hardminder wrote:n o i s e f l e ur wrote:
So basically . . . what motherboard is it?
Yes, sorry about that. My motherboard :
Gateway DX4860 (yes i know, crappy motherboard).
Chipset : Intel Ivy Bridge
Southbridge Intel H67
BIOS : American Megatreds P03-A3
Graphic Interface : PCI-E
Someone suggested that cheap chipsets could be the cause for my CPU not taking 32gb ram.
Would I be able to enjoy the advantages of the NVME M2 with only a new Mobo without changing my CPU or would that be plain stupid?
Thank you
Hmmmm yeah - I think it's probably time to upgrade the system! That is indeed a pretty basic board. It's certainly possible you could use an NVMe SSD on a better board (anything with PCIe v3 x4 slots, either a PCIe NVMe drive, or card-adaptor with M2) but finding something suitable is going to be a chore, to say the least.
hardminder wrote:
So if I have to change my CPU, no AMD until I go in the 3000 series. Noted!
Yep. AMD single-threaded performance prior to this latest gen wasn't pretty compared to Intel, particularly for audio . . . and multi-threaded performance (the whole reason one might go AMD versus Intel, to get more cores for the money) tended to result in poor low-latency audio performance also.
That said, I don't have a dog in the Intel v AMD fight - and I believe the latest gen AMD stuff has addressed all of the above. Single-threaded perf is now about on par (depending on workload sometimes a bit better, sometimes a bit worse), and they've fixed the microarchitectural issues that held them back on multi-threaded perf.
Agharta wrote:
Then there are the security issues with Intel platforms and the issue of whether the board you buy will have the latest and future updates.
This is completely overblown for a single-user desktop use-case, presuming you're referring to the recent speculative-execution issues? I mean, it's a real issue - but more something for the folks running datacenters to be concerned about. It's about on a par with worrying about Rowhammer attacks on RAM really. Let's not forget that Intel, MS and the BIOS / UEFI vendors have released mitigations for these, which funnily enough contribute to AMDs recent single-threaded competitiveness!
AMD systems aren't completely immune from spec-exec vulnerabilities either, nor ARM. I agree a more modern system would be better in this regard, but again, it's a completely overblown issue for the common user.
I have to disagree about buying an older Ryzen system, they're sub-par with contemporaneous Intel kit no matter which way you cut it - and current AMD / Intel outperform it in every way that matters for audio work.
My advice would be to take a look at whatever current budget platform Scan offer (AMD or Intel), and hew closely to that.
Single fast M2 NVMe for everything will suffice - you can always add to this later. The whole point of NVMe is the protocol is designed for very low-latency / high-concurrency, it can service the OS perfectly well even during file loads like loading sample, audio tracks etc.
32GB of RAM in 2x 16GB sticks - again, you can add more as need / budget allows.
https://www.scan.co.uk/3xs/custom/daw-d ... ations#anc
If you can get a specialist outfit like Scan to build the new system, do that. I did. Not because I couldn't spec, source and build myself (I'm more than qualified to do so) - but because they could test the build before it ships, have plenty of parts to hand if issues crop up etc. It's a real pain to have to deal with RMAing faulty kit, and without known-good parts to swap out it can be quite the task tracking down any issues that do arise.
