Dr Huge Longjohns wrote:Well I was seriously bewildered by the last post but this one is seriously above my pay grade!
Roughly it's saying that the impedance changes dependent on:
The current, "I";
The rate that the current changes with respect to time (the "time dependent" bit referred to in DC Choppah's previous post), "dI/dt";
The rate that the rate at which the current changes with respect to time, changes with respect to time, "d²I/dt²";
(Etc)
The exact contribution that each of these elements of the calculation make is dependent on the specific properties of a given circuit.
The notation "dI/dt" is shorthand for saying "how much variable I (in this case, the current) changes as a result of a change in t (in this case, time)". It's a bit more subtle than that in some ways, but IMO this is an entirely valid way to view a differential without getting into actual calculus. Which is fun, but I know that is an opinion that isn't shared by everyone
Another way to look at it in terms of what is "happening" inside whatever equipment is being considered is something like (grossly over-simplified but sort of conveys the gist) :
Digital: 1+1=2
Analogue: 1+1 = about 2 ish, dependent on many variables to do with how the specific circuit works and how it's being used/driven. The answer to the sum is therefore generally going to be slightly "wrong" (or perhaps better to say not perfectly "right"), but that wrongness can sound very right if the flavour of wrong is good, and some analogue circuits can give a very pleasing flavour of wrong.
In summary, Walkers should probably launch SSL-flavoured fried potato things. Or something like that.
