Thr 30 II and piano record
Hello ! My first post here , i al totaly newbie in recording subject . Want to record piano and guitar song , but getting issue with multirecording , is it posaible to record first my guitar with thr30ii yamaha then connect a piano and record as a second track . How can i make itnpossible ??
Re: Thr 30 II and piano reco
mkk8741 wrote:Hello ! My first post here , i al totaly newbie in recording subject . Want to record piano and guitar song , but getting issue with multirecording , is it posaible to record first my guitar with thr30ii yamaha then connect a piano and record as a second track . How can i make itnpossible ??
I understand that the THR3011 is also an audio interface, with an auxiliary input, if it allows you to record using the aux input you could record the piano that way, and make sure you use the correct lead, mono, or stereo, depending on the input, to mini-jack plug.
