Tomás Mulcahy wrote:Tim Gillett wrote:Practitioners have been adjusting pre decoder gain for a long time.
This is (another) good example of your selective reading.
We can all be selective at times. If you can show me where I've been selective I'd be grateful.
Tomás Mulcahy wrote: I did mention the technique in my first post...
Yes you seemed to refer to play trim. I've just read that post in detail. Glad you are aware of it and its importance in achieving Dolby tracking.
Tomás Mulcahy wrote: Perhaps I wasn't clear in the post you're quoting, so I'll clarify. The clever bit I was referring to in James's post is doing the transfer without decoding, and leaving the level adjustment, with decoding, to the Uhe plugin afterwards.
Sure, but again that's hardly new. I started doing this many years ago with an outboard hardware analog decoder (gain staging needs to be done well) and I'm sure others did it well before then.
The only difference here is using a software decoder rather than a hardware.
Software is easier but it still needs a "home" reference IMO. Whenever I used this technique I always recorded in the file a reference tone for Dolby level, 200 nWbm from the playback machine which itself was well calibrated. Even if the actual recording doesn't strictly line up with Dolby level tone, the transferred 400Hz tone is a baseline of sorts from which to branch out, gain up or gain down.
You're already familiar with the "play trim" principle. The input gain adjustment is important too as Hugh mentioned. The two together are IMO the standard tools for this. Both are often needed although often it's the "play trim" type of tool which is more decisive because as we know many cassettes are vulnerable to loss of highs. Knowing that, (I'm speaking generally here, not to anybody in particular) why persist in just adjusting overall input gain? It makes no sense. If the tracking problem seems mainly due to a loss of highs, try and correct the highs with EQ. Target the actual error. Don't simply adjust overall gain. It will only introduce another error. (Happy to explain that if needed). Glad you're aware of both adjustment methods.
Tim
