Equipment List for recording an Orchestra
Post by bragimike »
Over the last few months I've asked a number of questions regarding recording my Wind Orchestra. I have now received the go ahead to purchase a recording set up, as hiring the equipment was expensive when you take into account that we would like the option to record more requently. We would like the option to record XY or ORTF.
With my limited knowledge of the options and the budget that has been agreed, I came up with the folowing equiment list:
ZoomF4
Matched Pair Mics Audio Line CM4s
Konig & Meyer Mic Stand + Stereo Bar
XLR Cables
SD Cards x 2
Does this seem like a sensible equipment list? Have I missed anything? I was considering Rode NT5s as an alternative to the CM4s.
I'm based in Nottingham and I'm looking for the best company to purchase the equipment off too if anyone has any views.
The replies to my previous posts and been extremely helpful, so thanks in advance for any assistance.
bragimike
Posts: 15 Joined: Fri Nov 30, 2012 12:00 am
Re: Equipment List for recording an Orchestra
Post by Bob Bickerton »
You just about have it covered, but you’ll also need a good set of headphones for monitoring. The microphone stand needs to be of the tall variety.
Then you also need to consider what you do with the audio once it is tracked, so you’ll need probably need a DAW for editing, so that’s a computer and interface as well as monitoring too.
I’d go with the CM4s over NT5s and would consider a future upgrade to be to add an Omni pair.
Bob Bickerton
Posts: 5642 Joined: Fri Dec 20, 2002 12:00 am Location: Nelson, New Zealand
Post by Aural Reject »
I've used Pink Noise Systems for my Line Audio purchases....I've not had anything outside of the mics off them though....but always been very good.
Aural Reject
Posts: 995 Joined: Fri May 02, 2003 12:00 am Location: Lancashire born, living in Yorkshire :s
Post by John Willett »
Aural Reject wrote:I've used Pink Noise Systems for my Line Audio purchases....I've not had anything outside of the mics off them though....but always been very good.
:thumbup: Pink Noise are good.
John Willett
Posts: 7297 Joined: Tue Mar 07, 2000 12:00 am Location: Oxfordshire UK
Post by bragimike »
Sorry, I should have mentioned: I already have a suitable DAW and headphones, so they're taken care of.
bragimike
While I remember, I use Rycote Invision shockmounts with my CM3s rather than the clips they come with...also from Pink Noise.
Aural Reject
Ooh. My first ever double post! How exciting.
Aural Reject
Post by MOF »
What are you going to use the recordings for, will you be re-recording any sections for editing in later?
If so then probably a separate recorder for playback to the conductor on headphones to get the timing right.
If that’s the case then it might be worth using a watch to record the time of each section on the score during rehearsals and then a notepad to note the start time of each recording so you can go to the relevant section for listening/playback.
MOF
Post by MOF »
A separate thought to convey to the performers, they must remain absolutely still after the final note to allow you to get the whole reverb tail and some room atmos’. Nothing worse than an abrupt fade out. :D
MOF
If this is for recording public performances, I'd recommend the K&M 26009 round base, along with the 26007 pole which is listed at the bottom of this page:
https://www.k-m.de/en/products/mic-stan ... 0-56?c=179
It minimises any obstruction of sight lines and can be disassembled easily to pack away in a small space.
Posts: 43698 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Post by MOF »
It doesn’t have to be a good quality recorder, an iphone will do, good enough to provide a timing reference.
MOF
Post by forumuser840717 »
Or one could suggest that the conductor get a metronome! Or you could get one and play it down the talkback to him.
Though any conductor worthy of the name should be able to maintain a consistent enough tempo from take to take. Those who know they can be a bit wayward often carry a metronome of their own anyway. A separate playback device really shouldn't be necessary.
Last edited by forumuser840717 on Thu Oct 24, 2019 7:22 pm, edited 1 time in total.
forumuser840717
Posts: 485 Joined: Thu Jun 16, 2016 5:20 pm
Post by MOF »
I think the budget is fairly tight, I don’t think there will be any talkback system.
I suggested an iphone (other brands are available) as they are readily available and yes you could download a metronome app’.
MOF
Sounds like a decent list, but things don't always go as planned, spot mic's may be needed, and with the best intentions a stereo,pair doesn't always do the job, no matter how hard we try. So I would budget for a couple of extra mic's, in the future.
A talk-back needn't be expensive, a roll of cheap cable, and the cheapest of mic's, plugged into a spare mixer channel, the smallest Behringer will do, all you need then is a crappy active speaker. You can cobble this lot together for very little money.
Posts: 21959 Joined: Sat Jul 12, 2003 12:00 am
Post by MOF »
Hi bragimike, I was just wondering how things went with equipment purchases and recording?
MOF
Post by bragimike »
The equipment has been purchased and I tried it out at the weekend. I used an ORTF configuration at different distances from the orchestra to find the best placement. I may try XY this weekend to compare. This may be for another post: but is ORTF preferable over XY for an orchestra?
The equipment itself sounds great!
bragimike
I often use ORTF rather than X/Y for orchestras and ensembles, but I’ll also often use Omni outriggers as well. I find ORTF gives a good balance of definition and expansiveness whereas X/Y is a little clinical for my liking. It’s all related to the room and where you can place the microphones too of course.
The good news is that you can experiment and make up your own mind :thumbup:
Bob Bickerton
Preferable is entirely down to the kind of sound you're looking for (or the producer or conductor wants).
Coincident arrays like XY tend to give much more precise imaging at the expense of a reduced sense of 'spatiousness'... whereas near-spaced arrays like ORTF tend to give more of a sense of spatiousness at the expense of imaging precision.
But there are also other considerations, such as the sound of the room itself. An ORTF array needs to be quite a long way back from the orchestra because it has a relatively narrow stereo acceptance angle. That means it will capture a relatively large amount of the room sound which may or may not be desirable.
In contrast, XY cardioids typically need to be right above the conductor because it has such a wide stereo acceptance angle, and thus has a much smaller proportion of room sound...
So choosing and placing the mic array(s) is what audio engineering is all about... and there is as much artistic interpretation involved as their is engineering science.
Just remember that an XY array can have any desired mutual angle -- it doesn't have to be 90 degrees -- and that there are more near-spaced options than just the classic ORTF format!
