I am buying a pair of passive vintage Auratones (5PSC) and a pair of Reftones LD-2.
I want to try both reference mixing cubes and see what it will work the best for me. At the moment I'm without my main monitors (I just have very good headphones), so I think it would be good having a pair of these for checking also panning decisions, and make a little more of traditional speakers mixing. Later I plan to probably use only one Auratone / Reftone cube in mono since it's better for balancing the mix levels and check mono compatibility... and use main monitors for the stereo information. I want to start to mix more in mono.... but who knows, maybe I'll love using these also in stereo, we will see!
These are my first passive speakers, so any recommendation about a good amp that may work for both of these?
- Vintage Auratones 5PSC speakers should take approx 30W of power if I remember correctly, while Reftones take up to 300W of power! So which wattage can you recommend for the amp? Better underpowering the Reftones or overpowering the Auratones? Or I'm forced to buy two different amps (I hope not!)
- Also, since the amp will stay near my desk, another essential feature I want is to have the amp without fans (only convection), buzzes or hisses/noises.
- Another benefit would be to have it in a small form factor, since I don't have any other gear in racks! So I will place it on the desk, or under the desk. Smaller, the better. If possible, of course.
- Better Class AB or Class D for these kind of speakers?
- Budget: Anything from 100€ to 500€ (of course, lower the better, if not compromising the audio). I've never worked with passive monitors and also we are referring to small "one woofer" cubes with a sort of limited frequency range (Reftones are more extended in this regard).
On the internet some people says that the improvement in sound may be dramatic on these speakers with the good amp. And that actually, these speakers may transform themselves with a good amp (passing from "horror tones" to very revealing speakers). Is this real? I mean...passing from an amp of 150€ to an amp of 500€ can make a huge difference on these speakers?
Now, some models I've found (fanless), that I'm evaluating:
- Auratone A2-30: https://www.thomann.de/gb/auratone_a2_30.htm (seems great if used only with the Auratones...but I'm little worried that it could be not powerful enough for the Reftones which seems to be much more power hungry)
- PAS 2002 PCA: https://www.thomann.de/gb/pas_2002pca.htm (didn't know this brand before, but the reviews are amazing so it's a good sign. Little more expensive than I wanted, and also huge and with big weight. I can stretch and accept form factor if the quality justifies it)
- Amphion Mono 100 https://amphion.fi/create/products-pro- ... p100-mono/ seems very good, also in a great form factor... but only mono (for the price of approx 500€; stereo model double the price. 1000€ would be too much for Auratones I think!). The mono model could work good later on when (and if) I will be using only one cube.
- Dayton Audio DTA-120BT2 https://www.parts-express.com/dayton-au ... --300-3803 This is one of the recommended amps on Reftone's website. Anyway it's quite a cheap amp, and deisgned for hi-fi more than for the studio. I guess if such a cheap amp can be good enough for mixing on these speakers? Also, it seems not very powerful. Also, maybe the unbalanced inputs on the back are not great and practical for coming with the signal from the sound card (XLR)?
- Dayton Audio APA150: https://www.soundimports.eu/en/dayton-audio-apa150.html Another amp recommended on Reftone's website. Same considerations as above (except power, which is higher). Again, maybe the unbalanced inputs on the back are not great for coming with the signal from the soundcard (XLR)?
- Apart Champ Four: https://www.thomann.de/gb/apart_champ4.htm or some other Apart from the Champ series.
- Apart Revamp 2150 (or some other models of the Revamp or other series from Apart): http://www.apart-audio.com/press/Apart_ ... elease.pdf
- Drawmer CPA 50 https://www.kmraudio.com/drawmer-cpa-50.php same nice form factor as the Auratone A2-30, but even slightly less powerful (25 vs 30 w at 8 ohm), so maybe still better the Auratone one.
- Drawmer MPA 90 https://www.kmraudio.com/drawmer-mpa-90 ... lifier.php this seems a little more powerful in a nice form factor. It also seems discontinued, at least in Europe.
- Some of the T.Amp models (produced by Thomann), but I would prefer buying a more "traditional" amp brand if possible.
Any suggestion on these amps (or some other fanless models)? One side of me wants to try the Auratones / Reftones with a good amp, to be sure to experience and evaluate their utility at their best. Would be a shame to make them arrive from the US (so, not cheap!) and then try them with a very bad amp that can will them seem bad and not useful for mixing purposes. While instead, it will be just the bad amp.
The other side of me doesn't know if the difference in amps can bring out just different nuances in these speakers sound, or if they really can make a difference. I have to admit that I am completely ignorant on this topic.
Thank you all for your kind help
