Music on cassette tape made easy
Exploring the tools and techniques for long-distance recording projects.
Post by Guest »
I've never heard my music on cassette tape before.
Is it possible that there is someone out there that can make me a cassette tape of my music,
so that I don't have to buy all the equipment to make a tape?
Obviously I'd pay for the tape and shipping it to me.
I know this seems infantile but the reality is don't kid me,
I know the facts about CD quality versus tape and how tape is inferior to all other mediums,
still,...
I've never heard my music on cassette tape.
Guest
Re: MUSIC ON CASSETTE TAPE MADE EASY
Post by resistorman »
What is interesting about linear formats like tape and vinyl is that it's not easy to skip around through it. This gave birth to albums and then concept albums. It takes a commitment of time to listen to the whole thing, and when it was well done it was a great experience. The medium itself imparted no magic, we learned to work around it and listen past it.
If you're interested in what the actual cassette medium would do to your music as far as sound quality goes; add a fair amount of noise, roll off the high end, smear the low mids, blobularize the bass, modulate the pitch, and slowly vary the phase between left and right channels. Enjoy.
resistorman
Posts: 2979 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
Post by Tim Gillett »
It really depends on how well the recording is made, on what equipment, tape, in what condition etc. There is no definitive "cassette sound". Done well, the cassette playback will probably be indistinguishable from the original for most listeners.
The sound here I recorded off TV to cassette in 1976. I wasnt aiming for super quality, just as a record of the TV show's music. Its main problem is probably tape hiss and saturation (distortion) towards the end when the band gets louder. BTW no restoration/enhancement done here.
https://youtu.be/KYFVx4gpe9c
Tim Gillett
Posts: 2706 Joined: Wed Jan 30, 2013 12:00 am Location: Perth, Western Australia
Post by HomerJSimpsson »
Beware of old tapes and cassettes. Through time, moisture from the air settles on the tape makeing it sticky almost like glue. Therfore its usualy much 'harder' to rewind old cassettes. Playing them put heavy load on the motor and mechanics, it can overheat and get damaged. You may even hear the music slowed down from the tape.
There's supposed to be a trick using a microwave to boil off the moisture, but I never tried that.
HomerJSimpsson
Posts: 5 Joined: Sat Mar 09, 2019 7:04 am Location: Sweden
"Oh why do my actions have consequences ?!" H.S.
Surely somebody has made a cassette tape simulator vst...
resistorman
My advice would be to buy a cassette deck, there’s plenty around, I love them, treat them just like an effects unit.
Posts: 21832 Joined: Sat Jul 12, 2003 12:00 am
Arpangel wrote:My advice would be to buy a cassette deck, there’s plenty around, I love them, treat them just like an effects unit.
Agreed. Presumably OP has the ability to play cassettes but not record them? Replay only systems, by and large are of inferior performance compared to a good Sony say, hi fi deck.
Posts: 19103 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
Yeah, one of the Tascam semi-pro decks would be cool, I’ve got a Tascam 3 head job, very reliable. Or grab yourself a Nakamichi...
https://www.ebay.co.uk/itm/NAKAMICHI-BX-2-Dolby-B-C-2-Head-Cassette-Deck-Working-Good-Condition/154032680436?hash=item23dd102df4:g:-6kAAOSw-OpfKH9K
Arpangel wrote:Yeah, one of the Tascam semi-pro decks would be cool, I’ve got a Tascam 3 head job, very reliable. Or grab yourself a Nakamichi...
Yes, nice. But the problem with buying a second(?) hand deck privately is that you have no idea of its state of wear. Cassette decks rely on precision head structures and alignment. Drive belts can stretch or go hard and lead to wow and flutter and accurate Dolby* replay depends critically on a flat frequency response and aligned levels.
Buying from a 'hi fi' dealer might get you a well serviced deck but of course you will pay extra for it. All that said, if a deck SEEMS ok and you clean the heads and trim the replay azimuth alignment for each cassette you will probably not be far out. Cassette was only ever 'jeeeust hi fi' and some would say not even that!
*If getting cassettes made I would ask for them NOT to be Dolby B encoded. With a modern(!) high output, low noise typell cassette, noise should not be a problem unless the music was of vast dynamic range.
HomerJSimpsson wrote:Beware of old tapes and cassettes. Through time, moisture from the air settles on the tape makeing it sticky almost like glue. Therfore its usualy much 'harder' to rewind old cassettes. Playing them put heavy load on the motor and mechanics, it can overheat and get damaged. You may even hear the music slowed down from the tape.
I think this MIGHT be a confusion with "Sticky Tape Syndrome" as it affected certain brands of OR tape?
I must have over 200 cassettes recorded some 40-50 years ago and whenever I pull one out to check it is always fine. These are a range of makes, TDK, Maxell, Philips, BASF, 3M, and a many strangers!
Post by CS70 »
Argiletonne wrote:I've never heard my music on cassette tape before.
still,...
Just FYI, we did a small run a few years back to sell at concerts. Used a printing plan someplace in the UK for a "two single" tape and pro sleeve printing and the costs were nothing crazy at all, some £150 equiv I guess. Super pro admin also, great guys. Can try and dig the plant name if useful.
I did have to buy an old walkman to listen to it tough - after a while I was given an old boombox.
As of how it sounds... it sounds just the same - at least on non-hifi stuff. To my lead ears, of course :)
Yeah the medium is far less capable but so it's the playback system and the point of well mixed and mastered music is that it survives pretty much intact. The two songs we put in were, so they did. I don't think there is such a thing as a "cassette" experience (other than the physicality of the thing). Nevertheless, they sell as hot cakes because of the novelty and physicality - bit like vinyl.
On the other side, I grew up listening to badly duplicated cassettes so probably I have no idea. :D
Re: Music on cassette tape made easy
Yes CS70, well recorded/reproduced cassette is very good and not at all 'niche' sounding.
When I first got my Sony Dolby S machine I carefully biased and calibrated some TDK SA and duped some CDs. I really could not tell the difference on my Tannoy 5A monitors.
Now that I no longer have a car with a cassette player in it I don't know what to do with my vast tape collection and two pretty good tape decks?
Seems such shame but "All things pass."
Post by Dr Huge Longjohns »
Of course. I have one and it's really good...https://aberrantdsp.com/plugins/sketchcassette/ I bought this because the UI was such fun to be honest, but it sounds fab too. There are free ones out there too which a quick Google will supply.
Last edited by Dr Huge Longjohns on Sun Aug 09, 2020 12:53 pm, edited 1 time in total.
Dr Huge Longjohns
Posts: 3953 Joined: Thu Apr 10, 2003 12:00 am Location: Gallifrey
So, what does it DO? Add hiss, W&F and some harmonic distortion?
But then I am a cynical old sod...
Yes. And it doesn't unravel all over the floor of your car.
Dr Huge Longjohns
Joo know! I have never had one do that! But then I never bought ***t cassettes!
Ok, sorry, it is just that I come from the era when there was great competition between just a few top companies to make THE best cassette decks and a few diehard reviewers like J L Hood kept the buggers on their toes!
Now! We have a recording system that is all but perfect and the ability to store zillions of albums on something the size of my little finger nail but we hanker after a technology that was basically imperfect to start with (dictating machine) and only by supreme effort was made about as good as a top FM broadcast! Except the latter did not have W&F if live!
Yes it's a funny old world but I don't believe it's all hype when people bat on about old analogue gear and distortion and the rest of it.
Character and atmosphere can transform a boring, perfectly recorded performance and give it an extra something for your ear and emotions to latch on to. The same way a slightly out of tune upright piano in an echoey church hall can sometimes sound sadder and more evocative than a perfect Steinway recorded in a perfect studio with mics costing as much as my car!
I think the hiphop innovators recognised this early on, when sampling old records was all they had. There's something about a gritty old LP and limited bandwidth sounds that are intrinsically atmospheric perhaps?
Dr Huge Longjohns
Post by nathanscribe »
Can't remember who said this or where I read it, but the conversation was about vinyl, and on being asked "why would you want to listen to something with all that surface noise", the response was "life has surface noise".
I'm on board with that. I think there's value in imperfection, and especially at a time when recording clarity is easy to achieve, compared to say the 90s or the 70s or the 50s, embracing some of the imperfection and instability and noise is part of the character of the experience.
Horses for courses, mind. I wouldn't go back to loading software from a C15 shoved in my Dixons cassette recorder. But I did buy an album on cassette from someone on Bandcamp a while back, and played it on an early 80s Technics component, and... it sounded, really, really good.
nathanscribe
Posts: 1566 Joined: Fri Jan 19, 2007 12:00 am Location: Wakefield, for my sins.
The seller of that one strikes me as someone who knows what they're on about. The rubber idlers are a weak point of the cheaper Nakamichis with the Sankyo mechanisms and are a bit of a pain to replace (I need to do it on mine by haven't plucked up enough courage to take everything apart) so it is good to know that they've been replaced.
Normally I'd echo the suggestion to buy something used but many cassette deck drive belts seem to have a lifetime of only 15-20 years so you may well need to be prepared to replace the drive belts if it hasn't been done already.
Posts: 16950 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Post by muzines »
There's quite a few tape/cassette simulation plugins in various flavours. u-he's Satin will do it, and this one is quite nice:
https://www.wavesfactory.com/cassette
muzines
I know what you mean about "courage" James. About two years ago I found the capstan belt on my Sony had 'melted'. Got a set no bother at all but the job of fitting them was MUCH trickier than I remembered when I did it for a living forty odd years ago!
I almost got to the point where I would have to take the 'bag of bits' to a hi fi shop and grovel. Fortunately, one last stupendous effort got the job done.
My stance on "imperfections" and grunge are that I doubt Bach would have been happy playing a harpsichord recital accompanied by the equivalent of half dozen chaps hissing on a tin roof!
And why do even Heavy Metal producers spend hours making sure of tunings if it is ok played on a wowing cassette deck?
But, there's no accountin'f folk!
I like that a lot! :thumbup: We all know how sometimes you can make a positive difference to a mix by putting an almost inaudible background pad or sound fx underneath everything. It's like that room tone thing that some engineers swear by. Just an almost imperceptible little bit of sonic filler that our ears seem to like. Glue reverb etc etc. Maybe, as the quote suggests, we're so used to the surface noise of life that it sometimes seems unnatural to hear something without it? My personal view is also that our brain craves movement in sound, as it does in vision. So tiny bits of wow or flutter or hiss that come and go stop our attention switching off. We're programmed by evolution to notice change, sabre-tooth tiger twitching a leaf in our peripheral vision and all that. Nothing more boring than a perfect sine wave.
Dr Huge Longjohns
But I doubt he would have been happy playing it in an anechoic chamber either!
Dr Huge Longjohns
ef37a wrote:I know what you mean about "courage" James. About two years ago I found the capstan belt on my Sony had 'melted'. Got a set no bother at all but the job of fitting them was MUCH trickier than I remembered when I did it for a living forty odd years ago!
I've done an Aiwa ADF450 and a Tascam 112 recently - the Aiwa was easy while the Tascam was a bit more complicated and a Youtube video helped. The Nakamichi seems more difficult than those. I've got a couple of others that need doing too.
Post by CS70 »
I agree with the spirit, but thing is, these micro-movements are like 0.001% of the result.. I mean you cannot take a boring song and magically make it sound good because it's on vinyl. It can be cooler, but the music (and the mix) don't get better in any way.
The surface noise thing is cool to read but a meaningless slogan.. there's no fun in racing a slower car (but it's more fun to race a faster car with a noisy gasoline engine than an electric one, any time of the year and twice on Sundays!!). It is just a head game, a fun self delusion (and by all means, nothing wrong with it, self delusion is essential to life.. anyone being totally rational would sucide in 30 seconds flat).
Sonically it's not even like the icing of the cake, it's like having bought the eggs for the icing from an eco farm feeding hens only with Bulgur grain and picking them up between 4:00 an 5:00 in the morning. Makes a difference? Sure does..
One of my band' songs has a simple lyric video, whose background consist on a old deck playing an even older vinyl record, suitably blurred. The recording is, of course, a state of the art digital one which has never seen a (non-virtual) master tape, to say nothing of a vinyl pressing plant. It has, also of course, all the tricks I know to make it sound the opposite of sterile and "digital", including the right amounts of mains hum, tape printing and so forth.
Nevertheless it's as digital as they come. And yet you can't believe the amount of feedback I've got by people stating without question that "the vinyl sound is really making a difference", "nothing sounds as good as vinyl" and suchlike.
I politely nod and thank said people - I truly do appreciate the attention, of course - and I am continuously reminded on how pop music has as much to do with image than with substance.
