Which string library is this?
A few years ago, and in a different place... I used a string library (in Kontakt), where the legato articulations all displayed the delay required to place the body of the notes on the beat.
Which string library was that?
Re: Which string library is this?
The delay time for each instrument (bass, cello, viola...) was displayed in ms on the left of the window. It was a fairly simple interface...
Was it Sospiro Strings?
I don't see a ms timer shown, but it does show a bar and beat slider for sustain lengths. It also has a 'smart release' feature for swells so that on key release the playback jumps forward to a known offset prior to the beat in order to complete the swell: https://youtu.be/3fuMKDyEx6s?t=44
Posts: 9976 Joined: Wed Sep 01, 2004 12:00 am Location: Brighton & Hove, UK
Thanks, Eddy.
No it's not that one.
I had this library bought and installed on the old PC, but I've somehow lost it during an upgrade. I just cannot recall what it was. I think it looked a lot like Cinematic Studio Strings, but it definitely reported the delay time in ms for legato articulations when you loaded each instrument. It was a fairly simple interface IIRC.
I can't find it in my backups, and because I make it a point to render all instruments as audio it isn't referenced in any of my old songs.
I'm stumped - but I feel sure it's the library I need right now!
Post by BJG145 »
The Elf wrote:I think it looked a lot like Cinematic Studio Strings
I don't suppose it's this custom script someone put together for CSS...?
http://alexjevincent.co.uk/css-control-panel/
(I found it linked to this discussion about getting its legato in sync.)
Posts: 8085 Joined: Sat Aug 06, 2005 12:00 am Location: UK
Thanks. BJG.
No, this was definitely just an off-the-shelf library. I recall seeing a YouTube video where it was mentioned, but I've even gone back through my YT history to 2016 and I still can't see it.
This is crazily frustrating! :headbang:
Post by BJG145 »
The Elf wrote:I've even gone back through my YT history to 2016 and I still can't see it.
Wow, you have your YT history from 2016??
I securely erase mine every lunchtime...:beamup:
I have my history back to day 1 - it's been a life-saver!
Nothing on there I feel the need to hide.
Post by BJG145 »
FWIW this section of the CSS demo on YT has a slide showing the delay for each of its legato types.
https://youtu.be/veQCUb0kpMg?t=255
It’s not the delay time that is important to me. It is rather the content of that library.
Sent from my iPhone using Tapatalk
