Am looking for a little advice on A/B-ing using reference tracks.
Specifically, when I do this I'm trying to make sure my bass levels are decent enough.
But I struggle a little with setting up the A/B process.
Can someone explain a REALLY SIMPLE way to do it that doesn't require much brains?!
I'd like to be able to pull a reference into a session while I'm still writing/mixing, but the level matching always seems way off. Also, I guess I should be bypassing all master bus plug ins?
Is a graphic EQ useful here?
Thanks in advance for your help.
