What is the most professional USB audio interface for vocal recording?!
Post by Synthman4 »
I want to record and produce music in Cubase for selling on iTunes etc.
I have so many virtual instruments but I want to know what is the best audio interface for vocal recording?
Also, would an Aria valve mic be enough or would I have to buy I one of those £2000 Neumann jobs?!
Synthman
Synthman4
Posts: 115 Joined: Fri May 01, 2020 6:35 pm
Re: What is the most professional USB audio interface for vocal recording?!
You definitely don't need a Neumann to record excellent 'release quality' vocals, nor a boutique preamp/interface. Give these* two articles a read then start thinking about the room you are going to record in. Getting that right will make far more difference than spending megabucks on the best preamps and mics.
* https://www.soundonsound.com/reviews/pick-preamp
* https://www.soundonsound.com/techniques/vocal-mics
Posts: 22914 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Post by Music Wolf »
And of course what matters far more than the equipment, or the producer / engineer, is the quality of the vocalist and the material that they are going to perform.
If both of those are not up to scratch then, even with the best mic and pre-amp in the world, you aren't going to see many sales.
Music Wolf
Posts: 2894 Joined: Fri Feb 17, 2006 12:00 am Location: Exiled to St Helens
Post by Synthman4 »
Why can't anyone give me a proper answer? My production skills are good enough now, but before I was using a Roland Rubix 24 for vocal recording. It just didn't seem powerful enough even when the indicator was high. Surely there are more powerful preamps than that that give a more powerful recording.
Synthman4
Post by Kwackman »
Synthman4 wrote:I was using a Roland Rubix 24 for vocal recording. It just didn't seem powerful enough even when the indicator was high. Surely there are more powerful preamps than that that give a more powerful recording.
The Roland Rubix's mic pre-amp (according to the spec on Roland's site) has 60dB of gain.
That should be more than enough for most microphones.
Kwackman
Posts: 3687 Joined: Thu Nov 07, 2002 12:00 am Location: Belfast
Post by MOF »
What microphone are you using now? The Aria has very good reviews as a vocal mic’.
MOF
By a more 'powerful' preamp I guess you mean higher gain? Simply having more gain will not do what you are asking. More 'powerful' vocals come from many different factors but more preamp gain is not usually one of them.
Post by Synthman4 »
A meant a louder, more powerful vocal input.
I use an Aria valve mic worth £900.
Synthman4
Post by Synthman4 »
I can't understand that even today, when I make a harding pumping dance mix, the vocals are always too low or quiet and when I eq them or put more compression on, the vocals distort
Synthman4
That's just a matter of gain structure within your mix and the production techniques you're applying.
Post by Synthman4 »
If I turn the drums down, do I put more compression onto the drums or do I leave that for the mastering compression at the end?
Synthman4
From what you've said I don't think the problem is with you mic or preamp but related to how you process the vocals after recording them. You also seem to misunderstand the basic principles of gain structure. Given that your genre is dance music I think you'd benefit from a one to one with Zukan (Eddie Bazil) of this parish. I believe he is able to conduct online lessons and I'm sure it would be money well spent. Drop him a PM.
Post by Chet Leeway »
Chet Leeway
Posts: 163 Joined: Fri May 06, 2016 8:13 pm Location: Barcelona
Post by Synthman4 »
Sam Spoons wrote:From what you've said I don't think the problem is with you mic or preamp but related to how you process the vocals after recording them. You also seem to misunderstand the basic principles of gain structure. Given that your genre is dance music I think you'd benefit from a one to one with Zukan (Eddie Bazil) of this parish. I believe he is able to conduct online lessons and I'm sure it would be money well spent. Drop him a PM.
Please post the link to this Eddie Brazil geezer.
Synthman4
Post by Synthman4 »
What's the best vocal compression to use? The built in compression of the audio interface or the software compression?
Synthman4
Post by Dynamic Mike »
Perhaps the knowledge you seek is to be found in here https://www.soundonsound.com/forum/view ... 42#p463451
Dynamic Mike
Posts: 5291 Joined: Sun Dec 31, 2006 12:00 am
Why do bad things mostly seem to happen to people who light up a room when they enter it?
Post by Synthman4 »
I'm buying this one... Universal Audio Apollo Twin MKII DUO
Synthman4
Synthman4 wrote:Why can't anyone give me a proper answer?
Maybe it's because you're not asking the right questions?
My production skills are good enough now, but... It just didn't seem powerful enough even when the indicator was high. Surely there are more powerful preamps than that that give a more powerful recording.
I fear your production skills still have a way to go -- at least when it comes to vocal recordings!
The perception of vocal power involves a lot more than just the peak level. I suspect the reason your vocals seem too quiet compared to your dance music arrangements is because they are not compressed adequately. Although it may also be an arrangement problem, or a performance issue...
Posts: 43704 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Post by Synthman4 »
Well I've decided to focus on emphasising the vocal track rather the pumping drum track. I'll have to turn down every other track in future and just apply more compression on the drums while being lower down in the mix.
Synthman4
Post by MOF »
Yes it's all about balance, and at different points in the song some things have to give to allow other elements to feature.
As others have said you really need to spend some time learning about gain structure and lay off the vocoder effects.
MOF
Post by duder »
When you say indicator, it sounds like you’re looking at the red/green
LED on the rubix and using that LED to set your gain. However, the recorded track is nowhere near loud enough within the track (small waveform). Maybe not? If so, I’ve noticed the indicator is somewhat conservative, may want to look at the levels in the daw when setting the gain for whatever your max volume will be.
Also you can use an EQ or compressor (as others have pointed out) to boost the overall gain in the channel (if it’s low)
duder
Posts: 1 Joined: Sun Jul 17, 2022 6:48 am
