IK Multimedia - T-RackS 5
Post by John Egan »
Hi All,
I recently bought IK Multimedia T-RackS 5 and I am impressed with it. I am using it in stand-alone mode. I do have a (quite likely stupid) question, however.
How do I use it as a plugin?
The manual says it is possible but for the life of me, I can't see a plugin version. What am I missing?
Regards, John
John Egan
Posts: 476 Joined: Wed Nov 27, 2002 12:00 am Location: Staffordshire, England
Re: IK Multimedia - T-RackS 5
Post by Aled Hughes »
The individual processors are available as plugins, but I don’t think the entire program is. They should have been installed automatically.
I like the plugins, though I only occasionally use the stand-alone mode.
Aled Hughes
Posts: 2136 Joined: Tue Oct 24, 2006 12:00 am Location: Pwllheli, Cymru
Post by John Egan »
Ramirez wrote:The individual processors are available as plugins, but I don’t think the entire program is. They should have been installed automatically.
Yes, I have used the individual plugins as well as using them in T-RackS 5 stand-alone mode and I have come to the conclusion that there is no shell plugin available, but that doesn't seem to equate with the Ik Multimedia description. I'll contact them for an explanation.
Regards, john
John Egan
Post by Rich Hanson »
Yes there is, the plugin name you're looking for is TR5 Suite (this is for the VST3 version, VST2 and AU names sometimes differ slightly).
Rich Hanson
Posts: 3686 Joined: Sat Sep 06, 2003 12:00 am Location: Sort of near Rochester, Kent, UK
Post by innerchord »
Rich Hanson wrote:Yes there is, the plugin name you're looking for is TR5 Suite (this is for the VST3 version, VST2 and AU names sometimes differ slightly).
Rich is correct. Look for the Suite and you'll get the 'shell' plugin loading up.
I'm a huge fan of the new IK stuff. Some of their recent work has been up there with the best I've heard. It used to be quite bad... ;)
innerchord
Posts: 212 Joined: Wed May 11, 2016 12:00 am
Post by John Egan »
Thanks Rich and Innerchord. I will look for the TR5 :thumbup::thumbup::thumbup: Suite plugin later today when I am in the studio.
Regards, John
John Egan
Ah yes of course!
But, from memory, I think that only allows you to 'host' chains of plugins, and has the metering suite baked-in. I don't think it allows the metadata/exporting functions of the standalone. I could well be wrong on this.
Aled Hughes
Ah well, that part I don't know about as I don't use it myself. I just knew it was there :D
Rich Hanson
Ramirez wrote:[But, from memory, I think that only allows you to 'host' chains of plugins, and has the metering suite baked-in. I don't think it allows the metadata/exporting functions of the standalone. I could well be wrong on this.
You're right, but who wants to master from a plugin inside their DAW?
innerchord
Post by muzines »
innerchord wrote:You're right, but who wants to master from a plugin inside their DAW?
Well... iZotope Ozone users?
Actually, it happens all the time - it's not a workflow I like, but it's common for folks to mix/master all on the mix bus in the same project and deliver hard limited final mixes.
I much prefer to output a good mix, and then master separately, but then I'm a bit more "old school" in this regard...
muzines
Post by John Egan »
Rich and Innerchord, I have found the TR5 Suite plugin. I don't know how I missed it on several passes, but I obviously did. Thanks very much for the info.
I went for the TRackS 5 bundle because of a very positive earlier SoS review.
Regards, John
John Egan
Post by John Egan »
I wasn't looking to master in my DAW, but I currently use Sound Forge to master and burn CDs and wanted to do a comparison between mastering using TRackS 5 as a plugin within SF and TRackS as a stand-alone (which I thinkmay well give me greater flexibility).
Regards, John
John Egan
I meant using the file facilities of TR5. It doesn't make sense that you would want to compile and process tracks from within a track itself. I didn't mean applying master bus processing, which we all do.
innerchord
Well, I would really like if the plugin allowed me to create DDPs etc. from within Reaper without having to use the hack that’s currently implemented.
Something like Pyramix’s mastering (and 4-point editing) features would make Reaper close to perfect for me. But if a plugin could add that feature, why not?
Aled Hughes
