British pedals?
British pedals?
Seem to be a bit rare, seems to be a lot US/Canadian "boutique" activity, also Japan, as usual, and a few in Europe, but off the top of my head, I can’t really think of any British stuff, apart from a couple of high-end bespoke outfits.
Re: British pedals?
There's Thorpy https://thorpyfx.com/
Anything UK built is going to be relatively expensive (or boutique as they like to put it) due to the labour cost.
Give me a decent multi fx unit any day.
- Music Wolf
Posts: 2894 Joined: Fri Feb 17, 2006 12:00 am
No One There
https://starbelly.bandmule.com/
Re: British pedals?
Music Wolf wrote:There's Thorpy https://thorpyfx.com/
Really nice guy, too. He's worth a call before you make any pedal-related decision.
Re: British pedals?
His stuff looks very interesting, I’m after a good overdrive/distortion, but I’m not having any luck, it’s getting one that progressively cranks things up, slowly, with a valve like tone, doing things quietly but the tone is like full on, it’s difficult.
I’m checking out the Thermionic Culture Vulture, but it’s not a pedal, it’s big, and it’s b****y expensive.
Re: British pedals?
Is this a distortion for guitar, or are you applying it to keyboards?
- Music Wolf
No One There
Re: British pedals?
Music Wolf wrote:Is this a distortion for guitar, or are you applying it to keyboards?
Mainly keyboards, but sometimes guitar.
I’m looking for a really dirty valve type distortion, but with control, just hovering on the edge, I’ve noticed a lot of pedals don’t have enough adjustment, they suddenly go wild and that’s that.
Re: British pedals?
Not sure whether I'd call it "valve" sounding, but my Moog MF Drive is a nice bit of kit, I find it does that middle ground really nicely. Although I've just had a quick look and I'm not sure they're making them now, so might be a search around second hand job.
Re: British pedals?
Luke W wrote:Not sure whether I'd call it "valve" sounding, but my Moog MF Drive is a nice bit of kit, I find it does that middle ground really nicely. Although I've just had a quick look and I'm not sure they're making them now, so might be a search around second hand job.
Yes, this is something I’ve been trying to sort out for ages, with no success, trying out things isn’t easy, with a keyboard, maybe a bit easier with a guitar.
Re: British pedals?
Not really spam because I have no connection with them anymore,Blackstar Amplification make two ranges of pedals.
The first is the "HT" range so called because they use a 12AX7 valve run at a proper, hurty 300V supply. The "LT" range are designed to be close to the HTs but run from the conventional 9V battery or wall rat.
Yes, the pedals are made, very well, in the far east but the design is 100% home based guitar mad brains.
The HT range was reviewed in SoS a few years ago.
Re: British pedals?
ef37a wrote:Not really spam because I have no connection with them anymore,Blackstar Amplification make two ranges of pedals.
The HT range was reviewed in SOS a few years ago.
Thanks Dave, I’ll check this out.
I was happy at one point with my old and long gone Boss SE50, that had some great distortion and overdrive sounds, that were very controllable, very, very underrated unit in this respect.
Re: British pedals?
Raygun FX based on Essex do a mix of mods and own line, I was going to send my Rat over but in the end I found in could sell it and get a Mooer Black Secret with change to scratch that itch when needed.
http://fuzzboxes.co.uk/
I've a Blackstar HT Drive, personally always found it a bit too much gain for me but it does work as a very nice valve preamp into an interface. I did fit a 12AT7 in mind which calmed it down (but Dave has rightly pointed out the various concerns on doing this in the past so change at caution).
Hewesy
Hewesy
Re: British pedals?
Arpangel wrote:Music Wolf wrote:Is this a distortion for guitar, or are you applying it to keyboards?
Maybe use the pedal in parallel rather than series?
You could treat the keyboard as if it was a guitar and run in through an amp, might get you in the ballpark for a grungy synth lead sound?
- thefruitfarmer
Posts: 639 Joined: Wed Sep 01, 2004 12:00 am
Re: British pedals?
Thorpy v well regarded, I can personally recommend the Frederic effects stuff, also Zander effects.
I think Hudson electronics are British too.
Re: British pedals?
thefruitfarmer wrote:Arpangel wrote:Music Wolf wrote:Is this a distortion for guitar, or are you applying it to keyboards?
Thanks, I have a Roland amp and that’s what I’m using right now, it’s got a line out so it’s fine for recording, I may just stick with this until I can find something else.
Re: British pedals?
I have 4 Effectrode pedals (but you may think they are one of those "high-end bespoke outfits"?)
Regardless, great pedals and great customer service!
Effectrode
p
Effectrode
p
Re: British pedals?
Re: British pedals?
Hewesy wrote:Raygun FX based on Essex do a mix of mods and own line, I was going to send my Rat over but in the end I found in could sell it and get a Mooer Black Secret with change to scratch that itch when needed.
Hewesy
The pedals are great but the customer service sucks, sent a pedal back twice and first time it wasnt fixed then paid to send it back a second time and I have had no response when I’ve asked about whats happening with it. Sent it back in April.
Another vote for fredric, have the howling fuzz and grumbling wolf on my board, the wolf is amazing for distortion with old tube amps.
Re: British pedals?
al_diablo wrote:Just a thought on this - do you stack gain pedals (or use multistage ones)? It usually gives a more controllable sound than just using one.
Good idea, I’ll look into that.
Re: British pedals?
Oh that's shocking, I never got to actually order as I moved to the Mooer but that is pretty poor.
The guy replied quickly when I enquired about the mod but perhaps that's not a suprise as it was pre-sales.
Hope you get it sorted
Hewesy
Re: British pedals?
Hamstead Soundworks do some good stuff. I think it's made in the UK (like their lovely amps!)
https://www.hamsteadsoundworks.com/pedal-navigation
- Matt Houghton
Frequent Poster - Posts: 1603 Joined: Wed Aug 08, 2007 12:00 am
SOS Reviews Editor
Re: British pedals?
Hewesy
Pre sales it is fantastic as I was going to get a line of custom pedals done and we had talked at length about it but after my first bad experience I scrapped that idea and now well into my second I am still waiting for my pedal and have no contact and cant get a reply and he has had my pedal since april.
