MixAndMatch wrote:Tjbenz wrote:Curious what Key you guys use when using auto tune for vocals. I know the "classic T Pain" style is a C Major but I have been using D-Major on my vocals and it seems to sound better. Curious what you guys are using. Attached is my vocals with D-Major for reference.
https://youtu.be/LQLKdus7woA
Yes, C major is the sweet spot.
It has to do with ear anatomy but also frequencies and how they resonate within the ear. This is why some keys sound 'better'. It is because the inner ear drum is resonating at a more comfortable frequency. The further you go from C maj the more the resonation so this could explain the effect on/in the listener. This is why very few pieces (if indeed any) in the classical period were written in B major (although at the time no one would have been aware of the fact even though they may have been witnessing some light ear discomfort). C major is the 'purest' of all keys and resonates at just 262 hz (which matches certain bodily biorhythms) so it seems reasonable that vocals put into this key are going to be more easily absorbed in the ear canal because those resonances are cancelling each other out.
This is in fact how some noise cancelling hearing aids work. It is also the same principle as the need for troops to break marching pattern when going over certain bridges in big cities (London or NY for example). It makes sense then, to tune a vocal to the most sonically amenable key. There may also be psychoacoustical factors at work here too. It's certainly an interesting area and there's a few articles available online.
I don’t believe this is even slightly true. Plus it’s pointless tuning vocals to C major if the tune is in E major, say.
