I have no idea on what I'm doing but I know what I want it to do.
Post by Slidewayz247 »
Mods please move if in wrong spot.
Okay so I am trying to find a program that I can clip the tops of sound off in a live game I.E. not recorded stuff.
For example i need to be able to hear call outs at the 40bd lvl but clip everything over 60db to save my ear drums.....
Any suggestions?
Slidewayz247
Posts: 1 Joined: Sat May 09, 2020 12:09 pm
Re: I have no idea on what I'm doing but I know what I want it to do.
Wouldn't a limiter be better rather than a clipper? You probably need to find something that works as a virtual driver and allows you to insert plug-ins into the signal chain.
This has a limiter https://www.vb-audio.com/Voicemeeter/potato.htm
Post by MOF »
Are you at this sport venue or are you receiving sound remotely, where are the ‘call outs’ coming from i.e. can you put a dedicated mic’ on that person?
If the sound you want isn’t clear then it’s not about level so much as removing frequencies to leave the speech band clearer.
MOF
Post by Dicko »
What software are you using ?
A limiter would be my choice
Dicko
Posts: 294 Joined: Mon Jun 16, 2008 12:00 am Location: Allesley
Post by CS70 »
Slidewayz247 wrote:Mods please move if in wrong spot.
Any suggestions?
It depends if you want to still hear the 60dB stuff, only at a lower volume, or you don't want to hear it at all.
In the former case (which makes more sense), you need to find yourself a limiter.
A limiter.. limits the max level to whatever you want (fo example, 40dB), acting very fast.
It depends a bit on your setup (specifically if you use a USB headset or an analog ouput for headphones and analog input for mic), but the easiest way would be to get a cheap hardware limiter box and put it inline between your headphone out and your headphones. Basically instead of having
Code: Select all
computer --usb--> interface headphones out --cable--> headphones
you will have
Code: Select all
computer --usb--> interface headphones out --cable--> limiter --cable--> headphones
There's plenty of good and cheap limiter boxes from the past that can be had for very little in the used market: dbx, behringer, aphex... you name it. For your application you don't need any particular audio properties other that limiting, so really any would do.
A hardware limiter would not add any processing load on you pc which for gaming is obviously a thing.
There are other ways but this would be the simplest one. If you use an USB headset shout out and we'll take it from there.
