Overdrive unit/pedal for warming digital synths?
I've been using mainly analogue synths for awhile now, my Mini Moog, Eurorack, for a bit, and now my Buchla. All I can think of is that I've got used to a ceartin type of sound.
But now I'm revisiting my old digital stuff, my A--Station is fine, that has a sound that's unique, and I don't mind that, but I have an Alesis Micron and a Proteus 2000 that could benefit from a bit of a warm up.
I know there are various ways of doing this, more obvious chorusing or layering, but that's not what I'm after, all I need is a thickening, warming up of the sound, I'm after a stereotypical tube sound, not something subtle, a cliched valve sound, harmonic distortion.
Re: Overdrive unit/pedal for warming digital synths?
Still can't say I interpret distortion as being 'warmth', but...
https://www.soundonsound.com/forum/viewtopic.php?f=23&t=47153
The Elf wrote:Still can't say I interpret distortion as being 'warmth', but...
That thread mentions the ART Tube preamp, I'm thinking along these lines, but I'm also thinking of maybe putting things through an amp, for a more dramatic effect.
Maybe distortion is the wrong word, I can hear in my head what I want, it's just bigger, warmer, I can cut the top,end and hoist the bass and lower mid, but that's not it, I think it may be the harmonic distortion of valves, they seem to do everything but don't rob the sound of clarity, it's like something nice has been added.
dbx386? At some point you're likely to need stereo.
The Elf wrote:dbx386? At some point you're likely to need stereo.
Elf, I definitely need stereo, from the beginning.
This is a "saturated" market..... :blush: sorry!
The first thing that comes to my mind is the Culture Vulture, but that's stupid money, but this is like buying a suit, and just as personal, a fifty quid pedal might do it, ad we are talking about a little hundred quid synth, its not worth spending too much.
Arpangel wrote:Elf, I definitely need stereo, from the beginning.
Then I'd definitely put the dbx386 on your check-list. I thought those ART Tube boxes were all mono?
I'd recommend my beloved VKP-1, but I have only seen one other in many years of searches.
They have been around for over ten years now and are seen as a bit 'Marmite', mainly because of size and power requirement but the Blackstar HT pedal range are noted for a good OD sounds and are very controllable. Might picjk one up cheaply second hand.
The 'warmf' is generated by a double triode and unlike most other 'toob' pre amps, these run at the right, ouchy, 300V HT.
Most versatile of the lot is the HT-Dual and that also has a speaker emulated second output ideal for recording or feeding a PA. Designed for guitar of course but the tone controls have vast range. TMB plus a sweep notch filter.
Got a good review in the mag.
Post by Dan LB »
Elektron Analog Heat?
https://youtu.be/PQXPARuCXZg
There’s a MKii version now too.
Dan LB
Posts: 1691 Joined: Sat Jan 28, 2006 12:00 am Location: Wicklow, Ireland
I'm not after a "hovering on the edge" type of sound, just a "nice" valve processor, it's getting that balance, or getting something with a fine degree of control, I just want my Micron to sound like an Oberhiem through a Fender Dual Showman, come on chaps, is that really too much to ask?
Arpangel wrote:I just want my Micron to sound like an Oberhiem through a Fender Dual Showman, come on chaps, is that really too much to ask?
Yeeeeeeeeeaaaaah...
Have you considered a new synth?! :wink::lol:
Yeeeeeeeeeaaaaah...
Yeeeeeaaahhhhh????? Oh, OK then!
:D:D
I loved my Micron, got loads of good sounds for it, but lately it sounds so damn thin, for some reason.
And an amp perhaps? ;)
blinddrew wrote:And an amp perhaps? ;)
I've got a Roland Guitar Cube, I'll put it through that with a bit of drive, it's got a recording output, I'll try that.
Whatever the question now is, the answer is "Novation Peak".
My work here is done! :D:beamup:
The Elf wrote:Whatever the question now is, the answer is "Novation Peak".
I've just passed the Peak, I'm on my way to the Summit...
Post by chanceoperation »
chanceoperation
Posts: 61 Joined: Fri Aug 01, 2008 12:00 am Location: Montreal
chanceoperation wrote:maybe this?
https://www.radialeng.com/product/firefly
Mono, from what I can see.
Post by IAA »
Mr Wakeman no less pushed many of his synths/keyboards through external amplification in the studio to rather good effect!
You could also send some of your digital stuff through the Model D ext input - that's also quite a nice sound - Ive tried it with a Kronos lead and it was quite nice
Ian
IAA
Posts: 1621 Joined: Fri Dec 28, 2007 12:00 am Location: York
Post by BillB »
Shouldn't you just attach wooden end-cheeks to the synths in question? :tongue:
BillB
Arpangel wrote:I'm not after a "hovering on the edge" type of sound, just a "nice" valve processor, it's getting that balance, or getting something with a fine degree of control, I just want my Micron to sound like an Oberhiem through a Fender Dual Showman, come on chaps, is that really too much to ask?
Sorry to press the point but, the Dual can go from as clean as a triode ever gets and at neg 10 that is pretty bloody hi fi! To total mayhem in 3 stages and with excellent control.
Just spotted this YouTube video that may be of interest:
Does a TUBE PREAMP add warmth to your SYNTH?
https://www.youtube.com/watch?v=joNM5No1Ef8
Jump to 13:03 to hear the A/B (ish) comparisons.
Last edited by Martin Walker on Fri Dec 13, 2019 11:49 pm, edited 2 times in total.
Oh, and I just remembered that I wrote this for SOS yonks ago - it might just contain something relevant to your desires Tony ;)
Warmer Sounds From Digital Synths
https://www.soundonsound.com/techniques ... tal-synths
Post by BillB »
That’s a great article, Martin, just what Arpangel needed. You forgot to mention wooden end cheeks and unnecessary brass fittings, which is surprising for you, but apart from that it was perfect.
BillB
Martin Walker wrote:Oh, and I just remembered that I wrote this for SOS yonks ago - it might just contain something relevant to your desires Tony ;)
Thanks Martin, that article jogged my memory about certain techniques, I used to use the PSP Vintage Warmer on a lot of my previous CD's, along with a plug-in called Wow and Flutter, that was on my old XP machine, which I no longer have, I really would like the PSP back again, it's a really great plug-in, and I think it could help me with this problem.
Listening back to a few tracks with PSP on them, they really do sound very nice, not OTT, just nice.
