The tuner strip reminded me that I was going to comment on how little tuner strips have changed over the years.
Last weekend I picked up a late 30s/early 40s regal parlour guitar for £100. Can't see any serial number on it so there's no no hope of an accurate date. Whilst the original machine heads work, two of the tuner buttons are very bent and there's so much play in the gears that getting it in tune and staying in tune was never going to be easy. So whilst I'll keep the original tuners safe, I went and bought a set of Kluson strip tuners.
These have exactly the same post centres, fixing screw locations and an almost identical mounting plate size and shape to the originals. And I expect the original strips were available from at least the 1920s (or before). So you can buy tuners today that will fit guitars made 100 years ago. And Gibson still use this strip size on their LP Jr and Specials.
The tuner post holes should have pressed steel ferrules, which have obviously fallen out over time, so I've ordered some more of those. They don't have any splines, so really need a dab of glue to keep them in place. The Klusons came with bushings, but they were of a wider, more modern design, so won't be fitted.
The guitar itself has many partially loose battens, so I'm in the process of gluing them back before stringing it up.
