The insecurity of small waveforms on your DAW
To achieve a cleaner sound with less risk of peaking, I took the advice of folks here, and now I always record at high bit rates and use -12dB as my peak reference, right through the system.
However, I think it must come from my analogue recording days, when I always used to keep the level up as high as possible, to avoid noise, and now the waveforms on my screen are pathetically small, it makes me feel insecure, and then going in and increasing the levels or normalising things just doesn’t feel right, as I’m obviously "throwing away" bits.
It all sounds fine, it’s just that I can’t put my confidence in high bit rate recordings, I’ve always been used to big healthy levels, and this just feels like it’s going against the grain.
I still record to tape now and again, and it’s a big relief, the meters actually become sort of irrelevant! and I have to use my ears to either achieve a clean sound, which isn’t the point, as I always use tape when I need a colouration, or a nice distortion, it seems a much more intuitive way of recording, and unlike digital, the results are very varied, and distortion is controllable and progressive.
Digital is great we all know that, but it still makes me feel insecure, it’s like recording into an invisible intangible medium.
Re: The insecurity of small waveforms on your DAW
What's your DAW?
In Cubase there's a slider type control to increase/decrease the size of the waveforms.
I use it for the same reason you give.
I guess other DAWs may have this option too?
Kwackman wrote:What's your DAW?
That’s an idea, I’m on Reaper, I can make the tracks bigger, but I’ll have to investigate the waveforms.
PS!
Done it! Shift plus ^ on Reaper, and it doesn’t alter the audio level.
There are two things you can do on Reaper to help, one is to extend the meter scale, the other is to change the render of the waveform. They're both explained on another recent thread, I just have to go away and find the link now.
blinddrew wrote:There are two things you can do on Reaper to help, one is to extend the meter scale, the other is to change the render of the waveform. They're both explained on another recent thread, I just have to go away and find the link now.
Drew, I’ve done it, Shift plus ^ does it.
Interesting comments....... just imagine how insecure you'd feel if you'd started off with digital with all the information, and visual feedback it offers and then have to work with tape!
- Bob Bickerton
Longtime Poster -
Posts: 5642 Joined: Fri Dec 20, 2002 12:00 am
Arpangel wrote:blinddrew wrote:There are two things you can do on Reaper to help, one is to extend the meter scale, the other is to change the render of the waveform. They're both explained on another recent thread, I just have to go away and find the link now.
Yep, that increases the size of the waveform but if you have some very different (or very dynamic sources) it can render somethings into a block (or other things shrink).
Fortunately there are a couple of other things you can do (courtesy of James P!
1) extend the default level of the meters so that they go from -96 to +12 rather than -62 to 12. Which just makes your levels look proportionally larger.
Options > Preferences > Appearance > Track Control Patterns > then change the minimum value in the VU meters section.
2) change the waveform view from a linear display to a logarithmic display. To change this setting go to the actions menu, click on actions list and then search for Peaks:scale peaks by square root (half of range is 12dB rather than 6dB).
Bob Bickerton wrote:Interesting comments....... just imagine how insecure you'd feel if you'd started off with digital with all the information, and visual feedback it offers and then have to work with tape!
Now that’s a massive can of worms, the "committing ideas earlier to tape" worm, the "getting too involved in digital editing" worm, the "believing your eyes more than your ears" worm, to name just three...
Yes, Samplitude has two +&- zoom controls at the extreme lower right hand edge of the track scene. Reaper has similar but it is B hard to see on 15.6" screen! These can expand the waveform in both X and Y directions.
Adobe 1.5 also has a waveform zoom function but it is a bit of PITA to find and use. Later versions might be better.
If you think about it, all DAWs must have this function else how could you put 50 tracks on even quite a large screen?
ef37a wrote:Yes, Samplitude has two +&- zoom controls at the extreme lower right hand edge of the track scene. Reaper has similar but it is B hard to see on 15.6" screen! These can expand the waveform in both X and Y directions.
Yes, I can make "tracks" big or small using those + and - buttons on the screen, but also, using shift and ^ just expands selected waveforms within the track.
As said above, it’s just a visual reference... I only care about it for editing. When I’m done editing I normally reduce track size to nearly the minimum, so I’m always seeing waveforms as a small black line, or even nothing if I have it to the minimum (Cubase)
- ore_terra
Posts: 1090 Joined: Fri Dec 02, 2016 12:56 pm
casmoestudio.com
Arpangel wrote:However, I think it must come from my analogue recording days, when I always used to keep the level up as high as possible...
But because analogue meters never revealed the available headroom, you really weren't 'recording as high as possible' at all. You still had 10-12dB of headroom even when you'd pinned the VU meter to the end stop. It's a constant frustration that so many people either don't understand this, or have forgotten it!
...now the waveforms on my screen are pathetically small, it makes me feel insecure
Yes, I get that... but a decent DAW will let you boost the amplitude of the waveforms precisely to overcome this 'problem'. Some also provide one or more (very useful) logarithmic display options to maintain a sensible waveform with very dynamic material, so you can still see the quiet bits without blocking out the loud bits. SADiE, my recording and editing DAW of choice, offers eight different waveform display algorithms.
...going in and increasing the levels or normalising things just doesn’t feel right, as I’m obviously "throwing away" bits.
The only thing you're throwing away by normalising/gain boosting is headroom at the output and in the monitoring... although working with higher internal levels might also affect the operation and character of modelled vintage-style plugins.
However, since all DAWs operate in floating-point internally, there won't be any overloads or clipping within the mix itself... but it really does make life a lot easier if you can maintain normal headroom margins when mixing by persuading the DAW to display the waveforms in a more practical way!
I can’t put my confidence in high bit rate recordings...
If you're talking about a linear PCM digital audio signal, a 'high-bit rate' is synonymous with a high sample rate -- 96kHz, 192kHz, or whatever. Or, if you're talking about the output from a lossy codec, a 'high-bit rate' equates to the least efficient, but also the least damaging coding format. Lossy codecs exists to produce the lowest bit-rate possible...
As Eddie points out below (and I've edited this to add it for completeness) you're probably thinking of 'bit depth' or -- more correctly -- word-length meaning the number of quantising bits employed per sample (16, 24, etc). In the context of your comments, it would make sense to be referring to recording with a long word-length of 24 bits.
That's because you're letting your eyes determine what you hear!
...unlike digital, the results are very varied
One of the reasons the industry moved wholesale into digital!
Last edited by Hugh Robjohns on Thu Jan 16, 2020 11:03 am, edited 2 times in total.
Posts: 43701 Joined: Fri Jul 25, 2003 12:00 am
Hugh Robjohns wrote:]
Yes, so did I, it was a revelation, and for my music, personally, or for anyone that made quite dynamic recordings, classical, and quiet, ambient style music...no hiss!
It was at a time when distressing and coloration were yet to become popular as a creative tool, in the way they are today, and cleanliness and transparency were the order of the day.
Because it was all new to us, a new sound, creatively digital enabled us to do many more things, that would have got lost in the analogue soup.
Not being a Trump Tone but it's bit depth not bitrate.
Ah yes. That makes a lot more sense -- well interpreted Eddie!
24 bit recordings have a long 'word-length', or a large 'bit-depth'...
Speaking as one who has suffered from these delusions in my past... most people feel that they have an understanding of digital audio right from the off. It is only when you realise that you don't understand it as well as you thought you did that you begin to get a real understanding!
I move in circles where I still see the dreaded stepped waveform drawn and the word 'resolution' used a lot. Unfortunately many people find these 'intuitive' concepts more comfortable to cling to than the reality.
And yes, the 'thin waveform' and 'wasted bits' are part of that world...
The Elf wrote:I move in circles where I still see the dreaded stepped waveform drawn and the word 'resolution' used a lot.
Tell me where they are...we have a dedicated troop of SOS 'Education' Ninjas primed and ready to 'deal' with these people...
Last edited by Hugh Robjohns on Thu Jan 16, 2020 11:39 am, edited 1 time in total.
Hugh Robjohns wrote:The Elf wrote:I move in circles where I still see the dreaded stepped waveform drawn and the word 'resolution' used a lot.
I'll refrain from naming and shaming, but we're not talking primary schools!
One day I'll tell you about my method for teaching about dithering!
Some of my friends are analogue hifi nuts. We were talking about Jeff Wayne's War of the Worlds recently, and the subject of the tapes shedding and having to be baked and transferred to digital... "it's good they're preserved but they'll have lost that analogue air now". I know I ought to educate such obvious bullcrap, but I just can't be arsed!
- Rich Hanson
Frequent Poster - Posts: 3686 Joined: Sat Sep 06, 2003 12:00 am Location: Sort of near Rochester, Kent, UK
The Elf wrote:Speaking as one who has suffered from these delusions in my past... most people feel that they have an understanding of digital audio right from the off. It is only when you realise that you don't understand it as well as you thought you did that you begin to get a real understanding!
I don’t understand it at "all" it’s all magic to me, I just use words that I’ve heard others as I try and muddle through. As long as digital audio works, that’s enough, it’s when it doesn’t that I start to get a bit panicky. Analogue I sort of understand, quite well, it’s easier to get my head around, and I can normally hear things that are happening or malfunctioning and identify them, not so with anything digital.
Wonks wrote:The Elf wrote:I move in circles
Try moving both legs instead of just one. It helps.
Have you seen the size of the toadstool?!
Sent from my iPhone using Tapatalk
Rich Hanson wrote:Some of my friends are analogue hifi nuts. We were talking about Jeff Wayne's War of the Worlds recently, and the subject of the tapes shedding and having to be baked and transferred to digital... "it's good they're preserved but they'll have lost that analogue air now". I know I ought to educate such obvious bullcrap, but I just can't be arsed!
Yes and no. Analogue tape is a wonderful thing. Esteemed audio engineer Tony Faulkner once said that the very best recorded audio he ever heard was a master tape straight off the Studer A80 in the control room. There is also the generational factor: to those of us who grew up on vinyl and tape, analogue just sounds 'right'. Never mind that the specs are better for digital; it is cleaner, more accurate, and vastly easier to manipulate in recording, mixing, and mastering stages...it just doesn't sound analogue no matter how many vintage plug-ins you use. So I'm not disagreeing with you, I'm just sayin'
- jimjazzdad
Regular - Posts: 310 Joined: Sun Dec 15, 2013 12:00 am
Halifax, NS, CANADA
jimjazzdad wrote:...it just doesn't sound inaccurate in the way that I like no matter how many vintage plug-ins you use.
FTFY...
Just tell them that there's a secret formula added in the oven during the baking which ensures that the air is retained during recording.
If they swallow that, you can tell them that it also leaves the audio strawberry flavoured....
