OK, so the requirement is to share sound from apps over Zoom while simultaneously using the mic and webcam in the normal manner. This is quite achievable but it isn’t part of Zoom’s settings – you have to set it up each time you want to use it. So here we go:
1) Start your meeting. You might want to start it early before anyone else joins so they aren’t hanging around while you’re doing this. At the bottom of the screen (at least on a Mac, might be different on other platforms) you’ll see a green button labelled “Share screen”. Click on it. You’ll see the following screen:
2) Most of this screen is irrelevant, you’re only interested in the “Advanced” tab (between Basic and Files) at the top of the screen. Click on that. You’ll see this screen:
3) Click on “Music or Computer Sound Only” to make it blue. Click on “Share”. If this is NOT the first ever time you’ve done this then you’re done. You’ll go back to the main screen which will look like this at the top:
You can see the big green strip pointing out you’re sharing sound and a button to stop sharing.
4) If this IS the first time you’ve tried this then Zoom has to install an audio driver and you’ll get this screen:
Just follow the instructions remembering to restart Logic or whatever program is generating the sound afterwards. As a result of this you’ll find an additional audio device showing up in Audio MIDI Setup called ZoomAudioDevice. Just ignore it.
Of course you have to balance up the sound of your voice in the mic against the sound of Logic or whatever, which is tricky when you can’t hear your voice. There’s two ways of doing this. The best is to have an assistant on a separate computer participating in the meeting who can tell you what he/she is hearing. The second if you’re just trying it out in a solo meeting is to use the Zoom record function to record a snippet of sound that you can review afterwards. My experience is that you’ll probably need to keep the level of the mic up and the application down.
Good luck!
