New hard drive not seen device manager, possibly damaged ?
Post by Marbury »
I have just taken receipt of a brand new WD 500GB Blue hard drive which was a steal at £18 from OnBuy.com. I want it to clone my C drive onto for backup if my SD drive ever fails.
Unfortunately I can not get my PC to see the drive , even the cloning software can't see it. I have one of those quickport combo gadgets for slotting the drive into and connecting via usb which has worked with other drives perfectly well. I will say that it's spinning quite nosily and when I arrived home, the Fedex courier had shoved it in the letterbox half in and out with only a jiffy bag as protection. I had my doubts then but gave it a try.
Is it likely to be goosed ?
Marbury
Posts: 1136 Joined: Thu Aug 28, 2003 12:00 am Location: Cheshire, UK
Re: New hard drive not seen device manager, possibly damaged ?
Marbury wrote:I have just taken receipt of a brand new WD 500GB Blue hard drive ... it's spinning quite nosily and ... only a jiffy bag as protection.
Yes, it is very likely. A jiffy bag is completely unsuitable for shipping a hard drive, unless that jiffy bag is enclosing a box completely lined with shock-absorbing foam within which the drive is nestling securely such that it cannot 'rattle around' in there.
I've had hard drives shipped to me in jiffy bags twice in the past and on both occasions I refused delivery and got refunds after informing the seller that it's insane to send them like that.
Posts: 9975 Joined: Wed Sep 01, 2004 12:00 am Location: Brighton & Hove, UK
Post by wireman »
It might be a better test to plug it directly into a PC but given the worrying fact it was not protected properly in transit even if it works do you want to rely on it for your backup?
The last drives I purchased of that size had no packaging (OEM) but they were encased in balls of bubble wrap and inside a box.
I would reject the drive as faulty, ask for a refund or replacement and if possible say you can make the drive available for collection.
wireman
Posts: 804 Joined: Fri Dec 17, 2004 12:00 am
Post by Marbury »
Thanks. Seems like a sensible option given the fact it will be used for backing up..
Marbury
Post by Marbury »
I have been given these instructions on returning the drive by the company who sent it poorly packaged.
We will not accept liability for packages damaged during transit. You are advised to package the product adequately to prevent this happening.
The irony
Marbury
You should include a copy of the dictionary definition of irony in your returns note. :D
Posts: 29713 Joined: Sun Jul 05, 2015 12:00 am Location: York
Post by OneWorld »
Marbury wrote:Thanks. Seems like a sensible option given the fact it will be used for backing up..
There is a possibility that the drive has not been partitioned. Check it in Disk Management (just type Disk Management into the Win10 search slot)
Make sure you are going to apply any changes to the right disk - perform any operation on the wrong disk and any data can be gone for good
There are also freeware tools such as AOMEI Partition Tool or Minitool Partition Wizard that are a bit more intuitive.
That said, if the disk arrived just packed in a Jiffy Bag then that is inadequate packing
OneWorld
Posts: 5958 Joined: Tue Apr 07, 2009 12:00 am
Post by Marbury »
It could well be that it needs partitioning but I don't want to take the risk of it failing later down the line, especially as it seems noisier than it should be when spinning.
Marbury
Post by OneWorld »
Marbury wrote:It could well be that it needs partitioning but I don't want to take the risk of it failing later down the line, especially as it seems noisier than it should be when spinning.
Yep, if it’s noisy then send it back. Sometimes the clicking noise a drive makes is the read/write head re-seeking and can be reset, but there is no guarantee it will be a permanent fix, so yep best send it back.
OneWorld
Post by Marbury »
Can anyone please suggest the best type of drive to get for just a basic backing up of the main c drive, and possibly supplier that packs well ?
Marbury
Post by Philbo King »
For backup I use an external WD 2TB USB drive that cost me $50 new. I use free backup software call Macrium.
Philbo King
Posts: 383 Joined: Thu Oct 11, 2018 10:07 pm
Post by Marbury »
Philbo King wrote:For backup I use an external WD 2TB USB drive that cost me $50 new. I use free backup software call Macrium.
Ok, I thought that you can't back up a main C dive on a usb drive, only an internal via a HDD docking station. I would only need a 500GB drive as this is the capacity of the drive I will be cloning.
Marbury
Post by billc2 »
I can recommend Scan, I've had drives from them in the past and they were packaged beautifully.
billc2
Posts: 160 Joined: Tue May 27, 2014 12:00 am
Post by Wacka »
Have you right clicked on this PC icon and chosen Manage ?
There you will be able to go to disk management and activate any new drives to make them visible.
Worth a go
Wacka
Posts: 17 Joined: Wed Feb 26, 2003 12:00 am Location: Liverpool
Post by Marbury »
I have a new WD 1TB drive I have just received from a professional company that packs well. Still the PC doesn't see the drive, even if I right click on PC and disk manage. Nothing dong.
Marbury
Post by Marbury »
I wanted to amend my last post but SOS forum seems not to allow edits after some time which is a bit strange.
Anyway, I have managed to format my new drive which now shows in "This PC" The problem now is AOMEI cloning software does not see it. I am stuck.
Marbury
Post by Nazard »
I am unfamiliar with AOMEI, possibly it doesn't recognise the file system you formatted the disk with, although you probably formatted the disk as NFTS, which it should recognise.
For disk cloning I use the free version of Macrium reflect and never had any issues with it.
https://www.macrium.com/reflectfree
For backup I use SyncBack, which has an excellent free version
https://www.2brightsparks.com/syncback/ ... k-hub.html
If you stick to those you should be OK, although I am not saying that there aren't equally good products out there, but I don't use them.
Nazard
Post by Marbury »
Trevor Johnson wrote:I am unfamiliar with AOMEI, possibly it doesn't recognise the file system you formatted the disk with, although you probably formatted the disk as NFTS, which it should recognise.
Thanks but I was looking for something free that I am not tied to paying for once the trial is over.
Marbury
Post by OneWorld »
Sorry to be so direct but might I suggest you read the content of the products' website fully. Both Macrium and SyncBack offer totally free to use as well as 'free to download - trial' versions of their software. And those free versions are very good. I have used both for longer than I care to remember. Both products are regularly updated by the respective companies. All you need to is look at all the web-pages for the options systematically and you'll drop on the respective links for the totally free versions of their products.
OneWorld
Post by Marbury »
I was about to come back to you and say that I had missed the free link. There is just so much clag to read through before you find what you want.
Now I have installed it and attempted to clone, I am getting another brick wall. I am cloning the Windows 10 C drive (500GB) onto a WD 1TB formatted drive but I am getting the error "the target disk has an incompatible sector size for this operation, please choose a different disk" I can't get past this.
Marbury
