A Long List of Compromises - new music space
Re: A Long List of Compromises - new music space
Post by jaminem »
blinddrew wrote: Firstly, in larger control rooms the rough rule of thumb is to aim for 1/3rd of the surface area reflective, 1/3rd absorbent, and 1/3rd diffusive.
Cool, ok. I guess my point is coming from the fact that I've been in and out of a lot of facilities and the only place I have seen that amount of absorption concentrated in that sort of area is in mastering rooms (where its hidden behind fabric) but you sound like you're on top of things, so I hope it goes well for you!
jaminem
Posts: 1536 Joined: Mon Mar 19, 2001 12:00 am
Ha! I hope so. :)
The proof will be in recording but I have done quite a bit of research and maths based on a couple of books recommended by the good Dr so I'm hopeful.
What is immediately obvious is that i will need to dampen all the strings on any unused instruments. Once you start reducing the room echoes these other resonances become very obvious.
Posts: 29679 Joined: Sun Jul 05, 2015 12:00 am Location: York
Post by ManFromGlass »
Then after that you have to tame all gurgles and other rumbles, so no curry or beans the day before a session!
I like the look - almost like your own private holodeck Cap’n Jean Luc Drew!
Posts: 7848 Joined: Sun Jul 24, 2011 12:00 am Location: O Canada
We have matching hairstyles! :)
Quick trip to Gear4music and they swapped the runner over for me - the advantage of buying locally. :)
So this evening I set the desk up and that end of the room is looking a bit more like a studio and a bit less like a building site! :)
If that is your final or almost final setup then I see you are wrestling with the same issues I am. You need access to the mouse when playing the controller but also when the controller is tucked away and you are mostly using the computer keyboard.
For me the constant is the mouse but I constantly go between controllers and computer keyboard.
I have almost found a non-crippling (not too much reaching so I can keep good posture etc) setup but am always curious what others are doing.
ManFromGlass wrote:If that is your final or almost final setup then I see you are wrestling with the same issues I am. You need access to the mouse when playing the controller but also when the controller is tucked away and you are mostly using the computer keyboard.
My approach is to have my main controller keyboards down each side of the studio (5-octaves synth ones stacked on the left, and 88-key weighted piano-style on the right) , and in then front of me I have a 2-octave keyboard for basic editing and the odd solo, with my PC keyboard directly in front and the mouse alongside.
Posts: 22568 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
Shouldn’t the whiskey, I mean, inspiration glass be more front and centre? :mrgreen:
Post by Music Wolf »
Look which side the mouse is on!!!! Or should that be Witch side the mouse is on?
Music Wolf
Posts: 2894 Joined: Fri Feb 17, 2006 12:00 am Location: Exiled to St Helens
I did notice that and thought, "ah, MW is of a 'sinister' persuasion" :D
Posts: 22870 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
I may end up moving the music keyboard to the left hand side and dropping the computer keyboard to the tray. But I haven't got room for that at the moment so I'll play around with things and see how it works.
Anyway, today was quite productive.
Aluminium strips for a bit of reflection:
Lightly stuffed with old duvet:
Bit more duvet wedged into the front top and bottom and then finished with cara:
The rest of the afternoon was spent with a surform plane working on what will be the other diffusion boards.
I might take tomorrow off...
Sam Spoons wrote:I did notice that and thought, "ah, MW is of a 'sinister' persuasion" :D
I'm ambidextrous with a mouse, and that glass contains sparkling water to keep me hydrated during long sessions ;)
Anyway, let's not stray too far from Drew's magnum opus (and I'm not talking about a choc-covered ice cream)
Hmmm... ice cream...
Thinking of being ambidextrous with a mouse, i did find myself using two at once at work on Monday (one on the Mac, one on the pc).
Not for anything particularly demanding, but it did impress a passing colleague. :)
Music Wolf wrote:Look which side the mouse is on!!!! Or should that be Witch side the mouse is on?
Banjo player burning, 16th Century style. They didn't mess about in those days.
Posts: 19204 Joined: Thu May 29, 2003 12:00 am Location: Freethorpe, Norfolk, UK
Last group of photos showed a squeezebox and an unsolved Rubics cube.
Both torture devices in the wrong hands
What do you think the padding on the wall is really for?
Only slightly related to torture -
Is this worse than actors miming be able to play guitar on tv? Two bagpipers on tv who have the mouth moves correct but couldn’t make their fingers mime Amazing Grace in time.
Sure, sure, blame the picture editor!
Post by MOF »
I wish that editors would re-synch archive footage used in music documentaries, which is usually out by about two frames for some reason.
MOF
Posts: 2575 Joined: Thu Mar 06, 2003 12:00 am Location: United Kingdom
and quite a number of old movies too. Hard to watch that stuff.
While it's sadly all too common to see out-of-sync material from the source, it's worth bearing in mind that sync errors can also be caused by the viewing equipment, particularly if you take audio from a TV to reproduce via a hifi system or external 'sound bar' as so many do.
Some systems -- either the sound system or the TV itself -- will include facilities to delay the audio to match the inherent delays of the visual display, but not all do, and even if they do, not everyone is aware of the feature or how to adjust it!
Posts: 43663 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Does anybody know of an app/plug-in that can do the same with Youtube?
I find some Amazon programs drift out of sync after a while. I have to exit the program and resume watching to get it in sync again. Never found that with Netflix.
Wonks wrote:I find some Amazon programs drift out of sync after a while. I have to exit the program and resume watching to get it in sync again. Never found that with Netflix.
Until about a year ago I had a TV that I bought in 2008. When watching pretty much any streaming content the audio would drift out of sync with the video and occasionally I'd get weird distortion on it as well. The solution to the distortion was to pause for 30 seconds, but the sync issue never went away.
Got a new TV early last year (a cheap but nice non-smart thing, as I use external devices for the smart part) and both problems went away and haven't re-occured, so maybe it would be worth trying a different TV if yours is getting on a bit?
Posts: 9961 Joined: Wed Sep 01, 2004 12:00 am Location: Brighton & Hove, UK
It's a Sony and only 4 years old max. And it's only sometimes, and only on Amazon. Maybe it's the app on the TV, though I do try and check for software updates about once a month.
It's usually the decoding software which loses track of the time stamping between the audio and video streams, and often because of a change to the encoder software intended to 'improve quality'.
So a TV software update will often fix it, but only if software updates are still being generated for that specific TV. Panasonic seem very poor at supporting their TVs once they're more than about 5 years old... :(
