Equipment for recording neighbour noise
Post by Doveman »
Although this isn't a question about creating / recording music, I figured that the people on this forum will have a wealth of knowledge about recording different types of noise and the best equipment to use, so it seemed as good a place as any to ask.
The noise I need to record is a mixture of impact noise (slamming doors, stomping on floor, dropping things on floor) and high-frequency screeching noise from water pipes. I can't get a decent recording on my phone as the noise floor is too high, so I've ordered a Zoom H4n Pro/UK as that supposedly has very-low noise mic preamps and I'll give that a go but I understand I'll also need an SPL meter to show the actual noise levels, presumably C-weighted?
Is there anything reasonably priced (i.e. in the low hundreds of pounds, rather than thousands) that combines a low noise recorder and an SPL meter? The only things I've found are these commercial recorders that cost 2-3 thousand.
If there isn't an affordable combined device, can you recommend a reasonably priced but decent SPL meter?
For the impact noise, would it be better to use something like a boundary mic attached to the wall and connect that to the Zoom H4n's external inputs? If so, can you recommend a suitable boundary mic?
I've actually just received the Zoom H4n whilst I was typing this. I've tested it and I'm not impressed, as it seems to have much the same noise as my phone does, which rather swamps out the sound I'm trying to record. I can't imagine anyone could use this to record nature noises, bird song, etc. due to the noise, so I wonder what people would use for that?
Doveman
Posts: 52 Joined: Mon Apr 06, 2020 2:01 pm
Re: Equipment for recording neighbour noise
Welcome to the SOS forums.
You're not the first person to ask about recording neighbour noise, and I am sure you won't be the last. To give you any meaningful advice you need to let us know where in the world you live because every jurisdiction has different standards/laws which makes general advice meaningless.
As Andy says, they get this a lot!
Hugh has told us in the past that unless you have the right equipment, setup by the right people and for the required time periods, any recordings you make will have little value in court.
I suppose if you make some recordings and play them to the local police they might go and have 'a quiet word' but here in UK the processes are pretty byzantine to get noise nuisance stopped. There was a couple of programmes on UK TV recently showing how much work the professionals had to do to get a result, see if you can find it on the web?
One thing I think we can all agree on? DO NOT retaliate!
Post by resistorman »
If the noise floor of the Zoom is masking the noise, then it’s so faint you won’t be able to get a reliable meter reading anyhow.
resistorman
Posts: 2988 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
Post by Doveman »
zenguitar wrote:Welcome to the SOS forums.
Thanks Andy
I'm in the UK, Greater London area, with a pretty useless Council but hopefully if I can get some evidence myself I can use that to at least persuade them there's a problem because they have something like a 6-month waiting list for their recorders and then you only get it for a week, which sods law dictates will be the week the noisy neighbours go on holiday!
Doveman
Post by Doveman »
ef37a wrote:As Andy says, they get this a lot!
Yeah, I probably can't afford the sort of equipment that would produce evidence that would stand up in court but hopefully it will be enough to convince the Council that there's a problem. The police told me they don't deal with noise nuisance and to phone the Council's out of hours service but when I phoned them they told me they don't have a noise nuisance out of hours service!
Doveman
Post by Doveman »
resistorman wrote:If the noise floor of the Zoom is masking the noise, then it’s so faint you won’t be able to get a reliable meter reading anyhow.
Experimenting a bit more with the Zoom, the noise floor seems lower when it's in multitrack mode for some reason but it's still too high to capture certain ambient sounds, or maybe it's just the mics are only really designed to record sources that are quite close to them.
I plugged in my SM58 to the external input though and the noise floor was much better with that. It would seem a bit strange if the Zoom's advertised low-noise mic pre-amps are only used for the external inputs. Anyway, I might be able to use it to capture the problematic noise with a suitable external mic but the SM58 isn't really suitable for that so I'd welcome suggestions for something that would be.
The Zoom is quite fun to use as a song idea scratchpad, especially with the multitrack mode but as the built-in mics aren't going to work for the purpose I bought it for, I might be better off using a low-noise soundcard/mic pre-amp connected to my PC to record with, unless there's another portable device with a lower noise floor when using the built-in mics.
Doveman
One thing to think about...
Do you own your property or is it rented? If you own it and ever come to sell it you will need to disclose to the prospective purchaser that you have had a dispute with your neighbour. Not disclosing it will leave you open to legal action from the new purchasers.
It is usually best to take a gentle and friendly approach to these issues - have you approached the neighbour and let them know about the problems? It sounds like they may have wooden floors rather than carpet. Sometimes people take up the carpet or install laminated floors without realising the noise issues for people living below. Some leases actually stipulate that floors must be carpeted for this reason.
If you want the environmental health department to consider this issue then you will either need to use their equipment to record the noise or hire similar standard equipment with a traceable calibration. I've just done a quick search and it appears that there are a number of companies that hire out suitable equipment packages.
Posts: 16993 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
And thanks for coming back with the extra info. :clap:
Post by John Willett »
In the meantime there are various iPhone (and Android I assume) apps that do noise measurement - even my Apple Watch has it.
You can use these to get a noise level in your room as well as recording it. :thumbup:
I have found these apps to be pretty accurate and within a dB of professional level meters.
John Willett
I was involved in monitoring sound/noise levels outside a wedding venue just outside Manchester. The problem I had was that what the EHO considered unacceptable 'nuisance noise' was below the level of the background so unmeasurable. Basically, if you could hear a beat or anything that resembled music it was too loud.
So recording or measuring the nuisance noise may not always be possible. Keeping a accurate and detailed log is essential though.
Posts: 22916 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Post by CS70 »
Since I don't live in the UK I have no opinion about the laws where you are, but the fellows here have indeed quite a lot of experience with that type of questions, and if they say that it's moot, it's most likely moot.
On the technical side, if the noise is loud enough to annoy you, it's odd that it cannot be captured by a mic, unless it's really, really low frequencies (which you would perceive more as a vibration than a sound).
And almost certainly is not the preamp noise floor of the Zoom which is the problem, and what you are hearing is the ambient noise in you room.
Dynamic mics (like a 58) aren't that great for high frequency noise as they roll off the highs, but once again it's hard to say what you mean by "high frequency". It seems unlikely that the sound that annoys you is entirely over the 13-15KHz threshold. You might fare a bit better with a condenser mic, which covers more than the entire audible spectrum, but again it's odd that you don't get anything usable with a 58. It has a cardioid pattern so it won't pick up much from rear and sides, but if you point it towards the neightbour flat, it should. You might try a more sensitive dynamic microphone (there's some), or one with an omni pattern.
But might it be that it's more of a perceptive issue, like you're trying to concentrate and suddenly there is a relatively faint but audible door slam which annoys you? Or do you hear it really loud? Because if you do, so it will even the cheapest microphone.
You may also to equalize and compress the recording a little bit to reveal more details, but if you start manipulating it too much it won't be really that valid even as indicative evidence..
CS70 wrote: On the technical side, if the noise is loud enough to annoy you, it's odd that it cannot be captured by a mic, unless it's really, really low frequencies (which you would perceive more as a vibration than a sound).
Nuisance noise, according to the EHO I had the conversation with, does not need to be loud, or even above the ambient noise, it simply has to be audible. The almost imperceptible but rhythmic 'thump' of the bass from the DJ in the marquee ½ a mile away was enough for him to say it was too loud. Even very quiet door closings or footsteps can be intrusive late at night but if it is just people conducting their normal lives in a flat where sound travels between floors that is clearly a different matter to people playing loud music or having shouting matches in the early hours. Context is everything
Yes, probably.
Yes, see above.
More detail would be useful Doveman please tell us what it is that disturbed you and what times of day/night it occurs. And, as I said above, keep detailed records, they will be much more useful in a court of law than uncalibrated noise meter readings or recording that demonstrate the 'nuisance noise' is below the ambient.....
Post by Doveman »
James Perrett wrote:One thing to think about...
I don't own my flat unfortunately, or I'd sell up and move. I'm a council tenant in a 1-bed flat on the 1st floor of a 3 storey block of 12 flats but I know at least some of the 2-bed flats on the floor above me are privately owned and possibly let out privately. The flat directly above me, at the back of the block, is No. 22 and the one next to that, at the front of the block, is No.21. I had the council investigate noise from No.22 a few years ago and it turned out that was privately owned and rented out and there wasn't much they could do, because at the time the lease was granted there was no stipulation about having carpets. They changed that a few years ago but it's not retrospective.
My block is also attached to the neighbouring block so there's a shared party wall and there's a lot of problems with noise travelling from the flats in that block too.
It's hard to know whether the people in No.22 are being deliberately noisy or not. When they walk about it sounds like they're deliberately stomping their heels on the floor and they always seems to be slamming cupboards and dropping things on the floor whenever they're stomping about but they're not playing loud music or anything like that, so they might just be elephants!
The screeching noise, which is probably water pipes, may be coming from a flat in the adjoining block as it's louder in my bedroom, which shares the party wall, than my living room. I made a 30s recording with the Zoom mic which I've shared here:
https://drive.google.com/file/d/1LZwryI ... sp=sharing
I used the Zoom's compression for this recording, which probably hasn't done much good as it's boosted the hiss as well as the noise I'm trying to record but at least you can hear it.
I don't think I need to make a recording with professional calibrated equipment before environmental health will investigate. They should investigate based on reports and logs, it's just with this sort of intermittent noise it would be helpful to be able to play them a recording to prove I'm not a crazy person creating logs of imaginary noises!
Doveman
Post by Doveman »
John Willett wrote:In the meantime there are various iPhone (and Android I assume) apps that do noise measurement - even my Apple Watch has it.
Thanks, I'll see what I can find for my Android phone but it has the same problem as the Zoom's built-in mic, i.e. quite a lot of hiss masking the noise I'm trying to record. I can't even use an external mic with my phone as the headphone/mic socket doesn't work, although I guess there might be some USB mics that would work.
Doveman
Post by Doveman »
Sam Spoons wrote:I was involved in monitoring sound/noise levels outside a wedding venue just outside Manchester. The problem I had was that what the EHO considered unacceptable 'nuisance noise' was below the level of the background so unmeasurable. Basically, if you could hear a beat or anything that resembled music it was too loud.
Yeah, it's tedious keeping logs in a home situation as it makes you focus on the noise even more, always feeling like you've got to be ready to make a note every time you hear something to convince the council that it's a problem.
I don't think the noise I want to record is unmeasurable though. It might not register as very loud on a SPL meter I guess, I'm not sure about that but it should certainly be recordable with the right equipment. I did have a problem with a neighbour letting her kid kick his football against the wall on the balcony all day and the noise that was making might have been hard to record, as it was a low-frequency thud, probably similar to the sort of thing you were monitoring.
Doveman
Post by Doveman »
CS70 wrote: Since I don't live in the UK I have no opinion about the laws where you are, but the fellows here have indeed quite a lot of experience with that type of questions, and if they say that it's moot, it's most likely moot.
I'm almost certain it's the Zoom's internal noise floor that's the problem, as there's nothing in my bedroom making any noise that would cause the hiss in my recording and the noise I'm trying to record is really quite loud and intrusive, certainly louder than a lot of ambient nature sounds that people might record, so I don't think the Zoom would be any good for that. The SM58 doesn't pick up the noise at all but I also don't get much, if any, hiss using the external input which makes me think the internal mic uses a different pre-amp. I really need a different external mic that is designed to pick up high frequencies though.
I've still got quite good hearing for high-frequencies, although I've also got tinnitus and auditory processing disorder, the latter of which makes it difficult to understand speech when there's a lot of background noise like in a busy pub.
Actually I've just used a frequency generator on my PC to compare with my recording and it seems that the noise I'm trying to record isn't high-frequency at all, it's around 400hz, which makes it even more strange that my SM58 isn't picking it up.
Doveman
Post by Mike Stranks »
I apologise in advance that I shall be blunt...
The Zoom and an SM58 are nowhere near accurate - or neutral - enough to let anyone judge anything apart from, "Yes, that was some noise." And noise-meters are not worth pursuing in an amateur context.
Having been involved in an informal 'neutral third party' noise assessment a few years ago, the other aspect is that, of course, the aggrieved soon notice every sound and noise emanating from the complained-of premises.
I could go on about my experience, but it won't advance the discussion any.
My tuppence...
1) Once social isolation has ended try and face-to-face with the occupiers of the noisy flat. Not letter, email, phone-call, but talk. Have an acquaintance with you - not a family member - and try and keep it light and smiley, but being clear about the issues as you see them. Don't get into an argument... do your best to part on at least calm terms.
2) If you really want to get evidence follow James Perrett's advice and hire some proper kit and keep those logs.
Mike Stranks
Post by CS70 »
Doveman wrote: I'm almost certain it's the Zoom's internal noise floor that's the problem, as there's nothing in my bedroom making any noise that would cause the hiss in my recording and the noise I'm trying to record is really quite loud and intrusive, certainly louder than a lot of ambient nature sounds that people might record, so I don't think the Zoom would be any good for that. The SM58 doesn't pick up the noise at all but I also don't get much, if any, hiss using the external input which makes me think the internal mic uses a different pre-amp. I really need a different external mic that is designed to pick up high frequencies though.
This sounds stranger and stranger. You wouldn't get anything even vaguely forensic (or usable for your specific goal in this instance), but certainly you should get sound, especially if the noise is at 400Hz. I did use a Zoom once (don't remember the model but I think it was in the same H series) and while I wouldn't exchange the preamps for my Daking One or the Aphex 207D, I definitely got reasonable results.
And when shooting video I routinely record audio with cameras mic for alignment (in addition to a separate audio feed), which if anything must be worse than the Zoom, and you can clearly hear little noises well over any ambient noise.
Do you run the H6 from batteries? What is your gain setting? You positive you don't have the pad engaged? I read there are compressors on the unit, you positive they are disengaged? The recorder has different types of capsules, which ones are you using?
Post by CS70 »
Mike Stranks wrote: Don't get into an argument
This can be harder than getting a good recording... :)
Post by Rob Kirkwood »
Noisy/difficult neighbour is one of those things that can destroy the peace you expect in your own home - been there, got the t-shirt. In our case we spent quite some time talking to the neighbour, trying to get to know them, making friends - & then, out of the blue, something came up that we were able to help them out with.
So, as Mike says, the best possible way to resolve a problem like this is face-to-face without getting into an argument - but appreciate that sometimes this just isn't possible, in which case is moving an option for you?
One other thing that I don't think has been mentioned: In the UK if the noisy neighbour is a tenant they may well be in breach of their tenancy agreement ... but again that's another 'official' process, which may not work anyway.
Rob
Rob Kirkwood
Posts: 138 Joined: Tue Jan 07, 2003 12:00 am Location: Nottingham, UK
Post by wireman »
Doveman wrote: Yeah, I probably can't afford the sort of equipment that would produce evidence that would stand up in court but hopefully it will be enough to convince the Council that there's a problem. The police told me they don't deal with noise nuisance and to phone the Council's out of hours service but when I phoned them they told me they don't have a noise nuisance out of hours service!
I would email the council and ask them if any measurements would prove useful and what equipment would be minimally acceptable.
Meanwhile keep records of the nuisance.
wireman
Posts: 804 Joined: Fri Dec 17, 2004 12:00 am
Post by DanDan »
The tiny mics on phones and zooms and the cheap measurement mics are all very noisy.
Ultimately though an SPL log of incoming noise is bound to be more useful than a strange audio recording. There are a few iOS options pretty much of the Pro level. You could demo SoundMeter by FaberAcoustical or SPLMeter Pro by studiosixdigital.com
DanDan
Posts: 108 Joined: Tue Feb 10, 2009 12:00 am Location: Cork Ireland
Dan FitzGerald MIOA  MAES
www.irishacoustics.com
www.soundsound.ie
wireman wrote:
Doveman wrote: Meanwhile keep records of the nuisance.
Keeping a diary of every tome it happens and a descrioption is essential.
This is what the Council will take most note of.
John Willett
Post by Doveman »
Mike Stranks wrote:I apologise in advance that I shall be blunt...
My tuppence...
I agree that I'm probably more sensitive to noise as a result of this ongoing problem but I think I'm still objective enough to be able to distinguish noises that I notice but aren't that loud and other people wouldn't be bothered by from noises that are very intrusive and would annoy most people, like screeching water pipes that wake you up at 2am and the thud of a football being kicked against the wall for hours on end. I'd hoped the latter had stopped after I spoke to my neighbour at No.21 about it but unfortunately it's just started up again after a few days of relative peace and quiet. I say relative, because there's still been the noise from the neighbours directly above me at No.22 stomping about and slamming doors but at least that only happens for a short time each time and it doesn't do my head in as much as the constant thud of the football for hours.
Clearly the Zoom and the SM58 are useless for recording these noises, so I'll return the Zoom. I don't think there's any point spending hundreds of pounds hiring professional equipment though, as the council aren't going to accept that as evidence when I have the key to the case and could have tampered with it. I don't think there's anything magic about the professional noise recorders, they're just calibrated, combine an SPL meter with a noise recorder and some features for analysing the recordings.
So I'm sure there must be a cheaper mic and pre-amp/USB soundcard I could buy that would record the sound to at least prove I'm not imagining it. If no mic can record the noise, then hiring the professional calibrated recorder for a week isn't going to help me and if I can get a recording of the noise, then together with my logs it will help me persuade the council that the noise is unreasonable and get them to investigate further.
Doveman
