MIDI 2.0!?
Re: MIDI 2.0!?
Yamaha had their PS/2 port style, 1 cable MIDI. Did that have much impact on equipment or was it just Yamaha ?
Posts: 4761 Joined: Sun Aug 12, 2018 2:40 pm Location: British Isles
Re: MIDI 2.0!?
Post by DGL. »
N i g e l wrote:Yamaha had their PS/2 port style, 1 cable MIDI. Did that have much impact on equipment or was it just Yamaha ?
Wasn't that a serial (either RS-232 (PC) or RS-422 for MAC) 'host' connector, 8 pins, quite a few manufacturers used that connection. My Korg 05R/W has this connector.
The only use of PS/2 connectors I know of for MIDI was the front panel sockets on the Creative Audigy PCI cards.
DGL.
Posts: 2212 Joined: Fri Oct 28, 2011 12:00 am Location: Portland, Dorset
Re: MIDI 2.0!?
All the Reface's have a PS/2 connector for MIDI. They do come supplied with an in/out breakout cable.
Thats the only thing ive got that's single cable.
image is click-able & zoom-able....
Re: MIDI 2.0!?
Post by DGL. »
N i g e l wrote:All the Reface's have a PS/2 connector for MIDI. They do come supplied with an in/out breakout cable.
Forgot about the Reface series (despite having their PSS cousin), though the way they work is different to what creative had in teh fact that creative didn't combine the two in/out connectors in to one PS/2 style using one for each, I guess, using the same pinout as an AT-PS/2 keyboard adaptor.
DGL.
Re: MIDI 2.0!?
The Elf wrote:They didn't need to time travel to see the benefit of a bi-directional cable. MIDI was based on RS232, which was itself bi-directional. The pins were sitting there waiting to be used. It could have solved us all this two-cable mess we ended up in - and the difference between 'in' and 'out' seems to baffle many people - myself included on occasions!
I think having seperate cables allows for a chain configuration, perfectly acceptable in the 80's, although because the electronics are asymmetric (on THRU), there is a limit of 3 or 4 synth modules from a master keyboard before the data gets slewed and erronious
Re: MIDI 2.0!?
Post by muzines »
Yay for MIDI 2.0!
Now we'll be back to the days with endless articles on MIDI, with message formats, and type-in listings for your very own personal computer to experiment with the new-fangled MIDI byte things... :thumbup::clap:
muzines
Re: MIDI 2.0!?
Post by Agharta »
desmond wrote:Yay for MIDI 2.0!
Maybe we'll see a new Atari in time for MIDI 2.0! :D
I wrote a basic app for my Atari ST that created Philip Glass like riffs.
All very basic and probably written in BASIC! :thumbup:
Agharta
Posts: 4350 Joined: Sat Oct 30, 2004 12:00 am
Re: MIDI 2.0!?
Post by BigRedX »
The PS2 style port for MIDI seems to be a Yamaha thing. The Tenori-On has it too. Nothing special about the connector, just a compact way of getting enough pins for MIDI in and out in a pre-existing form-factor.
Personally I think MIDI should go back to using XLR connectors as originally intended. All these nasty non-locking computer style connectors are simply not robust enough for gigging use.
BigRedX
Posts: 2948 Joined: Fri Sep 03, 2004 12:00 am
Re: MIDI 2.0!?
BigRedX wrote:The PS2 style port for MIDI seems to be a Yamaha thing. The Tenori-On has it too. Nothing special about the connector, just a compact way of getting enough pins for MIDI in and out in a pre-existing form-factor.
PS2 is knocking on! XLR seems overkill and DIN is being dropped like a hot brick, mainly due to size and cost I would imagine? I do however agree that it is a superb connector.
My vote stays with RJ45. They are cheap enough that you can keep 1/2 doz spares. The latch is vulnerable but you can get special boots that protect it and stop it snagging and surely someone can come up with a snap on 2 piece ABS cover that has a button to push the latch?
I think the very LAST thing we need is yet another bloody connector!
Posts: 18533 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
Re: MIDI 2.0!?
It will need to be cheap, and not easily confused with anything else to avoid damage. So while the RJ45 makes the first requirement, it fails the second.
Perhaps RJ11s (telephone type) connectors would be a safer option? ;-)
I love the idea of XLRs for MIDI on gigging equipment, but that fails on both counts and it's bulky, so perhaps mini-XLRs would be okay, although the expense probably rules them out too.
Posts: 42816 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Re: MIDI 2.0!?
Post by BigRedX »
ef37a wrote:PS2 is knocking on! XLR seems overkill and DIN is being dropped like a hot brick, mainly due to size and cost I would imagine? I do however agree that it is a superb connector.
The problem with RJ45 is not so much the connector (although even with the boot the latch is prone to failure and once that happens you find the connector no longer seats securely in the socket), but the type of cables associated with most of them.
Line6 have chosen to use RJ45 connectors and Cat5e cables to join their effects units and foot pedals together, and unfortunately IME they are simply not fit for purpose. Standard cables fail in less than a month of 2-3 gigs and rehearsals a week, and the expensive Van-Damme coilable cat5e cable lasted just over a years before it stopped being coilable, would not long lie flat and shortly after than failed. When I upgraded from a BassPod to a Helix I deliberately went for the floor unit so I was no long dependant on unreliable cables or connectors.
Computer cables and connectors are fine at home or in the office where they are rarely moved or unplugged, but in a gigging situation I have yet to find anything as robust as XLRs couple with high quality flexible screen cable.
BigRedX
Re: MIDI 2.0!?
The most reliable connectors I've come across are industrial ones.
Pros.
Screw terminal internally (so field repairable)
Excellent cable retention
Cons.
Not screened
Very Bulky
They are this type.
There is also a 6 pin version in the same footprint, but that doesn't come with screw terminals.
Posts: 20317 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Re: MIDI 2.0!?
Hugh Robjohns wrote:It will need to be cheap, and not easily confused with anything else to avoid damage. So while the RJ45 makes the first requirement, it fails the second.
Don't understand "not easily confused with anything else"? ALL XLR tend to look the same and they can be one of a dozen plus mics, lines, AES or, as some would have it MIDI!
RJ11?!! Wee and very fiddly (and might be confused with the pub's master socket?)
Cables? I have found UTP patch cable (not solid core) to be pretty robust and I again point out that this stuff is cheapo! Look upon the cables as a rather consumable item?
I don't gig so this is just my experience knocking about with the stuff but there has to be some sort of connector and the choices are limited. The metal bodied, locking 'B' DIN seems to have all but disappeared? Mind you, making up DIN cables is not for the 55plus!
Re: MIDI 2.0!?
Im not keen on latching connectors, when I trip on a cable, I want it to come out rather than drag the equipment off the desk/chair/amp !
:headbang:
The majority of future MIDI connectors will probably be USB C ? Laptop/phone/etc direct to equipment.
My cameras manufacturer has so much confidence in USB C that they provide a plastic widget that clicks into the body and acts as a support for the connector.
Re: MIDI 2.0!?
been a hot debate ever since kit was made Nige'. Do you protect against an accidental shut down or having a 50W valve head on yer bonce?
Many would say you should not run cables where/so as they can be tripped over?
Re: MIDI 2.0!?
ef37a wrote: Many would say you should not run cables where/so as they can be tripped over?
Many haven't played arse-end pubs with one working plug socket on the other side of the pub.
Oh and you can't unplug the tv next to the stage because people will be watching the football later on... (true story) :headbang:
Posts: 28849 Joined: Sun Jul 05, 2015 12:00 am Location: York
Re: MIDI 2.0!?
The MID 2.0 spec, as far as I know, defines the protocol but says nothing about the physical connectors so I suspect unless the manufacturers come to some agreement on that aspect of things there may be various physical connection types.
One would hope that they standardise but we'll see. I haven't checked any of the updates lately.
I am quite excited by the prospect of MIDI 2.0 however, to the point where I'm considering researching the technical aspects of implementing my own VSTs in native code as I really want to create my own MIDI plugin for performance and jamming purposes and 2.0 looks to provide an extremely rich environment for doing that.
Posts: 9736 Joined: Wed Sep 01, 2004 12:00 am Location: Brighton & Hove, UK
Re: MIDI 2.0!?
Done a lot of pubs in me yoof Drew (and you were never sure what the mains outlet would be. Kids got it easy these 13A days) but I take you point. However it will be YOU they sue if someone breaks their head!
Re: MIDI 2.0!?
I know, i'm older and wiser now...
Re: MIDI 2.0!?
Eddy Deegan wrote:The MID 2.0 spec, as far as I know, defines the protocol but says nothing about the physical connectors
.....or the electrics. MIDI 1.0 defined the electronics, as a current loop & frequency.
It would be nice if the MIDI 2.0 basic isolated connection ran a bit faster to get round the beat 1 bottle neck, especially as theres more than 16 channels now [!]
or is that 2020-30yrs thinking rather than thinking ahead to 2020+30yrs.
2050, it will probably be brain implants and AI by then !
Re: MIDI 2.0!?
Post by arkieboy »
There's lots of good stuff in here from my brief reading of reports of the spec (note the caveats!) but it feels to me like the main point is to ensure that hardware doesn't just die in the face of AU/VST plugins. Bidirectional communication, interface profiles and the like will ensure your DAW can control and snapshot your entire rig from your keyboard and mouse. And its timely too - we're still in love with our hardware right now but give it five years without MIDI2.0 and I think we'd see hardware become niche.
Alternate controllers - like guitar - are well served by the update so naturally I'm looking forward to how it all pans out ...
arkieboy
Posts: 589 Joined: Thu Nov 07, 2002 12:00 am Location: Oxfordish
Re: MIDI 2.0!?
blinddrew wrote:I know, i'm older and wiser now...
Well, you got 50% right there. :D
Posts: 18710 Joined: Thu May 29, 2003 12:00 am Location: Reading, UK
Re: MIDI 2.0!?
Specific circumstances only. Limitations and restrictions apply. This statement is not a guarantee.
Re: MIDI 2.0!?
arkieboy wrote: Alternate controllers - like guitar - are well served by the update so naturally I'm looking forward to how it all pans out ...
one of the videos I watched was less than complimentary about the current MIDI over Bluetooth BLE, stating delays of >10ms, so I was wondering if they will bring out somthing better for the likes of keytars and jamstik type devices or even for phone interfacing ?
Re: MIDI 2.0!?
I'm looking forward to hardware/software that will declare the capabilities of old kit on its behalf to open it up to MIDI 2. Gotta be done!
Posts: 21247 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
