I want to buy some monitors for around 150-200 euro to test against my more expensive ones..i was thinking of studiospares n10..but does anyone know better choice??Also was thinking Yamaha HS50Ms
Thank you
Studio Monitors around 150-200 euro
Re: Studio Monitors around 150-200 euro
Presumably you mean 'compare with' rather than 'test against'?
In which case, Avantone Mixcubes should suit. They're designed to give you an idea of how your mix will sound on typical small radio speakers - while your proper monitors should give you a more accurate/hi-fi picture.
Other than that, I can't see the point in spending money on crap speakers when you already have some good ones.
- Evie McCreevie
Regular - Posts: 445 Joined: Mon Sep 06, 2004 12:00 am Location: Dublin
talktalk wrote:i wanted something along the lines of ns10"s
You won't get these now, well not new anyway! and if you do see them for sale anywhere, i.e. ebay they will not be in your budget that you mentioned.
Have a look at the M-audio Studiophile range
here
I've heard them mentioned on here a few times before and they may suit you.
Hope this helps
Please please do a search - there are at least 3 threads on this subject that are current, let alone the 8,943 earlier ones, all of which contain good relevant info.
Grumpety grump....had a late night.
- IvanSC
Frequent Poster - Posts: 3041 Joined: Tue Mar 08, 2005 12:00 am Location: UK France & USA depending on the time of year.
Two bottles of Corona lemon and lime, please!
