Clip tuner that responds acoustically
Post by EleveDrole »
Hey there
I'm looking for a guitar (clip)tuner that's not just showing me visually how detuned my guitar ist but also acoustically (like these old big Boss tuners some players still use in the studio).
Any suggestions?
Would be happy to read some answers!
FB
EleveDrole
Posts: 2 Joined: Sat Nov 28, 2020 3:31 pm
Re: Clip tuner that responds acoustically
Welcome to the forum :thumbup:
I'm not sure what you mean? A link to a pic or old review of the 'big old Boss tuners' might help but what do you mean by 'acoustically'?
Post by Kwackman »
Kwackman
Posts: 3686 Joined: Thu Nov 07, 2002 12:00 am Location: Belfast
Post by shufflebeat »
If you mean that it actually generates an audible tone then I'd look to phone apps. The tech to make the tone is simple and the hardware is probably already in your pocket.
shufflebeat
Like these ones:
https://youtu.be/e773JS4OS8g?t=213
shufflebeat wrote:If you mean that it actually generates an audible tone then I'd look to phone apps. The tech to make the tone is simple and the hardware is probably already in your pocket.
I know. However I want exactly that in a clip tuner :/
EleveDrole
Post by Kwackman »
shufflebeat wrote:If you mean that it actually generates an audible tone then I'd look to phone apps. .
..and ignore my suggestion above as it doesn't make any noise!
Kwackman
Post by muzines »
That’s what I use and it’s awesome, love it!
muzines
My main tuner is my ancient Boss TU-12 which I've owned since 1984. It doesn't have any option to generate a reference tone for tuning. Neither does the TU-12H in the photo you posted.
Do you mean you are looking for a tuner with a built in microphone for acoustic instruments?
Posts: 13295 Joined: Thu Dec 05, 2002 12:00 am Location: Devon
My recommendation for a clip on tuner is the Snark ones, especially as the model 2 can handle double-bass and mandolin.
Yes, I have loads of different tuners. The best IMHO are the Peterson Strobe tuners but in terms of VFM the Snark's take a lot of beating.
I'm not aware of any clip on tuner that produces an audible tone*, but as Zenguitar says neither does the one you linked to. Why do you want this or is it a different feature of the Boss TU12 that you are looking for?
* TBH I have had loads of different electronic tuners over the years and none that I can remember have an audible pitch.
Ah, I suspect BigZ might have identified the desired feature.
Right now none comes to mind.
shufflebeat
Sam Spoons wrote: * TBH I have had loads of different electronic tuners over the years and none that I can remember have an audible pitch.
Some of the Korg ones do. I also have an old Korg tuner that will generate a tone through the output jack.
Posts: 16988 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Another plus for the snark, it has a built in mic as well as the vibration feature. It works ok for the most part as well.
To the OP
In the past when I've had to check the numbers on an accordion I clipped a guitar tuner to an appropriate resonator (piece of cardboard, CD case is good) which worked quite well.
For the record, tuning an accordion should only be attempted by a qualified veterinarian.
shufflebeat
blinddrew wrote:Another plus for the snark, it has a built in mic as well as the vibration feature. It works ok for the most part as well.
Problem solved.
shufflebeat
Post by SecretSam »
shufflebeat wrote:To the OP
How can you tell?
SecretSam
Posts: 3030 Joined: Tue Oct 29, 2002 12:00 am Location: Officially, I do not exist.
Instant gratification is actually pretty good. It's fast as well.
Post by adrian_k »
How can you tell?
You check it against some bagpipes, or a banjo.
adrian_k
Posts: 3813 Joined: Thu Jan 30, 2003 12:00 am Location: Gloucestershire
Life is wealth. (John Ruskin)
Post by SecretSam »
:bouncy:
SecretSam
How can you tell?
Or a Bb duck.
shufflebeat
Post by DC-Choppah »
DC-Choppah
Posts: 2054 Joined: Fri Jul 20, 2012 12:00 am Location: MD, USA
