bare bones interface with emphasis on converters?
For my purposes, Ableton plugins are fine. I don't need to run something like UAD plugs on an Apollo. Is there a bare bones two-channel interface with quality converters? Want to spend my money on the converters, and not all the bells and whistles like the Apollo.
Running 2015 MacBook Pro.
Thanks in advance.
Thanks in advance.
- whoateallthechips
New here - Posts: 4 Joined: Fri Jan 17, 2020 6:14 pm
Re: bare bones interface with emphasis on converters?
Apogee Ensemble 24.....not as good as the above Lyra but superb for the money with tight integration with Logic in terms of controlling preamp and direct monitoring.
- fatbenelton
Frequent Poster - Posts: 708 Joined: Thu Aug 22, 2002 12:00 am Location: Liverpool, UK
Jonny
fatbenelton wrote:Apogee Ensemble 24.....not as good as the above Lyra but superb for the money with tight integration with Logic in terms of controlling preamp and direct monitoring.
Sorry, I meant the ELEMENT 24!
- fatbenelton
Jonny
Sonosax SX-M2D2
Merging Technologies Anubis
RME ADI-2 FS
RME ADI-2 Pro FS
RME ADI-2 Pro FS R Black Edition
Or, for a lot more i/o and flexibility perhaps try a Merging Technologies Hapi It has it's issues but the sound quality of the Merging kit (or the Sonosax) is about as good as it gets at the moment.
RME ADI-2 FS
RME ADI-2 Pro FS
Last edited by forumuser840717 on Sat Jan 18, 2020 1:53 am, edited 3 times in total.
- forumuser840717
Regular - Posts: 485 Joined: Thu Jun 16, 2016 5:20 pm
fatbenelton wrote:fatbenelton wrote:Apogee Ensemble 24.....not as good as the above Lyra but superb for the money with tight integration with Logic in terms of controlling preamp and direct monitoring.
Would the Element's converters be noticeably better than the Apollo Twin?
- whoateallthechips
Perhaps but more realistically on a par or not noticeably better in most circumstances. To be fair the apollo are supposed to be very good.
- fatbenelton
Jonny
whoateallthechips wrote:For my purposes, Ableton plugins are fine. I don't need to run something like UAD plugs on an Apollo. Is there a bare bones two-channel interface with quality converters? Want to spend my money on the converters, and not all the bells and whistles like the Apollo.
Thanks in advance.
Nothing wrong with aspiring to the best converters provided absolutely everything else in your recording chain is top notch and you have fantastic monitoring in a professionally designed acoustic space - otherwise - most decent gear, including Apollo, will have converters that you are unlikely to be able to differentiate from top end converters costing many times more.
- Bob Bickerton
Longtime Poster -
Posts: 5641 Joined: Fri Dec 20, 2002 12:00 am
Bob Bickerton wrote:whoateallthechips wrote:For my purposes, Ableton plugins are fine. I don't need to run something like UAD plugs on an Apollo. Is there a bare bones two-channel interface with quality converters? Want to spend my money on the converters, and not all the bells and whistles like the Apollo.
Thanks in advance.
I’m still trudging through the learning curve on converters and signal chain. Presuming decent mic and room treatment, which do you think would be most biggest improvement:
1. Run a 500 series (looking at Neve 511 or API 512c) preamp into my existing Scarlett 2i2 at line level (not true bypass, but brings down the color of the internal pre a bit).
2. Apollo Twin. Its preamps are supposed to be better than the 2i2, and I believe you can completely bypass its internal preamps if using an external pre.
- whoateallthechips
whoateallthechips wrote:Presuming decent mic and room treatment,
You mean you have a bunch of vintage Neumanns and AKG's at your disposal?
Performance is the most important part of any recording with acoustics second and mic choice third. Mic preamps and convertors come well down the list of priorities. If you are recording yourself then the question to ask is what is getting in the way of you giving a great performance? Yes, an unreliable interface which drops out regularly might be a factor but the interface sound quality is unlikely to be an issue.
Posts: 16991 Joined: Mon Sep 10, 2001 12:00 am
Quite!
- Bob Bickerton
Longtime Poster -
Perhaps you could explain the reasons for wanting a very high end converter. Is the converter the current weak link? In what area(s)?
- Tim Gillett
Frequent Poster - Posts: 2707 Joined: Wed Jan 30, 2013 12:00 am Location: Perth, Western Australia
Remember that the “interface” is simply the part that translates the digit audio signal into an usb (or thunderbolt or whatever computer-based protocol) data stream.
The average interface offers pre amplification and AD conversion but it’s only a useful packaging, not mandatory.
So if you want the best possible conversion, it may pay off to use a separate box and simply connect it to any interface which accepts the digits audio protocol produced by that box.
That said, I very much subscribe to what others have said, the couple meaningful bits that you can squeeze from top converted with respect to your run of the mill ones aren’t likely to make a huge difference unless you work In a top space and a very good chain.
From personal experience, the Apollo is a distinct class above the Scarlett, so is the Clarett for that matter, both in terms of "quality" of the sound, and - at least for the Apollo - in the richness of the feature set.
Plus the Scarlett ain't got no street cred.
- Watchmaker
Frequent Poster - Posts: 1319 Joined: Wed Apr 13, 2016 12:00 am Location: Upstate NY, USA
Where does sound exist?
Watchmaker wrote:From personal experience, the Apollo is a distinct class above the Scarlett, so is the Clarett for that matter, both in terms of "quality" of the sound, and - at least for the Apollo - in the richness of the feature set.
Interesting how post above yours says higher end converters don’t make much difference.
- whoateallthechips
Yes but the differences most likely come from the preamps not the convertors (and even the preamps in modern kit make very little difference if used appropriately).
https://www.soundonsound.com/reviews/pick-preamp
They don't make much difference... It's a case of diminishing returns and you have to spend increasingly large amounts to get decreasingly small improvements -- and improvements that you can only perceive with the very best of monitoring conditions and equipment.
If you're looking to improve the quality of your recordings, the priority list is the recording room acoustic, the position of the mic, the type of mic, and the mic preamp, in that order... And that's assuming the source is a quality instrument being played skilfully. The converter quality plays a very small role in the overall sound.
So it largely depends on what your budget is, and what the rest of your system comprises (including the room acoustics), as well as what you're trying to achieve.
I say that because while most interfaces and converters are designed to be as accurate and neutral as possible, some are designed to intentionally add some colour or character. the latter is fine for an A-D stage because everyone gets to hear whatever they add, but a colourful D-A is not clever as only the users gets that flavour and everyone else hears something else... Which might not be such a clever idea!
And as mentioned above, the very best converters are often standalone designs, rather than integrated into computer interfaces.
Hugh Robjohns wrote: And as mentioned above, the very best converters are often standalone designs, rather than integrated into computer interfaces.
My personal preference is to separate the audio interface from the convertor. That way you can use the interface with the best driver support while going for the convertor that sounds the way you want it to.
The new SSL offering looks very tempting.. especially at the price
https://www.solidstatelogic.com/interfaces
Last edited by Chevytraveller on Sun Jan 19, 2020 9:53 pm, edited 1 time in total.
- Chevytraveller
Frequent Poster - Posts: 948 Joined: Sat May 13, 2000 12:00 am Location: Hastings
Soft: MBP 15", X-Station, LogicX, Mainstage 3, Korg legacy, Diva, Alchemy, FabFilter.
Hard: Mostly now all for sale.. but Akai MPC Live, Tasty Chips Gr-1, Roland Promars, AS Telemark, Eurocrack disease
