Sonosax/SSL
Sonosax/SSL
Just flicking through the Pink Noise catalogue, genuine question here, as you know, I’ve been looking for the ultimate small mixer for a long time, and not coming to any conclusions.
I’m interested in the difference in pice between the small Sonosax and the SSL Six, it’s about seven grand.
All I’m asking, is... what exactly is so different and beneficial about the Sonosax over the SSL that warrants the extra asking price.p, is the circuitry that much better?
The application? Local organ recordings by myself, my own piano recordings, that’s about it, in the current climate.
Re: Sonosax/SSL
Gear is designed and built in Switzerland to the highest possible standards in all respects. That's why it costs what it does.
Its much the same difference as between a Nagra IV and a Zoom F8...
They both get the job done, but one has a lot more more style, is nice to use, and sounds a bit more special
Sonosax makes beautiful equipment, built to last, but it's almost impossible to justify unless your living depends on it and you can send out big invoices on a regular basis!
Posts: 43708 Joined: Fri Jul 25, 2003 12:00 am
Re: Sonosax/SSL
Hugh Robjohns wrote:The sonosax is designed and built in Switzerland to the highest possible standards.
Sonosax makes beautiful equipment, built to last, but almost impossible to justify unless your living depends on it and you can send out big invoices!
Point taken Hugh, just wondered what it sounds like!
Re: Sonosax/SSL
Georgeous...
Re: Sonosax/SSL
Hugh Robjohns wrote:Georgeous...
I’m taking that as ultimately transparent? Could be a great mixer for our piano and marimba, along with the MKH's plugged in.
PS...
https://www.pinknoise-systems.co.uk/sonosax-sx-es64-6-channel-mixer.html
Re: Sonosax/SSL
Yes, absolutely. Just what you need. You should definitely buy one.
Last edited by Hugh Robjohns on Wed Oct 28, 2020 10:13 pm, edited 1 time in total.
Re: Sonosax/SSL
Hugh Robjohns wrote:Yes, absolutely. Just what you need. You should definitely buy one.
Trouble is right now, who’s going to play the Marimba?
Re: Sonosax/SSL
Sonosax is the very best of the very best - it has no equal.
There are no compromises - just the very best and priced that way because that's what it costs to make the best.
- John Willett
Longtime Poster -
Re: Sonosax/SSL
John Willett wrote:Sonosax is the very best of the very best - it has no equal.
Hi John! Yes, it would be great to have one, for our duo, but my Marimba man and my partner are both too scared to have sessions anymore, the way COVID is affecting music for me is becoming very disturbing, as it is for a lot of us.
I’d have an £8,000 mixer great, but it would be sitting there unused.
Re: Sonosax/SSL
I must admit, this looks absolutely spiffing, 8 busses, 4 sends, and very flexible routing, take a look at the spec and features, incredible.
https://www.sonosax.ch/product/sx-st/
https://www.youtube.com/watch?v=jPGyNnzhVao
Re: Sonosax/SSL
It really is absolutely spiffing... And so it should be for the money!
I fear you haven't looked at the prices yet...
The basic eight-module frame (there is nothing smaller) and PSU is £7,000
You then need to populate it with input modules (the master and monitor modules come with the frame)
A stereo line input module will set you back £1,300 while a mono mic/line channel is £1,200.
So building an eight module desk will set you back between £16,600 and £17,400.
That leaves one module space which can be covered with a blanking plate (£40) but is typically used for an integrated eight-track digital recorder module (records onto memory cards) which will set you back another £5,200...
You certainly do get a lot of analogue loveliness and functionality in a small space... but for that money the alternative options are very wide!
Last edited by Hugh Robjohns on Tue Nov 10, 2020 11:09 am, edited 4 times in total.
Re: Sonosax/SSL
Re: Sonosax/SSL
Hugh Robjohns wrote:Swiss built...
Crazy, not really an option, I’d have major trouble explaining that delivery, and the disappearance of my car in the garage.
Re: Sonosax/SSL
Not to mention the scar where your left kidney was...
But it really is a very lovely thing.... and for the kind of money Stuart (deservedly) gets from his big films, perfectly justifiable. But not for mere mortals recording a half broken piano in a living room...
Re: Sonosax/SSL
Hugh Robjohns wrote:But not for mere mortals recording a half broken piano in a living room...
Hugh, since when has that been an issue? Sometimes in life you just have to go for it, think of it like this, buying the Sonosax might galvanise me into getting the piano repaired, sort of the cart before the horse approach.
Anyway, the piano was all right for that BBC recording, but the Beeb did get a call the next day from someone called Mr Angry from the Home Counties complaining that the piano was half broken, and the mixer used was obviously not up to scratch, and how could they have possibly broadcast such a travesty?
Don’t worry, my wallet remains closed, my god, I could get an original ARP2600 for that sort of money.
Re: Sonosax/SSL
Re: Sonosax/SSL
There's a simple checklist before purchasing:
- are the faucets in your bathroom plated in gold? No buy
- are the faucets in your bathroom *made* of gold? Maybe buy
- do you have more than one bathroom? Buy
Alternatively, your name starting with Sheik and ending with <bin something> helps.
Re: Sonosax/SSL
CS70 wrote:There's a simple checklist before purchasing:
Well, there you go, we actually have "three" bathrooms, so that’s that decided then.
I’ll have to look elsewhere, for something of a slightly better quality, I feel another thread coming on..."what’s the best mixer over fifty grand? suitable for use in a damp basement with dodgy electrics and half broken piano?"
Re: Sonosax/SSL
Arpangel wrote:Well, there you go, we actually have "three" bathrooms
All with faucets made of gold?
Then zero problems
Meanwhile, I'm gonna look for these Arab relatives from the times of the first crusade....
