Mic stand for recording acoustic
Post by Scouser »
Recently purchased a Neumann km184 to start some serious recording and need a suggestion for a mic stand, ideally small footprint but safe ! Doesn’t need to be a tall one as I will only be using it to record acoustic.
Scouser
Posts: 842 Joined: Mon Oct 04, 2004 12:00 am
Re: Mic stand for recording acoustic
Post by John Willett »
Look at the K&M pro range - high quality and good value.
Do NOT get the cheapo cheapo stands that you often see.
John Willett
Posts: 7297 Joined: Tue Mar 07, 2000 12:00 am Location: Oxfordshire UK
Post by Dan LB »
Dan LB
Posts: 1691 Joined: Sat Jan 28, 2006 12:00 am Location: Wicklow, Ireland
Whilst I use K&M stands, you can get decent stands for less that won't slip or move if tightened properly. Especially for light home use. But once you have a decent stand I'd suggest that a decent shock mount will be of the biggest benefit.
The KM184 normally only comes with a clip mount, so I'd suggest looking at one of Rycote's excellent offerings. Don't forget to use an anti-vibration loop of mic cable between the stand and the mic itself.
Post by Kwackman »
For a smaller footprint consider one with a heavy round base.
Kwackman
Posts: 3686 Joined: Thu Nov 07, 2002 12:00 am Location: Belfast
I agree with all that has been said above.
The K&M floor stands are HERE
If you want a small stand which does not take up much floor space then THIS ONE is a new one that may fit the bill. :thumbup:
But all the K&M stands are good ones. :thumbup:
John Willett
However, a taller stand that you can use to try micing from over your shoulder might be more versatile.
Wonks wrote:However, a taller stand that you can use to try micing from over your shoulder might be more versatile.
Agreed - just look at all the mic. stands and accessories on the K&M website and then choose what best suits your needs. :thumbup:
John Willett
Post by Mike Stranks »
Scouser wrote:Recently purchased a Neumann km184 to start some serious recording and need a suggestion for a mic stand, ideally small footprint but safe ! Doesn’t need to be a tall one as I will only be using it to record acoustic.
Do you want a boom or just straight up/down?
I'm sure a lady of dubious reputation made the same enquiry of me once... :blush:
:lolno:
Posts: 43690 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
The closest that I could find to what I use is a combination of this stand
https://www.k-m.de/en/products/mic-stan ... 0-55?c=178
with this boom arm
https://www.k-m.de/en/products/mic-stan ... 0-55?c=180
Having both the stand and boom arm extendable makes it very versatile but that versatility doesn't come cheap. I've had mine for something like 35 years and they were secondhand when I bought them so they're certainly well built.
Posts: 16988 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
:bouncy::D
James Perrett wrote:The closest that I could find to what I use is a combination of this stand
with this boom arm
That looks like a very nice combination JKames. :thumbup:
John Willett
Post by shmuelyosef »
I have had very good results with the Ultimate line of stands.
The "Ulti-Boom Pro-TB - Telescoping" is a great value to provide flexibility on any size stand...contrary to intuition, a boom on a tallish stand uses a small space more effectively than something tiny as you can push the stand against the wall partially under a desk or table and have the microphone 'lean' towards you. I think that I paid $60 for my combination with the boom listed above on a telescoping stand with a weighted base (more compact than tripod bases).
I easily hang heavy large diaphragm mikes off this as well as X-Y small condensor pairs (for stereo on guitars or woodwinds.
Just to be specific, I am referring to THIS BOOM on THIS STAND
B&H always has the best prices
shmuelyosef
Posts: 12 Joined: Fri Aug 04, 2017 3:13 am
Post by Shostakovich »
Like the OP, I too am looking for a mic stand for recording acoustic guitar. My 40 year old boom stand has finally gone to the big studio in the sky.
The problem is, all I need is a straight stand, but they all seem to have a minimum height of 1m, which is too high for a sitting down acoustic guitarist. The alternative is to buy a boom stand and not bother with the boom, without which the height is commonly around 70-80 cm, but involves not using the boom which you've paid for and don't need.
I need a 'straight up' stand to mount my rode stereo bar on for ORTF, or my wide bar for wide spaced.
I've almost lost the will to live in searching for a webpage where the vendor or even manufacturer can be bothered to provide specifications about the working heights of the stand.
Hopefully, some evil person will enjoy humiliating me by pointing to such a website following less than a second searching. :lol:
Shostakovich
Posts: 221 Joined: Wed Sep 20, 2006 12:00 am Location: West Dorset, UK.
Excelling at mediocrity for 71 years.
know a web site where you can buy a 30cm deep hole to put a stand in. ;)
Post by Humble Bee »
https://www.k-m.de/en/products/mic-stan ... 960-300-55
We have two of these and they are great small footprint, flexible stands for recording acoustics. It is known for its agility around a drum kit to and have even reached a few brass sections in their time. :thumbup:
And amps. Tops!
And yes, K&M all the way!
Humble Bee
Posts: 395 Joined: Mon Jan 08, 2007 12:00 am Location: Cloughton Newlands
Wonks wrote:This any good for you? 625-1480mm.
https://www.thomann.de/gb/km_199_mikrof ... =undefined
I have one of these and it's a decent bit of kit, I use mine as an iPad stand but am considering a couple more as the fold up so small.
Ha, yeh perfect! That's the kind of humiliation I'm looking for :D
I'm sure I looked at the K&M site, but must have missed the specs.
Shostakovich
Post by Bob Bickerton »
Most of the time I use a stand but occasionally I find the H-Clamp useful http://exploraudio.com/categories/instrumounts-h-clamp-/1/.
Once you’ve sorted an optimum position it’s a set and forget solution.
Bob Bickerton
Posts: 5637 Joined: Fri Dec 20, 2002 12:00 am Location: Nelson, New Zealand
Post by Scouser »
Hey guys thanks so much for all the advice, went for a K&M in the end, real nice build quality very happy with it.
Scouser
