diy electret microphone, which phantom power adapter?
Post by pingalep »
i am planning to try build myself some microphones using electret capsules.
what is the best way sound and noise wise to power them with with phantom power? planning on using my mixpre 6 so i want to buy or build 4 adapters if needed, like the ones needed to power the mics for instruments.
any suggestion will be welcome for this kind of microphones:
1_ambisonic 4 cardioid mics setup
2_MS 3 cardioid mics setup/4 cardioid mics for bluemline setup
3_decca three 3 omni mics
4_contact microphone
5_lav with really small capsule
i was thinking to buy primo capsules, are there any better capsules for the price? i need them to be shipped in italy.
thank you for your attention!
pingalep
Posts: 8 Joined: Tue Jan 12, 2021 2:12 pm
Re: diy electret microphone, which phantom power adapter?
If I were doing this I'd look at some of the designs for phantom powering PZM mics. I seem to remember Chris Hicks and Rick Chinn had some designs on the web. Paul White also did an article in Home and Studio Recording which is probably available on the Muzines website.
Posts: 16989 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Post by Tomás Mulcahy »
Tomás Mulcahy
Post by shufflebeat »
This may or may not be of interest:
https://www.amazon.co.uk/VXLR-Minijack- ... DKBJ&psc=1
Rode adaptor.
shufflebeat
Here's a link to Rick Chinn's page which includes links to both circuits I mentioned.
http://www.uneeda-audio.com/pzm/
However, if you don't want to DIY then the Rode adaptor that Shufflebeat linked to should work fine.
Post by pingalep »
thank you all for the precious hints and help!
aside from building quality(i see some issues on amazon reviews), the electronic of the rode adapter quality wise is high enough to be matched with primo capsules 14dB selfnoise and my mixpre good quality preamp? or the sennheiser, akg or lom cables adapters are better?
pingalep
If you are worried about the adaptors changing the sound you could always avoid them by powering your capsules from a battery and connecting them directly to the mic inputs of your Mixpre.
Post by pk.roberts »
You might find it useful to have a look at the last page of this document;
https://www.microphone-data.com/media/f ... ics-10.pdf
Good luck with the project.
pk.roberts
Posts: 115 Joined: Fri May 09, 2008 12:00 am
Ain't No Party Like an S Club Party
