Is there a factory reset option for the D50? I couldn't find it.
Yes it works perfectly other than that.
Vendor said it recently had a battery and it clearly worked before he shipped it, I'll try a new battery anyway as it's easy. I don't really want to have to return it... I love a D50
I actually had several patches in a commercial sound bank on my trusty Korg M1 that had been created using a 'randomiser' utility that put totally random numbers into all the parameters.
This resulted in both corrupted titles (like those you've currently got on your D50) and weird sound effects.
As others have said, resetting after installing a fresh battery should resolve your problem.
Martin Walker wrote:I actually had several patches in a commercial sound bank on my trusty Korg M1 that had been created using a 'randomiser' utility that put totally random numbers into all the parameters. This resulted in both corrupted titles (like those you've currently got on your D50) and weird sound effects.
I never owned a D50, but I did own a D10 and I have a feeling that the battery isn't the problem here. The corruption on the screen in the photos strays well beyond the data fields maintained by dynamic battery-backed memory.
If there is a chip/data fault it would be an issue with the ROM holding the hard-coded strings that form the labels for various voice parameters. As to which ROM that is or how to fix it I cannot say. The fact it works OK other than the display is probably a good sign but I'd be inclined to reach out to Roland and ask them for some input on which chip(s) to consider suspect.
They probably don't sell them any more but you might be able to find a dead or damaged D50 cheap on an auction site from which to salvage one or more replacement chips.
Before doing any of that, I'd be inclined to open up the case and see if there are any dry joints or cracks in the connections associated with the ribbon cable going to the LCD. It could be that the corruption isn't ROM based at all, but one or more bad connections are corrupting a bit or two of data being fed to the LCD, which would also explain the issue shown in the photos and would be a relatively easy fix (just renew the solder joints and/or add a fly-lead to cross a broken PCB track) if that was the case.
If you power on while holding INCREMENT and the 0 SPACE button it should report ROM version and battery level, which may be a way to check the display circuit.
desmond wrote:Anyone else on the edge of their seat over the drama of whether this lovely but poorly D50 is resurrected or not?
I'm not unduly concerned, as long as the sounds themselves emerge faithfully - sometimes having a few corrupted characters in the graphic display can add a level of intrigue to the proceedings
Well I have sorted the screen, it was a connection to the main board, took them all off and cleaned up the connections. All lovely now. D50 making lush sounds and looking great all over again. Thanks for all the help guys.
nwns wrote:Well I have sorted the screen, it was a connection to the main board, took them all off and cleaned up the connections. All lovely now. D50 making lush sounds and looking great all over again. Thanks for all the help guys.
