the whole thread. The OP has just stated that rerecording is not an option. We've already agreed that the relevant section is too poor to be retrieved for the purpose intended.
Tim
Tim Gillett
