Garageband & OS Mojave ???
Post by DigitalMusicProduction »
Hi
Is it possible to install garageband 10.3.5 on a Macbook Pro mid 2012 using mojave?
Posts: 241 Joined: Thu Oct 22, 2020 7:00 pm
Re: Garageband & OS Mojave ???
Post by muzines »
As long as your hardware supports Mojave (it does), and GB's min requirements are at least Mojave (yes, min requirements are still High Sierra for GB 10.3.5) then I can't see there are any problems.
Why, do you suspect there might be a problem? Have you tried and something isn't working?
muzines
desmond wrote:Why, do you suspect there might be a problem? Have you tried and something isn't working?
I've spent the past few days amalgamating all the tech spec compatibility's for a MacBook pro mid 2012 i intend to purchase, hence the reason for posting, but if what you say is accurate, all should be fine, thanks Desmond.
FWIW I have GB 10.3.2 on my mid 2012 MBP. I don't use t as I prefer Reaper but on the odd occasion I have run it it has behaved as expected.
Posts: 22920 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
