X32 Compact to Logic Pro X help.
Post by Matt D »
Does anyone on the forum have experience of connecting an X32 Compact to Logic Pro x. I have the X-live card installed on the X32.
I've tried various methods and watched a whole pile of videos. I even tried to contact Behringer and I then found out they no longer have a technical support service, which was nice.
I'm more than happy to pay for someone's time to talk me through it over the phone.
Matt D
Posts: 75 Joined: Wed Sep 14, 2005 12:00 am
Re: X32 Compact to Logic Pro X help.
What is your difficulty? I don't use Logic but I do use Reaper on a Mac Pro so may be able to help.
Post by Matt D »
Sam Spoons wrote:What is your difficulty? I don't use Logic but I do use Reaper on a Mac Pro so may be able to help.
I have Reaper as a trial as well, so that would work fine.
Just basically, how I should set it all up, there are so many options and im pretty sure I have one option clicked wrongly. When I play a note on my synth, it comes into the X32 no problem, but it doesn't then seem to show up in the DAW.
Matt D
Basically if it works with Reaper it should work with Logic then.
In Reaper go to "Preferences/audio/device and select "X-USB", it should be available in the drop down menu, if not then check USB cable.
I use CH1-16 for instrument inputs and 17-32 for 'tape returns' so I have the card set to 16in/16out (setup/card on the X32C) and inputs 17-24 & 25-32 (routing/input on the X32C) assigned to 'card 1-8' and 'card 9-16'. It's possible to use scenes for tracking and replay/mixing if you need more inputs (set the card to 32in/32out). It shouldn't matter how the Mac 'sounds' are set as far as the DAW I/O is concerned.
See if that helps
Post by Matt D »
Sam Spoons wrote:Basically if it works with Reaper it should work with Logic then.
See if that helps
Thank you - I will give that a go and post back on here.
Matt D
Post by Matt D »
See if that helps
So when I play a note on the synth, am I supposed to be seeing some input on Reaper? The sound is showing up fine on the X32, but nothing on reaper at all. I have set repair to input 1 and chosen the X-Live option in audio preferences.
Matt D
Have you record armed the track? Reaper doesn't register an input signal by default unless the track is armed.
I've shut down the studio now and am away for a few days from tomorrow but if you're still stuck next week I'll have another go.
Have you connected your synth to channel one on the X32? I don't think you can reassign channels on the X32 to different computer outputs so you need to make sure the input channel you set on Reaper matches the channel you are using on the X32.
Also check the first and last channel settings in Reaper's Audio setup dialog (that's had me scratching my head for a while).
Post by Matt D »
Sam Spoons wrote:Have you record armed the track? Reaper doesn't register an input signal by default unless the track is armed.
Yep - armed the track etc.
Its okay, im going to take it back to Andertons tomorrow and change for an Allen and Heath Qu16.
I spoke to them today, and they were more than happy to talk me through the setup. There is probably just a setting on the X32 that is wrong, but as their customer support at Behringer is non-existent, I don't really want to get stuck.
Matt D
The issue is more likely with your DAW than the X32 but if not, and you have an analogue mindset, the Qu is probably going to be easier to get to grips with. Though Im a big fan of A&H kit I couldn't have lived with the Qu's limitations (limited routing, no LCD scribble strips, mega expensive peripherals etc), no regrets at all about going the X32 route after 6+ years.
Post by Matt D »
Sam Spoons wrote:The issue is more likely with your DAW than the X32 but if not, and you have an analogue mindset, the Qu is probably going to be easier to get to grips with. Though Im a big fan of A&H kit I couldn't have lived with the Qu's limitations (limited routing, no LCD scribble strips, mega expensive peripherals etc), no regrets at all about going the X32 route after 6+ years.
I think you are right and I would have been really happy with the X32 desk, if they had more comprehensive technical support. It was my first choice, but in the end, I am now using this as an audio interface to a DAW.
I will never need it for live recording or mixing etc, my use is purely personal and amateur. Its a hobby and so my requirement is ease of use for one by one channel layering.
So even without comprehensive internal routing, I will be routing to a DAW in the end, so I can change the input on each DAW channel, as opposed to having to route internally in the Qu16.
Having said that, give it a week and I might had got fed up with the limitations, next choice is the Soundcraft Si Impact. :headbang:
Matt D
If you are only recording one or two channels at a time and not using the mixer to mix through there is little point in having a mixer at all. A two or four input audio interface and, if you really need faders for ITB mixing, buy a small surface like an X-Touch.
Post by Matt D »
Sam Spoons wrote:If you are only recording one or two channels at a time and not using the mixer to mix through there is little point in having a mixer at all. A two or four input audio interface and, if you really need faders for ITB mixing, buy a small surface like an X-Touch.
I was thinking about that, but I can't see any other way to input 7 synths and 2 drum machines.
The Qu16 doesn't work either. When I go to system preferences>sound>input and choose the Qu16, I can see the signal from the Qu16, so the Mac is definitely receiving a signal from the desk.
But whatever DAW I choose, no signal is showing on the inputs. All of the 24 choices are there from the Qu16, but no signal is coming through. I've tried Cubase, Reaper and Logic
Ive enabled the tracks to record etc, but nothing. It's all very bizarre.
Matt D
Post by Dave Rowles »
Ok. Maybe run through some troubleshooting. You have probably tried this already, but it doesn't hurt to write it out point by point.
Firstly, is the QU set up correctly? I don't have that mixer (I use the X32), but you usually have to route the desk input channels to the correct USB output channels with Allen & Heath mixers. There's details of this on page 78 of the manual available here:
https://www.allen-heath.com/media/Qu-Mi ... 372_10.pdf
Once that's done we can look at logic. Hook up the USB to the mac and click on the speaker icon in the top right of the screen (volume and audio control). Does the QU pop up there as an option? If not, it's not connecting to the mac correctly, so either the desk is faulty, or your USB cable is faulty, or your USB port on the Mac is broken.
If you can see the QU on that menu then you can load up logic.
Once logic is open go: Logic Pro X > Preferences > Audio
Here you can select the QU as your input/output device.
Once you've done that you can create a new project and create a new audio track. Make sure the correct input is selected, then hit the red R button at the bottom of the channel fader. Level should appear.
It should be that simple, as Allen & Heath stuff is class compliant, so shouldn't need audio drivers or anything else on a Mac. If it still doesn't work then there's something really wrong somewhere, so you'll probably need to find someone who can help. Luckily you've bought a QU now. Allen & Heath, in my experience, are brilliant on their customer service, so I'd try giving them a call.
Dave Rowles
Posts: 1589 Joined: Thu Feb 28, 2008 12:00 am Location: Isle of Man
Post by Matt D »
Dave Rowles wrote:Ok. Maybe run through some troubleshooting. You have probably tried this already, but it doesn't hurt to write it out point by point.
Thank you for your reply and this is exactly the problem I am having. The Qu is showing up everywhere, Logic, the speaker on the top row of OSX, everywhere you look.
For example
I plug my iPhone into the Qu channels 1 and 2
play iTunes
Click on the speaker on the top row, change the input to Qu16
open preferences and click on the input tab, you can see the horizontal bar, labelled as "input level" and this is showing a healthy signal coming from the mixing desk and is moving left and right, like a normal meter should.
But no sound will come out of the internal speakers, even if I change the Output to "internal speakers" and move the volume slider around. Normally I don't have any problem with the Macbooks internal speakers. Im on Cantalina and the MacBook is only 4 years old, so this is all very odd.
And I suspect this is where the problem lies
Matt D
As you have tried an X32 and a QU with your Mac & Logic, it might be worth booking an appointment with a genius at your local Apple Store. Certainly worth a try Matt.
Posts: 13298 Joined: Thu Dec 05, 2002 12:00 am Location: Devon
Post by Matt D »
zenguitar wrote:As you have tried an X32 and a QU with your Mac & Logic, it might be worth booking an appointment with a genius at your local Apple Store. Certainly worth a try Matt.
good idea - I'm going to see if I can get a slot over the next week. I won't bother Allen and Heath just yet, as I think it would be fair to say there seems to be an internal problem with the Mac. The thing is, my wife's Mac has the same issue.
Would it be fair to say, that I should be able to choose the Qu16 as the input (on the speaker icon at the top of the Mac screen), and then choose internal speakers as the output - and hear the signal from the Qu16?
Matt D
Matt D wrote: The thing is, my wife's Mac has the same issue.
And that is precisely why it's worth getting a new set of eyes from a genius to contribute. It all points to a misunderstood or poorly explained setting in MacOS or Logic. Especially when OS and program developers work so hard to make the initial interface 'plug & go' for the bulk of users.
We are fortunate that for most hardware, computer, and software combinations plug & play 'just works' for the vast majority of users. But the downside is that when it doesn't 'just work' the solution is often something as simple as a tick box in the settings that is poorly documented.
Good luck Matt :thumbup:
Post by Matt D »
Thank you for all of your help. Can I just check something, before I make a Genius Bar appointment.
As in, the signal from the Qu16, which is showing up on the input level of the sound preferences, should be able to be heard from the internal speakers on the MacBook?
Matt D
Post by Matt D »
For anybody that is interested - this mystery is now solved thanks to Apple support. It took 3 different people at Apple to work out what the problem was .... and it is very simple.
Just so you know - I don't have a microphone and won't be recording vocals.
If you don't allow your DAW to have access to your internal microphone, you can't record an external signal on an Apple Mac. So the USB audio signal from the Qu16, was being seen by the MacBook - but it will not process the signal until you allow access to the internal microphone, via the security>privacy tab in preferences - for your particular DAW.
I asked why they didn't use the word "audio device", instead of microphone, but he wasn't sure.
So thank you to everyone for all of your help, as soon as I allowed Logic to have access to my internal microphone, the audio signal from the Qu16, came through loud and clear.
Something so bizarre, I never would have thought of it.
Matt D
Glad you got it sorted Matt. :thumbup:
Wow. That's a good obscure setting to know about. I use my internal mic to make audio notes in logic or to jot down ideas in random places out of my studio setup, so that's probably why I never thought twice about allowing logic access.
Dave Rowles
My MBP is on High Sierra and there is no option referring to the microphone in preferences/security/privacy (or any of the other security settings I can find. which OS are you using?
Post by Dave B »
I was just posting to check the Privacy settings for Microphone when I saw this second page - good that you found it and yes, it's crazy that the entire audio system is 'microphone'! We had exactly the same issue a couple of weeks ago with my brothers new mac and Garageband.
Dave B
Posts: 5935 Joined: Thu Apr 03, 2003 12:00 am Location: Maidenhead
Post by Matt D »
Sam Spoons wrote:My MBP is on High Sierra and there is no option referring to the microphone in preferences/security/privacy (or any of the other security settings I can find. which OS are you using?
Im using Catalina 10.15.6
So if you go to system preferences>security&privacy and then click on the privacy tab, scroll down to microphone - there isn't an option to click for reaper?
If there isn't, this would fit in with that the apple tech was saying about this being a new problem as Apple are becoming obsessed with getting users permission for everything, rather than just accepting that permission is given.
Matt D
