Recommend a NS10 Amp?
Re: Recommend a NS10 Amp?
I'd get what they called the Brian Lucey Mastering Amp which is just their 150w a side amp in an enclosure with balanced IO. It was specified by Brian. They will also do 250 per side for a hundred bucks more in the same box, but you'll find the 150 a side sounds very 'relaxed'
J
J
- Jack Ruston
Posts: 3847 Joined: Wed Dec 21, 2005 12:00 am
Posts: 43512 Joined: Fri Jul 25, 2003 12:00 am
That's the one...they changed the name.
If you're ever near Hove, Hugh, give me a call and come and have a listen. Nice amp.
J
J
- Jack Ruston
Thanks J, I will -- I often visit friends in Haywards Heath and you're not far from there...
Hugh Robjohns wrote:I'd Rather Play wrote:Unfortunately the responses here are similar to what I've already got from friends and colleagues, That is people recommend old discontinued amps or hard to source equipment.
Unlike some here, I actually found the Quad 405 (hifi) or 520 (pro) amps worked very nicely with NS10s. Yes, they are discontinued, but they are easy to source second hand, built like tanks top last a lifetime, easy to maintain, and Quad will still service them to as-new condition for astonishingly little outlay, if necessary.
if you want something new, then the earlier suggestion of Class D amps in the US is a good one -- I've heard other positive recommendations for them -- and you can save money by building a kit yourself, or buying one ready made. Different mains voltages and balanced/unbalaned input options are available.
http://classdaudio.com/complete-amplifiers/custom-built-amplifiers.html
Failing that, I've had good results over the years with Rotel hifi power-amps...
http://www.rotel.com/UK/products/index.htm?cat=112
hugh
Hi all, just got my first NS-10s and was looking at the Class D amps however the links above no longer work. It also looks like ClassD no longer offers completed amps... just kits.
Is this the kit to get... huge....James... ?
Also can someone explain to me what I am looking for in wattage? I’ve seen amps recommended but the wattages are all over the place? Still trying to wrap my head around these speakers.
Lastly sorry for all the questions but have any new amp developments come to light since I am reviving this post from many years ago?
Appreciate you all for the info.
- ablethought
New here - Posts: 6 Joined: Thu Aug 13, 2020 1:12 pm
The NS10 really isn't that fussy about the power amp. There's lots of decent second-hand pro and good hi-fi amps around that would do a good job. If you want to go down the (generic) class-D route then look at the Hypex modules and kits.
Hugh Robjohns wrote:The NS10 really isn't that fussy about the power amp. There's lots of decent second-hand pro and good hi-fi amps around that would do a good job. If you want to go down the (generic) class-D route then look at the Hypex modules and kits.
Thanks for the reply Huge! I was under the impression NS10s are very picky. I hear people talking about nothing under 125 watts a side etc..
Anyway, I have a few Power amps kicking around the studio but none of them where mentioned in any post I saw... probably because there all on the cheaper budget side.... would any of these do a decent job?
Crest Audio LA-901
https://www.yumpu.com/la/document/read/ ... rest-audio
Behringer KM1700
https://www.behringer.com/behringer/pro ... Code=P0BRJ
Crown XLS202
https://www.crownaudio.com/zh/product_d ... asheet-pdf
if not would your recommendation be to go new or something used if I had between $300 - 500 usd to spend? Any suggestions?
I appreciate your thoughts on this so much... so much chatter out there on the subject.. makes my head spin.
- ablethought
Arpangel wrote:Secondhand Quad 405? At laser you’d be in period, they were quite popular with the NS10.
Okey, I see them. Decent price. I see that there are also new clones... any thoughts on those?
- ablethought
Any thoughts on the original Bryson 3B? Not the ST or SST version... the older 3B. They any good with the Yamahas?
- ablethought
Maybe I was unlucky but the Teac amp that we had in the studio really brought out the worst in them.
I haven't tried a new 405 clone although the modules are so cheap that it seems tempting. However, having just done a little searching, it appears that they are based on a very early version of the 405 and suffer from all the disadvantages such as high noise levels and a mistake in the Zobel network routing. I'd prefer to go for a genuine 405-2.
Posts: 16842 Joined: Mon Sep 10, 2001 12:00 am
James Perrett wrote:Hugh Robjohns wrote:The NS10 really isn't that fussy about the power amp.
Interesting, clones no good then. 405-2 is the right model.
- ablethought
One other thought - if you are into DIY you could always remove the insides of the Crown or Crest amp that you have already and replace them with Hypex modules which should be within your budget. I did a similar thing with a noisy 405 a few years ago and it cost me around £250.
James Perrett wrote:One other thought - if you are into DIY you could always remove the insides of the Crown or Crest amp that you have already and replace them with Hypex modules which should be within your budget. I did a similar thing with a noisy 405 a few years ago and it cost me around £250.
Don’t mind doing that at all. Can you link me to what you used?
- ablethought
ablethought wrote:James Perrett wrote:One other thought - if you are into DIY you could always remove the insides of the Crown or Crest amp that you have already and replace them with Hypex modules which should be within your budget. I did a similar thing with a noisy 405 a few years ago and it cost me around £250.
The closest that I can find to my setup is 2 of these
https://www.diyclassd.com/product/ucd180hg-with-hxr/5
coupled with one of these
https://www.diyclassd.com/product/smps400a180/138
and the matching power supply cable set (I think I made my own amplifier cable set).
They only sell the upgraded amplifiers now which adds around 60 Euros to the total cost compared to my build.
I’d say you want to steer clear of lean sounding bright amps, the 405 is fine, it’s got some grunt and isn’t too bright. Audiolab 8000A is another one to consider, very nice amp, quite neautral.
Go on ebay or your local pawn shop and look for high quality old stereo equipment.
There is some great stuff out there.
For example: https://www.ebay.com/itm/Rotel-RA-02-St ... SwqfVfMDK1
- DC-Choppah
Posts: 2054 Joined: Fri Jul 20, 2012 12:00 am
James Perrett wrote:Maybe I was unlucky but the Teac amp that we had in the studio really brought out the worst in them.
Intriguing... define 'worst in them' please!
That seems a disappointing cockup. Which clones are these? I think there are a number of different ones about aren't there?
It was a Teac AX75 amp Hugh - originally sold by Thatched Cottage Audio to partner the NS10's. Plenty of power but with an exaggerated high end.
I just did a quick Ebay and Google search where it seems that the Chinese 405 modules are often proudly sold as Mk1 modules with NOS 301 op amps. Other forum comments turned up the issues with the early modules and mentioned the fact that the design was taken from a published article which presumably gets around any legal issues. I see there are also a few that are marked 405-2 which, if they are accurate copies, will have overcome these issues although they possibly could do with a few mods to optimise their sensitivity for studio use.
Hugh Robjohns wrote:Unlike some here, I actually found the Quad 405 (hifi) or 520 (pro) amps worked very nicely with NS10s. Yes, they are discontinued, but they are easy to source second hand, built like tanks top last a lifetime, easy to maintain, and Quad will still service them to as-new condition for astonishingly little outlay, if necessary.hugh
A bit late as I've been travelling down to the coast but Quad were not remotely interested in fixing my 522, or advising the engineer who was attempting to fix it (he failed). Thankfully Folderol has sorted it out for me (I have yet to plumb it into the studio and my period correct Kef 104ABs, sorry Foldy
OTOH, I did buy a mint condition StudioSpares Titan 600 off ebay for £65 delivered a few weeks ago so bargains do exist.
Forum Aficionado - Posts: 22746 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Hello, I am a newbie here:-) However, I have read SOS magazine for over a decade, so I thought what better place to come to get advice regarding my next home studio purchase?!!
I am in the market for a new amp to drive my NS10’s. I have previously used Hifi Amps with them, but I have been looking for something with balanced inputs (which my current Yamaha AS301 amp does not have). I don’t personally have any experience with using the NS10’s on more expensive or vintage amps, but I have visited a few studios that have and based on my research I am learning more and more about them and it appears the amp does make all the difference to how these speakers sound……Or does it?!
So it’s interesting to now see here that the NS10’s are not really fussed by the amp they use! I have been following Hugh Robjohns articles for many years and so know he is very well versed in this area and he knows his stuff! So, I cannot simply overlook what he says. I am therefore now wondering whether the investment I was considering is really going to make a huge difference like I have read it would?! I was considering the Avantone CLA-200, but I would be really interested in hearing from anyone that uses it or has used it in the past. Or from anyone that could recommend a suitable alternative. I am in the market for a brand new unit and don’t require it to have DSP, but balanced inputs are a must!
Many thanks in advance
- Angelface78
Poster - Posts: 40 Joined: Sat Sep 18, 2021 10:56 pm
If I was in the market for a new amp now I'd see if I could find one of the Monacor or IMG Stageline STA-400D amps. I'm not sure if they are still current but the electronic design looks almost identical to the monitor amps that I built from Hypex modules.
https://monacor.co.uk/sta-400d.html
They're amazing value for money (assuming that they haven't messed anything up in the additions that they've made).
If you like the sound of your current amp, just add an ART Clean Box, instant balanced inputs, and a cheap solution.
I did this with my Quad amp, works perfectly, gets rid of all the noise and hum.
James Perrett wrote: ↑Sun Sep 19, 2021 1:46 am If I was in the market for a new amp now I'd see if I could find one of the Monacor or IMG Stageline STA-400D amps. I'm not sure if they are still current but the electronic design looks almost identical to the monitor amps that I built from Hypex modules.
Thank you so much for your response James Perrett, I really appreciate it. Although, I am not very familiar with the brand of amps you have recommended I did have a look and they are significantly cheaper then the Avantone CLA 200 that I was considering, which is great. But I am still a little confused concerning Class D amps as my research consensus was mostly to steer clear of them as they often introduce noise and require some sort of int built noise filter etc. I am clueless in this area so maybe you could explain this?! Once again thank you for your help thus far and I welcome any further help and/or advice you might be able to provide.
- Angelface78
Thank you Arpangel for your input, which I am very grateful for. Now this sounds interesting!! Now in answer to your question as to whether I already like the sound of my amp. I cannot say I dislike it, but since researching the topic it got me wondering whether I am getting the best sound from my NS10’s due to the current amp choice. If the choice of amp is not going to hugely change the sound of NS10’s then I would rather not have that huge outlay and instead would purchase a subwoofer!! You have given me food for thought-which I am appreciate. I have had a quick look at the Art clean box pro. I wasn’t aware that such a box existed, but I am intrigued!!
Currently the line 1 inputs of amp (rca) are connected to my monitor controller output for NS10’s -using rca -trs leads. Therefore, how would I incorporate this into my setup? Sorry if this is obvious, but I just a little unsure.
- Angelface78
