Zoom H6 intermittent power on issues
Post by Rod1813 »
Hi to all H6 users.
I'm a newbie to this forum but have had about 15 years of home recording experience.
I have a Zoom H6 recorder that I love but has developed an intermittent fault when powering on. Most times it does absolutely nothing but after a few consecutive attempts it produces a constant white screen which I can ony remove by disconnecting the power. (Either batteries or USB power). After a few more of these antics it boots normally and provided I don't interrupt the power supply it will record all day long without issues.
I have checked all the connectors, the on/off switch, battery compartment and visually inspected the internal boards but there is no sign of any corrosion or battery leakage at all.
Anybody have any ideas or suggections how to rectify this?
I live in South Africa and we have a Zoom "agency" here but am unsure of whether it could be repaired here. :(
Please help if you can.
Thanks
Rod
Rod1813
Posts: 11 Joined: Sun Dec 27, 2020 8:10 am
Re: Zoom H6 intermittent power on issues
Is there a 'factory reset' option?
Posts: 29633 Joined: Sun Jul 05, 2015 12:00 am Location: York
Post by Rod1813 »
Thanks for the response.
There is, in fact, a Factory default/reset setting but I'm not sure if that will achieve any improvement in the power switch-on scenario. I don't want to lose my pesonal preferences which I fear might happen but am not sure at all.
I'll try that option if you think it will work :<)
Rod1813
Have you tried a different memory card?
I'm just wondering if it's hanging during boot up because the card is not responding correctly?
Posts: 43601 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Post by Rod1813 »
Thanks Hugh
Yes I have changed the SD card and the result is exactly the same - totally blank screen for first 5 or 6 attempts then white screen for a few more tries then suddenly it works perfectly. Very annoying so any help or suggestions would be appreciated.
Rod1813
Given that you've tried different power sources and different memory cards, there's not much else you can do.
A factory reset would be worth trying -- but you will probably lose any personalised tweaks -- and I'd normally suggest a firmware update... but if there is something dodgy going on inside it could kill it completely...
So I'd say the next option is a registered zoom repairer.
Post by Rod1813 »
Thanks for your assistance guys. I will try a factory reset and see if there is any improvement (or otherwise!) but if that doesn't work then you might be right in suggesting a Zoom repair. Given the vague nature of this specific fault, I don't know if such a repair would be economically viable. There are NO similar faults reported anywhere that I can find on the Internet so mine might well be the first.
Thanks again.
Rod1813
Post by Rod1813 »
Following up on Hugh's comment about "booting" the H6, I realised that it is a small computer style device that it, in fact, does "boot" up before running properly. On impulse I opened it up again and there is a rechargeable 3V button cell on the motherboard which appeared to be supplying about 2V DC unloaded. I don't know if this is not holding sufficient current to support the boot process but don't want to tamper with it right now.
(I did a factory reset but it didn't improve anything)
Any further comments?
Rod1813
Post by wireman »
Does it 'work'?
By that I mean will it record or playback or act as a USB host if it can do such a thing if you activate the relevant controls (I know the screen does not seem to be working).
wireman
Posts: 804 Joined: Fri Dec 17, 2004 12:00 am
Post by Rod1813 »
Hi Wireman
Yes it works perfectly but it's a bit of a rigmarole getting it to boot. Once it has booted and running it performs flawlessly.
Rod1813
Post by Rob Kirkwood »
Rod1813 wrote:On impulse I opened it up again and there is a rechargeable 3V button cell on the motherboard which appeared to be supplying about 2V DC unloaded.
If it is a rechargeable on the motherboard, might be worth plugging the H6 into a USB power supply & just leaving it connected for a day or so?
Rob
Rob Kirkwood
Posts: 138 Joined: Tue Jan 07, 2003 12:00 am Location: Nottingham, UK
Post by wireman »
Rod1813 wrote:Hi Wireman
What I was trying to understand was if you only see a white screen on the 'bad' boots and nothing else. I was wondering if it is possible that the screen has a dodgy connection but otherwise it works. So I'm really asking if it works with the white screen showing.
wireman
Post by Rod1813 »
Yes I was thinking of doing that to test whether the rechargeable cell would then recover a bit and behave normally. If that happens then I'm a little further along the road to understanding this strange problem.
Rod1813
Post by Rod1813 »
Hi Wireman
It doesn't work at all when it displays a white screen as it freezes there and won't complete the boot cycle into the "H6 Handy Recorder" splash screen etc.
I don't think it has a dodgy screen or screen connector as when it boots successfully the screen functions 100%. I also checked the flat multi cables & connectors a few times when I dismantled it and reassembled it.
Rod1813
Post by wireman »
Thanks for confirming.
I suspect that the onboard lithium cell will be there to maintain settings in memory.
wireman
Is the button cell in a holder or soldered to the mainboard? if the former then it's easy, and cheap, to change it. Even rechargeable cells die eventually. But, does the H6 boot reliably when it is plugged into it's mains adapter?
Posts: 22820 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Post by Rod1813 »
Hi Sam
The cell is soldered to the board and no, the unit does exactly the same thing irrespective of its power source (batteries or mains).
What I was thinking is this - if that cell is used to assist with the boot process (very much like the CMOS on a PC) and it's in the process of dying then the boot instructions are either missing or confused and the machine freezes without completing the boot process. After a short period of trying there is now sufficient power in the cell to complete the tasks and boots fine. Once the machine is switched off, the residual power in the cell drains and we're back to zero again.
Does this make sense?
Rod1813
Post by wireman »
Rod1813 wrote:Hi Sam
I think this is very unlikely.
If there was enough voltage to charge the battery that same source would be powering the other components.
wireman
Can you take a photo of the battery and post it somewhere so that we can see what type it is?
Posts: 16912 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Post by Rod1813 »
I took 2 photos of the underside of the motherboard when the unit was in pieces but they are not very clear. The button cell is visible but I cannot read the letters on the cell to identify specifically which 3 volt rechargeable cell it is.
I also don't know how to post photos in these posts.
Sorry
Rod1813
WRT posting images the forum does not host them so you'll need to host them on another site, I use Imgur and link to them, the direct link pasted into the "Img" tags will display the image in the post.
Post by Mike Stranks »
Short video on how to post images here:
https://www.youtube.com/watch?v=s7vVDGTOHW0
Post by Rod1813 »
Thanks a lot Mike for the tutorial on uploading images. It was a breeze!
This is one of the photos I took of the motherboard where the button cell is located. The other pic does not show the cell as clear as this one so didn't bother uploading it.
Please shout if anyone needs anything else from me. I've plugged the H6 into the ac/dc adapter and will leave it there for the next 8 hours or so and see if that improves the situation. I will report back with any data that I find.
Thanks again for all the interest on this forum.
Rod1813
Post by Shooroopski »
Hey, I had same issue. Managed to fix it by cleaning all flex cables and connector with spray antiseptic and cotton buds. It had some kind of grayish fungus or something on it. Now device boots and works fine. :thumbup:
Shooroopski
Posts: 1 Joined: Tue May 18, 2021 10:31 pm
Post by gjerome22@mail.com »
I am having the HN6 power issue. It boots and works fine on batteries. It will not boot past the white screen using plug in power of any kind. I have tried everything mentioned except opening the unit and checking internal components. I have update the software to verion 2.5 a couple weeks ago, before the issue. Does anyone have answer that has come up and not been posted?
gjerome22@mail.com
Posts: 1 Joined: Thu Oct 26, 2023 9:52 pm
