Best USB Microphones for Music
I'm not even sure if this is the right category to post this in... but what do you all recommend for a good quality USB microphone?
I've been using Zoom for the last six months for vocal lessons, a few impromptu music performances, etc... but the quality of the sound from my webcam microphone is not good (it's fine for normal conversation, but if I start playing guitar/singing, it sounds like I'm singing through some sort of filter... it gives off almost a robotic sound if that makes any sense!).
I do have an Aston Stealth mic, which is exceptional for recording on DAW's such as Ableton, etc..., but it has an XLR plugin, so I can't exactly plug it into my computer to use for video calls (I tried it earlier, to no avail).
My dad has an older-model Samson G-Track USB mic, which is pretty good quality... but it is about 10 years old so I would definitely want something even a bit newer.
- anna-marie music
Poster -
Posts: 46 Joined: Tue Jul 21, 2020 5:55 pm
I've always had a passion for music. Influenced by the likes of Michelle Branch, Kelly Clarkson, and Mandy Moore; my music style is alternative pop based with a little hint of country.
Re: Best USB Microphones for Music
How do you get the signal from you Ashton Stealth into your DAW? I'm assuming you have a USB audio interface of some kind (or similar), if so that would be the way to make the same mic usable for zoom meeting audio.
Forum Aficionado - Posts: 22916 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Sam Spoons wrote:How do you get the signal from you Ashton Stealth into your DAW? I'm assuming you have a USB audio interface of some kind (or similar), if so that would be the way to make the same mic usable for zoom meeting audio.
I use the Focusrite Scarlett 2i2 (3rd Gen I believe it is?) interface with my DAW. My webcam is a Logitech C920... I tried switching the default microphone in the sound settings on my computer and didn't have any luck with it (couldn't get the sound to work)... but now that you mention it, I may try this again and see if I just happened to select the wrong settings or something
- anna-marie music
Poster -
The Stealth into the Scarlett will appear the same to the computer as a USB mic (which is just a mic and USB interface in a single unit). It should be possible to make the Scarlett work as a zoom audio source.
Dunno if it's "the best" because it's the only USB mic I have, but I'm pretty happy with the Blue Yeti I use for my office computer + laptop. It's multi pattern (cardioid, omni, stereo + bidirectional). not crazily expensive, and sounds decent for the price. I use it it for much the same tasks as you describe - a general computer mic rather than a "recording" mic.
I have a Blue Bluebird in the studio too, which can be a useful vocal/ general purpose cardiod.
They're both quite bright sounding mics, but that's not necessarily always a bad thing.
Fishnish wrote:Dunno if it's "the best" because it's the only USB mic I have, but I'm pretty happy with the Blue Yeti I use for my office computer + laptop. It's multi pattern (cardioid, omni, stereo + bidirectional). not crazily expensive, and sounds decent for the price. I use it it for much the same tasks as you describe - a general computer mic rather than a "recording" mic.
Thank you for the recommendation
- anna-marie music
Poster -
Deleted
- Mike Stranks
The Korff wrote:You might find this article helpful:
https://www.soundonsound.com/reviews/ch ... microphone
Thank you!
- anna-marie music
Poster -
Are you running Zoom on a pc, a mac or ipad/tablet? I think it affects what you can do in terms of selecting inputs and outputs. E.g. on my last Zoom conference I had the video coming from the website, the audio in coming from one interface and the audio out going to a second interface, all easily selectable within zoom.
But I think if you're on a tablet the options are more limited.
Posts: 29722 Joined: Sun Jul 05, 2015 12:00 am
- Guest
Worth having a scroll down this article: https://www.soundonsound.com/reviews/ch ... microphone
It's aimed at podcasting but a lot of it transfers and there's a useful list of mics at the end.
https://soundcloud.com/user-157646387/u ... iving-room
Hope that works, first time of trying!
For those on a tight budget that mic is commonly available at £20-30 and is really nicely made. Citronics CCU3.
My son is playing in his flat in France. The place has a high ceiling he tells me and the microphone is about 1mtr from him.
He is waiting for the Mackie LDC PW was quite taken with in the August issue but they are back ordered until mid October. That will go into a Behringer UMC204HD.
