Pedal Order
Pedal Order
Wanted to ask what was the proper order of placing guitar effect pedals. I have the following, I have read all kinds of different points of suggestion, so curious to see if there's any kind of 'right way'?
Overdrive pedal
Distortion
Noise Gate pedal
Compressor
Delay Pedal
EQ pedal
Chorus
I do know that a compressor never goes before any kind of reverb or delay pedal.
Overdrive pedal
Distortion
Noise Gate pedal
Compressor
Delay Pedal
EQ pedal
Chorus
Re: Pedal Order
Interesting. Whist I'm no expert, I would raise where the compressor comes in here - I thought that they typically went before the overdrive / distortion rather than after so that the signal was smoothed a bit before hitting the OD rather than levelling the OD output . I thought that the latter would potentially be more noisy.
Re: Pedal Order
The *real* answer is that there is no 'right' way.
But if it were me...
Noise Gate
Compressor
Overdrive pedal
Distortion
EQ pedal
Chorus
Delay Pedal
Reasons?
Noise gate to clean the source up before it hits any of the pedals - you could also add another gate before the delay pedal.
Compressor to give the rest of the chain as much signal to bite on as possible.
Overdrive and distortion early, since they would mask EQ and chorus.
EQ next to massage the tone before the wet/dry mix pedals.
Chorus before delay, so that the delay is an exact repeat of the rest of the signal chain, including chorus.
Of course you could message this order around specifically to not do any of the things i've suggested above!
Noise Gate
Compressor
Overdrive pedal
Distortion
EQ pedal
Chorus
Delay Pedal
Reasons?
Re: Pedal Order
Back in the day my gut feeling was OD before Wah, until I tried it the other way around...... Much better sounding with the Wah first
As The Elf says there is no right way, just what sounds best. I have wah>clean boost>overdrive>delay>tuner>chorus>looper>reverb.
The tuner is where it is for purely practical reasons, normally I'd put it first but that made the pedalboard layout less than optimal 'cos it would have needed to be where I could plug a guitar lead into it.
Re: Pedal Order
There are no really hard and fast definite rules,
if it is making the sound you wanted, the one you heard in your head and were aiming for , then it's right..... generally......
but from my perspective as an engineer , and a guitarist, seeking to optimise signal to noise ratios , and get the most controlled results... it's worth considering how each effect works, and what it may do in combination with others ,
my general thinking tends along the following lines..... some of which may sound a lot like fence sitting, but are in fact not......
Between Guitar and amp
Depends on purpose of gate and self noise of distortion,
to reduce hum from single coils , it might be,
Gate , (Wah) Compressor, (EQ) (Wah) Distortion, (EQ) Wah > Amp
or the Gate may go at the end of the chain to stop fuzzbox hiss being annoying in quiet spaces between things.
EQ can go almost anywhere, but is typically better after the compression, or the compressor may end up being driven primarily by the low end thump you tried to add to the basic tone, sucking out the power of the rest .
the other pedals
again depends on the application, if largely playing clean, then
I would normally use pitch and time based In the effects loop of amp ideally,
usually in the sequence
Pitch >Modulation > Time
in this instance
Chorus > Delay >Reverb
if largely playing distorted, i MIGHT put the chorus in front of the amp. and distortion pedal...
remember that the chorus effect will be applied to the whole signal, and if there's a significant hiss component, that hiss will have chorus applied after the fact , leading to an obvious swooshing noise when you're not playing (Carlsboro once rebuilt an amp for me to move the signal path to the chorus of my GLX150C, such that the gain happened after the chorus rather than before , so it was quieter when not playing a note.... ,. yes it meant a mono chorus rather than stereo , but it honestly sounded much nicer ) , or you need another gate in that point of the signal chain..... )
but if using say a harmoniser then , Harmony then chorus then delay and reverb, to give the pitch device the best chance of tracking the original signal well,
I would normally place a flanger in front of a chorus if using both , the flanger being pitch orientated, the chorus being very small delay orientated , but parallel also works well
you could add EQ at any stage to be fair , if your other fx don't allow sufficient spectral control of their contribution .
the exception to the general dual pitch signal rule being Octave pedals, they mostly seem best before the amp to me.... whether clean or dirty , perhaps because the spread is wide enough to preclude intermodulation effects when driving through an amp's gain topology, i find that if I place , say , a minor third harmony in front of the amp, it sounds shit, self intermodulation , a bit like trying to run two guitars through the same gain structure at the same time..... as opposed to the cleaner, more classic twin lead guitar effect when used in the fx loop
levels at all stages need to be paid attention to so you don;t end up with uncontrollable noise through driving pedals too hard, unless of course, that is the effect you were after in the first place..... see ... there are NO RULES>>....
Ask yourself..... is this the noise i WANTED to make ??
if the answer is No, then and ONLY then are you doing something definitely wrong.....
the other pedals
in this instance
- Studio Support Gnome
Frequent Poster - Posts: 3025 Joined: Tue Jul 22, 2003 12:00 am Location: UK
Mostly Retired from Audio.... If I already know you I'll help, if not.... Ask Hugh Robjohns, unless that is you're in need of 80's shred guitar... that, I'm still interested in having fun with...
Re: Pedal Order
Thanks for the replies and suggestions so far. Isn't another way by using the amp's effects loop? I read that you can put any delay/chorus type pedals through the effects loop and then just have the compressor/noise gate/distortion etc going through the normal guitar - amp chain.
Re: Pedal Order
I'll 2nd the "no right answer" answer, which is why i have an es-8 on my main board to allow order switching. However, my usual preference is:
Wah/envelope
pitch
fuzz
boost
drive
comp
eq/volume
chorus
trem
delay
verb
If using the loop on an amp, i'll either make the break before comp or after eq.
Wah/envelope
pitch
fuzz
boost
drive
comp
eq/volume
chorus
trem
delay
verb
- Funkyflash5
Regular - Posts: 215 Joined: Thu Apr 26, 2018 12:43 am Location: Wisconsin, USA
Re: Pedal Order
If you have an effects loop then think about the guitar amplifier as being a pre-amp (which in simple terms is a type of distortion and eq) and a power amp (something to make everything louder) with the loop being the connection between them.
I would go from the last distortion / fuzz pedal into your (pre) amp in then amplifier effects send (pre amp out) > modulation / delay / reverb > effects return (power amp in).
- Music Wolf
Posts: 2894 Joined: Fri Feb 17, 2006 12:00 am
No One There
https://starbelly.bandmule.com/
Re: Pedal Order
They’ll be a zillion opinions on this, and rightly so, but my favoured order is a compressor right at the end, no matter what’s being used before it, I like that lovely slowly rising noise floor with a long release setting, especially on certain solo notes, apart from that I think there is no right order, it’s up to you, unless you’re deliberately trying to copy or reference a particular sound,
Re: Pedal Order
Absolutely no "right" way - see Tom Morello for a great sounding but not "correct" layout.
Personally I'd start with...
Compressor
EQ (to allow you to tone shape before the drives)
Overdrive
Distortion
Noise Gate pedal - if it has a loop put the OD and Dist pedals in there
Chorus
Delay Pedal
A tip I picked up years back was putting a tuner at the end of the pedal board. That way if you have any cable issues you can see if it is post board or not.
Hewesy
Compressor
Overdrive
Distortion
Chorus
Delay Pedal
Hewesy
Re: Pedal Order
Auto-Wha
Chorus
Compressor
Delay
Distortion
EQ
Flanger
Harmoniser
Overdrive
Phaser
Reverb
Tape Echo
Tremolo
Wah
Alphabetical order, feels so much better now.
Andy
Chorus
Compressor
Delay
Distortion
EQ
Flanger
Harmoniser
Overdrive
Phaser
Reverb
Tape Echo
Tremolo
Wah
Andy
Re: Pedal Order
I thought that one of the reasons behind having many pedals is that you can experiment with the order. There is certainly no right way. Also, most guitarists I know are more concerned with getting a sound they like, and then trying to fix any noise produced later on.
Just experiment and learn that way!
- innerchord
Regular - Posts: 212 Joined: Wed May 11, 2016 12:00 am
Re: Pedal Order
zenguitar wrote:Auto-Wha
Chorus
Compressor
Delay
Distortion
EQ
Flanger
Harmoniser
Overdrive
Phaser
Reverb
Tape Echo
Tremolo
Wah
Andy
My mate claims to have CDO.
It's like OCD, but the letters are in the right order.
(You can use that if you like. No need to thank me.)
- SecretSam
Frequent Poster - Posts: 3031 Joined: Tue Oct 29, 2002 12:00 am Location: Officially, I do not exist.
Instant gratification is actually pretty good. It's fast as well.
Re: Pedal Order
Re: Pedal Order
I knew a guitarist once who would organise his pedals in whatever order he found them in after forgetting where he'd left them the night before due to his ardent belief in the merits of inhaling the fumes resulting from igniting his home-grown horticulture.
I'm not even joking. The guy had to practise every day just to remember stuff he'd been playing daily for a year or more. Some days he was (genuinely) fantastic, others... well, we drank to forget.
I'm all for freedom of choice on the herbivoral front, to the point where I believe the current prohibition of same to be very wrong, counterproductive and misguided.
That said, legal or not, please don't mix it with business!
Posts: 9985 Joined: Wed Sep 01, 2004 12:00 am
Re: Pedal Order
No order prescriptions from me but a note on my own use of OD and compression. I pluck the strings with my fingers mostly and fairly lightly. My compression is post OD this allows me to use the overdrive as a expressive element by digging in without significantly changing the output level. A bit like a wide open tube amp.
