Hello all I am learning about setting up busses but was wondering if you bus into busses !
So for example say I have a main vocal bus and a harmonies bus - would the harmonies bus go into the vocal bus (and not the master) or would you leave that separate? What about vocal delays and reverbs - would all the busses go into those channels and not the master or would you send to the verb/ delay channels AND master
Similarly I have set up a drums bus and drums verb bus, do those also run concurrently as well so both the drums buss and drums verb buss going separately to the master?
Busses are really just a means to organise lots of tracks. Historically there might have been a bit of convention because big console mixers would only have a specific number of bus channels... often 4 or 8. So you would have drums, guitars vocals etc. But in the software world there is no practical limit, so just do whatever best helps you keep things organised.
