Cable inventory
Cable inventory
Post by baward »
After about 100 years of pretty randomly plugging stuff in and scrabbling around on the floor to find out what might be inserted where, I thought it is time to properly organise my input cables. Even though I don't have tons of gear, I have about 18 channels of analogue input that I regularly use. Even though I can see the clear benefits of a patchbay, I am not using one at present.
I've got as far as keeping tabs with paper and pencil as to what's what, but I wonder what other folk use? I've recently bought a Mr-Label system, although I am yet to implement it.
Thanks!
baward
Posts: 431 Joined: Tue Feb 04, 2003 12:00 am
Re: Cable inventory
Post by Bob Bickerton »
I use a tape labelling system around the connectors which is colour coded by length. So “20 Blue” would be number 20 of a 5m length.
It gets a little confusing because I have long and short 5m lengths ;)
Bob Bickerton
Posts: 5637 Joined: Fri Dec 20, 2002 12:00 am Location: Nelson, New Zealand
Re: Cable inventory
:headbang: I have long and short memory lengths these days but, sadly, they aren't colour coded......
Re: Cable inventory
Post by nathanscribe »
The most colourful thing in my studio is the language I use while trying to untangle a heap of all-black cables with identical jacks on each end.
I did make a couple of looms with electrical tape of different colours and patterns on the jacks. Even just using a couple of colours (for, say, left and right) and then writing on it with permanent marker is better that nowt.
nathanscribe
Posts: 1566 Joined: Fri Jan 19, 2007 12:00 am Location: Wakefield, for my sins.
Re: Cable inventory
More years ago than I care to remember XLR cables were ID'ed with tape as per the resistor colour code, e.g Brown/black was 10mtrs Red/black 20mtrs. They were plugged together and wound up on Kmal drums.
Because PVC tape goes sticky and peels it was protected by clear heat shrink. The plugs also had Blue HS over the plug rear. This stopped the then Cannon clamp screws coming out but was mostly to ID OUR cables and stop the BBC and ITV blokes from 'mistaking' them for their own!
Of course, the system would not work today because I doubt one in 10,000 readers of this and other audio forums have ****** CLUE what the resistor code is!
Re: Cable inventory
Used to know, but haven't needed to for at least 25 years so, funnily enough, it hasn't stuck! :)
Re: Cable inventory
At a push I think I could remember (learned it at my pappy's knee don't-cha-know) but on the rare occasions I build anything I look it up to check I'm right :blush:
Re: Cable inventory
I'm so steeped in this now that when I see any of the preferred values I instantly think the complete number, not the colour band values. For other values, I'll think something like 2, 5, k rather than red, green, orange
Posts: 20880 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Re: Cable inventory
I guess it's a bit like reading music, see the code/dot on the stave and think the number/note?
Re: Cable inventory
Oh yes Drew, 'use it or lose it' !
It is so burned into my hind brain like Will that I doubt I shall ever forget it. What defeats me is the 'weeness ' when I cannot resolve the colours and the 'new' four band system banjaxes me! I just keep my trusty Fluke handy.
Tell what IS tricky for old electronics techs? Snooker scoring!
Re: Cable inventory
As a beginner I used to think 'why bother when you can use a meter to find the value' but, in my later teens as I amassed more components I realised that it was much easier to learn the code rather than find the meter every time I wanted a resistor. Fortunately Practical Wireless included some handy cards free with one issue around the same time that featured the resistor colour code.
Posts: 16988 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Re: Cable inventory
Post by ManFromGlass »
I don’t build many diy projects so the internet would be my place to find resistor values when needed.
As for cable labeling (and I think there is another thread here somewhere with some good alternatives) I tried those small sticky numbers. But being older I found by the time I traced a longer cable I forgot what the number was on the other end. One day when I’m so inspired I will give the cables people names on both ends. So I will know that "Fred" connected to the ribbon mic is connected to mic pre #2
Re: Cable inventory
I like that idea. :)
In the shop in Amsterdam we named all the tools (it started with a Stanley knife). We decided that all screwdrivers were called Eric; our two most used ones were red and blue so you'd here comments across the floor like, "lob me Eric the Red please Bert."
I don't if they wete simpler times or if we were just simple... ;)
Re: Cable inventory
Or the fact that you were 'in Amsterdam'. ;)
Re: Cable inventory
Post by Moroccomoose »
I haven't used the resistor code since A levels! But isn't it just the rainbow...Richard Of York Gave Battle In Vain...With Black and Brown tagged on the front and white on the end, Black being 0 and white 9. Last colour is number of zeros?
Then the tolerance band.silver for 10% and gold for 5%....
Didn't google, honest!
Did I pass the test Dave?
Moroccomoose
Posts: 568 Joined: Tue Apr 12, 2011 12:00 am Location: Leicester
Re: Cable inventory
Moroccomoose wrote:I haven't used the resistor code since A levels! But isn't it just the rainbow...Richard Of York Gave Battle In Vain...With Black and Brown tagged on the front and white on the end, Black being 0 and white 9. Last colour is number of zeros?
9/10
There is no Indigo, instead grey is 8.
There are two more tolerance colours these days Red (very common) and Brown
Having Red as a tolerance band can make it quite difficult working out the value when some manufacturers don't put the required gap between this and the value bands :protest:
Re: Cable inventory
9/10
Yeah, could not get on with the 'new' system at all, just slapped them on a meter
Was not aware of that nemonic Mo'. Why would anyone need to know the colour sequence of the rainbow?
Re: Cable inventory
Probably to work out resistor values? :smirk:
Mine was Roy G Biv
Re: Cable inventory
Sam Spoons wrote:Probably to work out resistor values? :smirk:
Mine was Roy G Biv
Oh. You knew him too :lol:
Re: Cable inventory
Post by Kwackman »
I learnt "Black Beetles Running On Your Garden Brings Very Grey Weather".
I think it originally was ".....Good Weather", but "Grey" meant one colour less to remember!
Kwackman
Posts: 3686 Joined: Thu Nov 07, 2002 12:00 am Location: Belfast
Re: Cable inventory
blinddrew wrote:Used to know, but haven't needed to for at least 25 years so, funnily enough, it hasn't stuck! :)
Even after 50 years, I still remember my weird mnemonic (no idea where it orgininated):
Bye Bye Rosie, Off You Go, Birmingham Via Great Western
However, like Will I see most common resistor values as a whole without having to decode their individual colour stripes ;)
Posts: 22574 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
