vst (plugin) host with side chain capability?..
Post by Gadg3ts »
I'm 90% sure this was in a review or article in the magazine within the last year, but I can't find it...
Basically, what I'm looking for it the name of a bit of software that will host VST plugins, but also it was described as being able to "expose the side-chain connections of VST3 plugins" or allowing funky routing to do the same thing with multi-in/out plugins.
I do primarily use Cubase for bigger projects, but that's tied to one PC.
The thing I'm looking to do is get a feed for the sidechain signal for the Brainworx bx_DynEQ, but from a different audio channel and in DaVinci Resolve, the video editor from BlackMagic (and on my laptop, so preferably not needing an ilok/eclicenser) .
I've had a look at Nugen Sigmod, which has a 'signal tap' function, but this only feeds to another proper channel. I've also looked at BlueCat PatchWork, but that's a bit inscrutable without having to RTFM.
Does anyone recognise the thing I'm talking about and know what it's called?..
Thanks,
Sean
Gadg3ts
Posts: 7 Joined: Thu Oct 20, 2005 12:00 am
A/V, Tech and Studio Services: gongbong.media
Custom Volca Cases: pimpyourvolca.com
Re: vst (plugin) host with side chain capability?..
Cubase makes VST3 side-chaining easy, but I'm pretty sure Reaper can do it too - and that would be a cheaper option for multiple PCs.
Hopefully others can confirm.
Post by n o i s e f l e ur »
Is it this, reviewed in this months mag?
https://www.soundonsound.com/reviews/ddmf-metaplugin-3
I believe the trick referred to is the ability to easily sidechain (sidechainable) VST2 plugins, as VST3 has it in spec no?
n o i s e f l e ur
Posts: 424 Joined: Sat Aug 04, 2018 6:20 am
n o i s e f l e ur wrote:Is it this, reviewed in this months mag?
It could well be, and DDMF have some really creative products in their range that work well - Metaplugin works beautifully for a host of uses.
I've also used it in the past to test out different rates of oversampling on various plug-ins - everything you host inside it can be run 'as is' or with x2 or x4 oversampling (watch that aliasing distortion drop off the graph!)
Post by Gadg3ts »
Yes! that one
"Cubase users might be interested to note that Metaplugin... coupled with SendIt... can grant you access to side‑chaining with VST2.4 compressors and gates."
The sendit thing is what I was looking for.
If I were doing this in Cubase or Reaper (both of which I use a lot), then the process would, of course, be easier, but I'm not, so it isn't. I might add this to my feature requests to BlackMagic, as Resolve makes other things like ducking for voiceover tracks really simple.
Ironically enough, I'd put a sticky tab in the actual magazine so that I could find the article again...
Thanks people :)
Gadg3ts
