Hardware compressors around £400
Re: Hardware compressors around £400
Alternative (and apparently not as popular) opinion
Benefits of compressing on the way in:
- Getting a 'sound' you like - usually by driving the compressor - yes you can do that afterwards, and that's fine, but committing to something on the way in, does sometimes effect the way you work in a positive way by avoiding the 'so many many plugin in options not sure which to chose and takes loads of time to do it' creative blocker
- As others have said - you need to know what you're doing, but you ain't gonna know what you're doing unless you practice - so benefit 2 is it helps you learn how to compress on the way in!
- Controlling singers with piss poor mic technique and big transients - yes its better for them to learn good mic technique but I'm not giving them a lesson in that if they're in full flow and I just need to capture it.
- Bonus benefit HW compressors are more fun to use, generally sound a bit better (!!! opinion !!) and are more intuitive to use.
I'd echo Elf - The KT-76 or the KT-2A are good start, or if you have 500 series id build a JLM audio LA500 - really intuitive, forgiving great sounding opto compressor
jaminem wrote: - Controlling singers with piss poor mic technique and big transients - yes its better for them to learn good mic technique but I'm not giving them a lesson in that if they're in full flow and I just need to capture it.
Agree on the rest but if you can't control singers without a compressor when recording at 24 bits, it's not only their technique that's piss poor!
jaminem wrote:Alternative (and apparently not as popular) opinion
I'd agree with all of these.
Whereas in the days of analogue tape it was pretty much essential to compress wide dynamic range sources for technical reasons before recording them, we no longer need to do that simply because digital recording systems have such a wide dynamic range capability.
And for the inexperienced it is generally 'safer' to record flat without compression, and then mess about with unadulterated signals in the DAW where you have an undo option. So I would generally advocate recording flat where the knowledge and experience is limited.
But there are definitely situations where compressing the source on the way in is an important or even an essential part of achieving both the required sound character and -- more importantly -- the required performance.
And yes, committing to 'a sound' at the time of recording can also help to move things along during the session and save time in post-production. The issue here is that making the right decision when recording obviously requires experience, so there's a bit of a chicken and egg situation.
You need to practice to gain experience... so the obvious safety net would be to split the mic preamp output so that you can record both the straight sound for 'get out of jail' purposes, alongside the hardware compressed version as you develop your recording chops...
As always with these things, there are no absolute rules. it's all shades of grey that depend on the situation, the experience, and the requirements...
Posts: 43621 Joined: Fri Jul 25, 2003 12:00 am
I agree there's no need to do it as such, but I still do.
At the studio we have a nice collection of hardware - real vintage 1176s and LA-3As as well as more modern Avalons and DBXs. Frankly, unless I use them on the way in, I wouldn't use them at all, because there's no guarantee that I'll actually be doing the mixing at the studio. Also, I rarely complete a project/mix in one sitting so recall becomes an issue. Sometimes if I have the luxury of time I'll print some tracks through, but I rarely bother to be honest.
It's a similar conundrum with the AMS RMX16 reverb we have. I love its sound, but it's very rare that I actually mix through it and render the tracks in real time!
I know what they do, they are fun to use, and I've reached a stage where I trust myself to not overdo it, so yes, I like to tickle the hardware on the way in!
- Aled Hughes
Posts: 2126 Joined: Tue Oct 24, 2006 12:00 am
CS70 wrote:jaminem wrote: - Controlling singers with piss poor mic technique and big transients - yes its better for them to learn good mic technique but I'm not giving them a lesson in that if they're in full flow and I just need to capture it.
Easy tiger...
...more of a safety net really, and most importantly avoiding the 'mic technique lesson' when they are firing because that's more important than anything - just one less thing to worry about...
jaminem wrote: Easy tiger...
Apparently the one loudest female singer in the world can do 121dB so I stand corrected - you need a compressor if you have a piece of music with her starting with a whisper and ending with her loudest note!
Ramirez wrote: It's a similar conundrum with the AMS RMX16 reverb we have. I love its sound, but it's very rare that I actually mix through it and render the tracks in real time!
Though in that case you have the option to sample an impulse and then use that impulse in a convolution reverb. I had exactly the same issue last year when the client loved the reverb he was hearing in the headphones from an H3000 and wanted it for the mix. I wasn't confident enough to sample the H3000 right in the middle of a mixing session but it is something I ought to do for the future.
It isn't so easy to sample compressors - although not impossible for a real DSP expert.
Posts: 16923 Joined: Mon Sep 10, 2001 12:00 am
James Perrett wrote:Ramirez wrote: It's a similar conundrum with the AMS RMX16 reverb we have. I love its sound, but it's very rare that I actually mix through it and render the tracks in real time!
Now that's a neat idea.
We also have a H3000 here, and a Lexicon PCM91, but I haven't really paid much attention to them. There's an EMT140 in bits in the workshop too...
- Aled Hughes
Ramirez wrote:We also have a H3000 here, and a Lexicon PCM91, but I haven't really paid much attention to them. There's an EMT140 in bits in the workshop too...
You could go to the effort to make impulse responses of some of the settings of those items, and it can be fun and a learning experience, but others have probably already done it (google for impulse responses) - and of course you can get plugins which reproduce those things in detail with *all* the settings, so if you like the sounds those things make, grabbing the plugins would probably get you 95+% of the way there a lot quicker...
desmond wrote:Ramirez wrote:We also have a H3000 here, and a Lexicon PCM91, but I haven't really paid much attention to them. There's an EMT140 in bits in the workshop too...
True. To be honest I don't feel I'm missing too much when I load the Eventide 2016 or Arturia plate plugins instead of using the hardware reverbs.
I do want to get the plate up and running though (though there might be an issue with asbestos in the case...).
- Aled Hughes
I found a great resource a few years back - someone who had made IRs of the Lexicon 480L .. I've used them quite a bit over the years and they sound good, even if lately I use more the Lexicon native.
Let me see.. yes it seems still around, here: https://www.housecallfm.com/download-gn ... xicon-480l
CS70 wrote:Apparently the one loudest female singer in the world can do 121dB so I stand corrected - you need a compressor if you have a piece of music with her starting with a whisper and ending with her loudest note!
Not really. She can reach 121dB SPL at the loudest, but what's a whisper? 40dB SPL? The noise floor in my room is around 30dB SPL during the day, and a whisper must be louder than that or it wouldn't be inaudible...
So you're talking about a recorded dynamic range from whisper to ouch of around 80dB, maybe 90dB if we're feeling generous...
You could capture that perfectly well on a 16bit DAT machine if you set your levels carefully, and it wouldn't be even slightly difficult on a 24 bit format. So still no absolute need to use a compressor for the recording.
CS70 wrote:I found a great resource a few years back - someone who had made IRs of the Lexicon 480L .. I've used them quite a bit over the years and they sound good, even if lately I use more the Lexicon native.
Let me see.. yes it seems still around, here: https://bedroomproducersblog.com/2014/0 ... responses/
That's cool, thanks!
Would anyone be interested if I did some IRs of a few of the RMX16's presets?
- Aled Hughes
Hugh Robjohns wrote:CS70 wrote:Apparently the one loudest female singer in the world can do 121dB so I stand corrected - you need a compressor if you have a piece of music with her starting with a whisper and ending with her loudest note!
Yes
And on a side note: 121dB!! Probably short bursts, but holy cow!
Ramirez wrote:Would anyone be interested if I did some IRs of a few of the RMX16's presets?
Sure, go for it!
For a few dollars, this one looks pretty good:
https://inhalt.bigcartel.com/product/townhouse-rmx-ams-rmx-16-impulse-responses
CS70 wrote:And on a side note: 121dB!! Probably short bursts, but holy cow!
I imagine that was measured within a metre... but yes, professional singers can certainly belt it out!
I think there's generally someone like this at most gigs...
Posts: 29633 Joined: Sun Jul 05, 2015 12:00 am
blinddrew wrote:CS70 wrote:And on a side note: 121dB!! Probably short bursts, but holy cow!
Remember that not all of us have your screaming fans...
CS70 wrote:blinddrew wrote:CS70 wrote:And on a side note: 121dB!! Probably short bursts, but holy cow!
I think you know that's not what I meant!
Have you considered the Aphex Easy Rider?
Not too many knobs to mess with, but it really makes some material pop, which I guess is what you're usually trying to avoid if you're using a compressor. That being said, you get four compressors that sound great for not a lot of money.
Best of luck!
Best of luck!
- twotoedsloth
Frequent Poster - Posts: 1135 Joined: Sat Jan 26, 2008 12:00 am
Hugh Robjohns wrote:CS70 wrote:And on a side note: 121dB!! Probably short bursts, but holy cow!
My partner was a trained opera singer, but now a shadow of her former self owing to health issues, I’ve tried to record her many times, it’s OK, but not great in a smallish living room, even with her voice as it is now, I find I have to use compression, or ride the faders, and a score is essential to anticipate the loud bits.
I can’t get her far enough away from the mic's, like you can in a large hall, where it evens out the levels a bit, and yes, 16 bit is fine, I’ve been on opera sessions where we used DAT, and provided it’s a decent sized hall or rehearsal room there were never any issues, and we never used compression.
