Thinking ahead perfect PA
Post by gsc1ugs »
Ok, ive brushed on this b4. I want a small very good system that delivers anything upto 500, i always need take all the gear but if its small 120 peeps i want put less in the room, if more i had to it, what would people recommend without breaking my back, i wont be hiring in, i need to do this myself. This is alot to do with lower end bass, i want the same sound in each room
gsc1ugs
Posts: 298 Joined: Thu Oct 18, 2018 12:08 pm
Re: Thinking ahead perfect PA
Post by Music Wolf »
gsc1ugs wrote: i want the same sound in each room
Then you need a PA + Engineer
Music Wolf
Posts: 2894 Joined: Fri Feb 17, 2006 12:00 am Location: Exiled to St Helens
This ^
Somebody said in one of your earlier threads you can choose two out of three from good, cheap & light. That's still true, as are the laws of physics, small rooms and/or small boxes don't result in accurate bass.
Posts: 22884 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Post by AlecSp »
This ^^ and that ^
AlecSp
Posts: 826 Joined: Tue Nov 16, 2004 12:00 am Location: Herts, UK
Post by shufflebeat »
That ^^.
It's not as simple as you think.
shufflebeat
Posts: 10106 Joined: Sun Dec 09, 2007 12:00 am Location: Manchester, UK
Post by Dave B »
gsc1ugs wrote:i want the same sound in each room
You and every other artist! This is the killer - with the right knowledge and experience it can be done with relatively modest kit. But even if you splurge on the most expensive rig imaginable, without someone with that knowledge running it, you’re never going to get that consistency...
Think of it this way : a more expensive PA will cost, say, 3 grand - 2 if you trade stuff in. Say you paid an engineer .. 100quid a gig .. that’s at least 20 great sounding gigs which will pretty much be guaranteed to get you more bookings. And help save your back loading in/out. And less stress and worry which should mean a better performance from you.
So ask yourself : isn’t it worth it to be able to provide a quality product? And not have to worry about (or explain away to a miffed venue / promoter ) bad sound / unexpected squeals and howls?
Dave B
Post by gsc1ugs »
Trouble with hiring other people is the reliability issue, illness, sorry, didnt get that date. Etc. One person coming down with dreaded lurgy is issue enough.
I think a graphic would help so i can sort the room out, so the question still stands, is this add on pa more than likely an array system (frightened to mentioned ) l’acoustic system, ive seen the id24 system again a fortune but the smaller the better just keep adding pairs, i know i sound novice but i still cant get my head round the perfect system for all, indoor outdoor. I being my last big investment quiting other jobs to put my effects into it i want the right gear. Thanks for listening.
gsc1ugs
The premise of your question is flawed. The perfect PA system, like an F1 racing car includes someone who can get the most out of it.
Bearing in mind that the sound experienced by those listening to it will be determined to a significant extent by the space itself and the physical properties of the audience there is an inherent problem in recommending any kind of "set and forget" system.
I would suggest a good operator with a mediocre but sufficient system will provide a much better experience for the listeners than a bus driver in a racing car.
Good people usually value their reputation and will do at least as much as you to be reliable. They may even improve your project in ways you haven't considered.
shufflebeat
Post by gsc1ugs »
Great words.... BUT.... at this stage im looking at something i can manage and and good rig with easy enough add ons and a graphic will suffice for now. Thanks for all your input.
gsc1ugs
Post by MarkPAman »
shufflebeat wrote: They may even improve your project in ways you haven't considered.
As your setup is vocal & backing tracks, there's probably not too much to do with the sound once it's set right for circumstances of that night, so you could find somebody who can, look after the lighting too.
MarkPAman
Posts: 1020 Joined: Thu Apr 06, 2006 12:00 am Location: Somewhere between Portsmouth & Chichester
There has been a lot of good replies here, great advice, but sometimes compromises and have to be made to get to where you want to be.
I got roped in to manage the PA for a friends band, and I'm not, a PA engineer.
The idea of a graphic EQ to match sound to venue isn't such a bad one under the circumstances, I did the same thing, it's not maybe the "right way" to do it, but it works sometimes. I used to use radical EQ settings on our mixer to get out of trouble, settings that looked obscene, but it worked and no one complained, or thought anything was wrong.
Also, hiring a "proper" PA engineer isn't simple, good ones aren't easy to find, you could easily end up with someone who would do a worse job than you, how often have I heard that before?
Posts: 21909 Joined: Sat Jul 12, 2003 12:00 am
Post by Tim Gillett »
And even with the best PA and the best engineer, even that wont be enough. The venue has the final word.
Tim Gillett
gsc1ugs wrote:I think a graphic would help so i can sort the room out,
But you'd have to know how to use it
Two boxes a line array does not make, and you'd need at least one sub even in the smallest rooms (and you'd need 4 id24's a side to match a pair of Yamaha DZR10s).
One system will not do all jobs, if it's man enough for 500 people outdoors it will be too big for an indoor function to 60 punters and vice versa.
Do you have a promo vid you can link to, I seem to remember seeing one a while ago but can't find it. IIRC your show is very polished.
Post by gsc1ugs »
:bouncy::D
Its just a promo for agent.
https://youtu.be/3KiT3lxs2yM
gsc1ugs
Post by MarkPAman »
Nice.
But if you don't cup the mic, that will help the sound.
Just checked a live Madness video - Suggs holds it quite high up, but does not appear to cover the grill at all.
MarkPAman
Post by gsc1ugs »
Got use to doing that when i had no bins... sometimes do it for low speaking lyrics, live is different from that promo. Thxs :thumbup:
gsc1ugs
Yes that's the one I remember, nice :clap:
Cupping the mic affects the frequency response and directionality (if you block the vents at the back of the capsule you change the pattern into omni with all the feedback issues that can produce).
gsc1ugs wrote:Great words.... BUT.... at this stage im looking at something i can manage and and good rig with easy enough add ons and a graphic will suffice for now. Thanks for all your input.
I feel you may have inadvertently pre-derailed the conversation with the word "perfect". If you were to substitute "appropriate" we might have been more focussed on your needs rather than dealing with the fact that a "perfect" option doesn't exist without an actual human making real time choices.
Do you already have a mixer?
Are the rooms adjacent?
EQ will not solve phase issues, it may mask them temporarily until your audience arrive.
Once you have the main FOH sorted a pair of Yamaha DXRs on a delayed aux if appropriate would raise few complaints from normal punters (SOS folks might tut a little).
shufflebeat
OK, back to the original question.
You'll struggle to find a scalable system that will cover all the bases, the nearest I can think of with a decent budget would be 4 x DZR10s and a couple of DXS15 subs. 2 x tops for small gigs and add a sub or two and the extra tops as delay satellites* as they get bigger. You'll need a digital mixer (any will do the job but I have 2 x X32s, an XR12 and a Mackie DL1608, the Mackie is the easiest to use)
* place them part way down the room and delay them by 1ms per foot. They won't work as well placed side by side in a conventional room but if you run one pair about 3dB lower than the other it helps keep comb filtering effects down. In an odd shaped room firing the tops into different areas will work ok.
Post by gsc1ugs »
Your right, im doomed, just setting up now
In a room hard floored, how the hell can i sound check with noone in
gsc1ugs
Post by gsc1ugs »
I do remember something years a called i think an autographic equaliser, dont know anything about it but i believe it sorted the graphic to the room but to who’s taste?
gsc1ugs
Post by gsc1ugs »
Sam Spoons wrote:OK, back to the original question.
Thats 4 x £915
2 x £1587
:ooo:
gsc1ugs
Thats 4 x £915
2 x £1587
:ooo:
To be fair, this is quite an expensive game if you want quality/ease of use/reliability.
Your goal is good and the advice here is well intended.
shufflebeat
Thats 4 x £915
2 x £1587
:ooo:
Considering the iD24 rig you linked to is £6.5k for only 4 boxes I'd say that was terrific value. And it'll be much louder.
If you fancy L'Acoustics kit a single 112P (now discontinued) FR cab would set you back £6k+ and it doesn't go as loud as a DZR10.
Good, cheap & loud, pick 2.......
Post by gsc1ugs »
I know the advice is excellent reason im on and about to start a new thread :crazy:
I will try my best find that rig 2nd hand. I dont mind bashes and bruises. Thxs all.
gsc1ugs
