Basically: I've moved house, and have all my stuff set up in a new room.
I *think* the electrics are fine (famous last words...
the letting agent had an electrical safety test done on the property before it was lit,
I tried a trusty Martindale socket tester on every socket,
and all my music stuff is plugged into the wall in the same arrangement I've used for the past decade or more, namely:
I used two wall sockets. Everything with a three-core (i.e. earthed) mains lead is starred back through some multiway-adaptors to one wall socket. And everything with a two-core lead (double-insulated) is connected back to the other.
I've also totted up all the power consumptions on a spreadsheet, and on paper they're comfortable within the 13A capacity.
And I tested it with a little in-line 'smart meter' thru-plug from my electricity supplier, which gives a live current readout (amongst other things), and I've never seen a current draw above 3A on either socket. And I always switch on at the wall first then bits of gear individually, to avoid surge inrush.
HOWEVER.
I keep getting static electric shocks when I touch various bits of gear (my Akai MPC4000! My SCI Six-trak. Even my digital Mellotron M4000D). The first two of those are earthed appliances, the last one isn't.
It doesn't feel like 240V live on the chassis (or I'd be long dead, I think), it just feels like those static shocks one sometimes gets in certain buildings when you touch a metal door handle.
Tell tale clue: there is a new springy synthetic carpet on the floor. And I only seem to get the shocks when scooting about in trainers, not if I walk about barefoot or in socks.
ANYWAYS -
the worst thing about it is that I also though my Mellotron M4000D had developed a fault. It kept spontaneously rebooting and making a nasty click in its output.
Initially this seemed to be when I waggled it's wallwart, and I though it was a dodgy wallwart. Although it seemed to be more mechanical movement of the 2.1 dc barrel connector in the machine's socket that did it, when I touched it with my fingers...
...but then the next day, it barefeet, I couldn't reproduce this reboot behaviour at all! The wallwart inlet seemed completely sound.
So: my question is: am I giving my mellotron static shocks? I mean, would that make the electronics blip and reboot? (the M4000D is basically a hardware ROMpler). Does that sound plausible?
Am worried I might just fry some ICs inside it... or particularly on older synths (like the Sixtrak, which has 35 years old Zilog Z80 CPU inside).
Is there something homebrew I could do to guard against ESD on my keyboard rigs? (Like those little wrist straps you used to be able to get in Maplin, and can doubtless now get on Amazon)... or should I call an electrician before I die?
(I found it counter intuitive that an earth chassis of an MPC4000 or SixTrak could give me a static shock... but then I thought it did make sense, cos I'd built up a charge on my body, and it was precisely because those chassis we earthed that it was discharging painfully through my fingers and through the chassis when I touched them?)
