Cubase Recording
Cubase Recording
Post by twotoedsloth »
Hello,
Is there a way to record the master bus output of Cubase while recording? I would like to give performers a rough mix right after their recording sessions. This was trivial in Vegas, but since we moved to the Mac platform, Cubase is DAW we are using.
Our hardware setup is a Focusrite Clarett 8pre and a Focusrite ISA 828 recording to an Imac Pro running Cubase.
Many thanks,
Peter
twotoedsloth
Posts: 1136 Joined: Sat Jan 26, 2008 12:00 am
Re: Cubase Recording
Quick and dirty would be a loopback within your AI's mixer app?
Or just record the incoming audio so it's available to export? That way if you capture a moment of magic it's a double-win.
Post by Kwackman »
What sort of file are you hoping to give them? MP3, Wav?
The Cubase export (turning real time option off) can create a file (of most types) pretty quickly after you have recorded the artists.
Kwackman
Posts: 3687 Joined: Thu Nov 07, 2002 12:00 am Location: Belfast
Post by ore_terra »
You can always route everything to another bus rather than the Master. That way you could print it in the mix if you want so.
Anyway, I agree with the latest above: exporting does not take that much time in cubase.
ore_terra
Posts: 1090 Joined: Fri Dec 02, 2016 12:56 pm Location: Seville - Spain
casmoestudio.com
Post by OneWorld »
Export audio will work fine unless you have hardware midi instrument output in the mix, if that's the case I've had to set up an audio channel to capture the output as an audio file. I have tried various loopback/record the mater bus options but never got them to work
OneWorld
Posts: 5960 Joined: Tue Apr 07, 2009 12:00 am
Post by Mixedup »
You could insert a virtual tape recorder plugin on the master bus. That would write direct to a WAV on the hard drive. You should even be able to write direct to a USB pen drive in theory, though I've not tried it. There have been a few such plugins over the years (I used to use them for multitrack exports in the days before Cubase had a batch export facility!), but I think you'll find one in Melda's free bundle...
Mixedup
Post by OneWorld »
Mixedup wrote:You could insert a virtual tape recorder plugin on the master bus. That would write direct to a WAV on the hard drive. You should even be able to write direct to a USB pen drive in theory, though I've not tried it. There have been a few such plugins over the years (I used to use them for multitrack exports in the days before Cubase had a batch export facility!), but I think you'll find one in Melda's free bundle...
Melda has the mrecorder which looks really useful.....but, you have to download a whole krock of gubbins, as is per usual these days :-( Back in the day you'd download the VST, drop the .dll into the VST folder and that was that
OneWorld
Post by Fishnish »
I agree, Export Mixdown is really quick, unless you're doing huge projects.
Fishnish
Posts: 239 Joined: Fri Dec 24, 2010 12:00 am
Post by Mixedup »
Yeah. OTOH there's some useful other stuff amongst this particular set of gubbins, including stuff that isn't bundled in Cubase. And it's pretty unobtrusive... You could try hunting i the KVR database for a similar thing I suppose.
Or maybe look at Voicemeeter Banana... I think you csn route Cubase to that and record the result.
Mixedup
Post by OneWorld »
I am not sure you can, as Cubase subsumes all other devices unless you choose "Release in backgound" which then hands audio dutiers over to another audio software that works in isolation of Cubase. If it were a VST then yes it would capture a recording from Cubase playback, but thanks anyway and I'll checkl it out.
I have managed to do it with other setups but they don't capture the output from a hardware synth even though that output is shown in the stereo/master output of the Cubase Mixer.
I used to use an RME Fireface 800 and that did allow me to make a stereo file by simply patching the outs and ins, in the Total Control software. I now use a Focusrite Liquid 56 and thought I could do the same, but can't, again the issue is the outputs from hardware synths not being captured
OneWorld
Hello,
Thanks all of your for your responses and suggestions.
I was able to resolve this by using the loopback feature in the Focusrite application.
Sincerely sorry that I was away for a few days.
Your help is greatly appreciated.
Peter
twotoedsloth
Post by OneWorld »
twotoedsloth wrote:Hello,
Peter
Any chance of giving a step by step instruction on how to do it? There are a few tutorials on YouTube but they all deal recording the output of for example Windows Media Player into Cubase, whereas I want to record Cubase into Cubase
OneWorld
Post by Mixedup »
There are various ways to record Cubase into Cubase. Eg, you can route everything to a Group bus before the master stereo bus, and use that Group as the input source to an audio track. As long as that audio track isn't routed to that Group (set it to no output) you can record the result.
The loopback method depends on having an interface that supports digital loopback, or on having spare I/O (digital or analogue) to create a physical loopback and routing software with your interface that allows you to create multiple mixes.
Eg. on my RME interface, I can have Cubase send its output to the interface's channels 1+2. Engage loopback on outputs 1+2 and the signal will also appear at inputs 1+2. Then in Cubase or whatever software, you select inputs 1+2 as the input source and record in the usual way. Again, you just have to be careful not to monitor/route this recording channel to the same outputs or you'll create a feedback loop.
The only problem with this way of working is if you want to be stop/starting Cubase while recording the result — you'll stop recording too. That's where you'd want to record the result into a separate application.
( used to use this method to record separate Cubase sound and narration mic onto different tracks in Camtasia, as detailed here... )
Voicemeeter Banana is also worth checking out...
Mixedup
Post by OneWorld »
Mixedup wrote:There are various ways to record Cubase into Cubase. Eg, you can route everything to a Group bus before the master stereo bus, and use that Group as the input source to an audio track. As long as that audio track isn't routed to that Group (set it to no output) you can record the result.
I'll try that method.
Yes when I used an RME interrface it was easy. I now use Focusrite and their software has a loopback feature but the examples they give are for recording the output from one device (weg Windows Media Player) into the DAW
The Banana thingy is overkill for my needs.
If all else fails I'll get the RME froim under the bench, their Totalmix software is brill. In fact I am considering selling my FF800 and purchasing the UFX
If all else fails
OneWorld
Hello,
Do you still need me to write up a short tutorial on using the loopback on a Focusrite Clarett? Or do you have it figured out now?
It really was quite simple, it was a week ago, and I don't have access to that computer right now, but I think I just used the Focusrite application, set the loopback to 17 and 18, and recorded those channels in Cubase. Important note: Do *NOT* monitor the 17 and 18 inputs, as you get really nasty feedback.
I can get to that room later this week or weekend if you need me to,
Best regards!
twotoedsloth
Post by OneWorld »
Best regards!
Thanks, it's ok, from that description you have written I sort of get the idea. I guess you are feeding the stereo/master out of Cubase to the loopback and then loopback(out) ===>inputs(ch17 + ch18)
OneWorld
Post by OneWorld »
Best regards!
It worked :-)
Don't know what I have done exactly, what I expected to work didn't, then I pressed another button and it's working. Need to take some screenshots!
OneWorld
