Does DSP have latency?
Re: Does DSP have latency?
Post by CS70 »
DigDug wrote:
CS70 wrote: As of the headphone out level, maybe a good idea is trying an interface out before buying it? Otherwise a little separate headphone amp like my headpod does the trick.
I'd love to do that but which retailers let you?
I only know of guitar center and that's if you have one close by to return in-store.
Ah, here shops tend to have the possibility, in terms of a dedicate studio space for the big ones, and a more "let's set up a computer with some material" for the small ones.
Doesn't hurt to ask..
Post by Music Wolf »
DigDug wrote:
I have a pretty low budget. I have my eyes set on the Steinberg UR24C that just came out a couple months ago
Have you considered the older UR242?
https://www.thomann.de/gb/steinberg_ur242.htm
DigDug wrote:My main complaint with my last interface(UR22mkII) was the headphone out was too weak. Hopefully they changed that this time around.
I don't know the UR22 or the new UR24C but the headphone amps on my UR824 are more than capable of doing some damage to you hearing. What headphones / impedance are you using?
Music Wolf
Posts: 2894 Joined: Fri Feb 17, 2006 12:00 am Location: Exiled to St Helens
Post by DigDug »
I have the Yamaha HPH-MT5w
sound pressure level: 100db/mW
Impedance: 51ohm at 1kHz
Max input power: 1600mW at 1kHz
I don't really know much about headphones, I just picked them cause they were white.
Is this decent?
DigDug
Posts: 17 Joined: Sun Apr 19, 2020 2:09 pm
I'm not familiar with the Yamaha's DD but nothing in the spec alarms me.
I'll see if I can find the spec for the headphone amp on your Steinberg AI and see how it compares with mine. It just woories me when someone says that a headphone amp lacks power that they are monitoring at too high a level.
Music Wolf
Post by tridelica »
CS70 wrote:
DigDug wrote:Okay, great! Very informative!
What about analog mixers with built-in effects?
Isn't that DSP as well?
Is that suppose to be instantaneous or is there still some latency because it is DSP?
Same! But too short for humans to notice.
There's some latency for analogue as well actually - the speed of EM waves in copper is finite! But of course is too small to be noticed by our brains in normal conditions.. try to send an analogue signal to the moon however.. :) (well, first you have to get a cable up there, which is not as simple as it sounds..)
That's what I hate about observing the night sky. The latency is just ridiculous.
tridelica
Posts: 7 Joined: Wed Mar 22, 2017 11:06 pm
Post by CS70 »
Well it's fine so long you don't have to play together with it.. :D
Post by ConcertinaChap »
CS70 wrote:For example, the relative balance between the guide base and the vocal monitoring is critical for them to pitch right while keeping control of articulation and expression, but only experienced vocalists will actively tell you (or even know) if the vox in the headphones is in the sweet spot or not.
Yes to all that. I've learned to spend time explicitly checking how they hear their voice against the music in their headphones. Once people get the gist of what I'm talking about they can get quite finicky :)
ConcertinaChap
Posts: 15240 Joined: Wed Jul 20, 2005 12:00 am Location: Bradford on Avon
Making music: Eagle Alley
I'm finding it hard to get right and I'm recording myself..... :blush:
