Buzzing fret
Buzzing fret
Post by awjoe »
So, imagine a buzzing fret on an acoustic guitar. I'm thinking there are two fixes to explore: a higher bridge, I mean just to see. Refretting. I don't want to begin to go there.
awjoe
Posts: 5579 Joined: Tue Mar 08, 2011 12:00 am
I bow down before your superior biscuitular capacity.
Re: Buzzing fret
Post by Murray B »
Just the one fret?
On all the strings?
Which fret?
Sometimes a tiny adjustment in the neck relief or a little hammering on the fret one higher can fix this kind of stuff. But there are many variables and the guitar makers and menders here will need a bit more detail I think if you want useful advice.
If you can get the guitar to a skilled repairer they should probably be able to sort this, a re fret is quite drastic and most guitars have enough meat in the frets to stand them being levelled and re profiled. If you like the guitar it's a worthwhile exercise, all my guitars that have been professionally set up come back playing at their absolute best - and it's a very positive experience and worth the money spent.
Please Note: I've made a number of cheaper guitars (I daren't mess with the posh ones) worse by not really knowing what I'm doing but it could be a simple fix. But I wouldn't wish to offer any direct repair advice in this regard.
Murray B
Posts: 467 Joined: Mon Nov 28, 2011 12:00 am Location: Staffordshire
Re: Buzzing fret
Post by John Egan »
awjoe wrote:So, imagine a buzzing fret on an acoustic guitar. I'm thinking there are two fixes to explore: a higher bridge, I mean just to see. Refretting. I don't want to begin to go there.
What condition are the frets in generally? Is this an old guitar or relatively new. I ask because if the frets are on their last legs, the remedy might need to be more drastic. If, on the other hand there is plenty of life left in them, then it should be possible to reseat/fettle it.
Regards, John
John Egan
Posts: 476 Joined: Wed Nov 27, 2002 12:00 am Location: Staffordshire, England
Re: Buzzing fret
Post by CS70 »
A higher bridge is seldom a solution, and refretting is way too drastic unless the frets are really gone. If it's just one or few frets on certain strings, it can be simply seasonal variation in the wood - make sure the guitar is plenty humidified (keep it in the case with a sponge humidifier for at least a week), and have it looked over by a luthier - dry wood contracts and frets may come up a little and need to be gently put back in place with a little tough love.
Re: Buzzing fret
All good advice so far. The only thing that needs to be added is that a decent luthier/tech has more options than just a refret to solve this problem.
Once all other options have been eliminated, if you still have one high fret for one or more strings it it perfectly possible to remove the high spots individually. If there are a lot of high spots, it is usually possible to dress the fret tops level and then re-profile rather than having a refret.
The important thing is that you need someone who knows what they're doing to look at it for you.
Re: Buzzing fret
Post by Luke W »
Some good advice so far. A higher bridge will only hide the issue and it'll make the action higher and then introduce the issues that brings in terms of playability etc. As already mentioned, an adjustment to the neck relief could do it, but in my experience if it really is just one fret that's playing up then the more likely solution would be either a bit of a tap down on a fret that's lifted a little as Murray suggests, or a fret level.
Murray B wrote:a re fret is quite drastic and most guitars have enough meat in the frets to stand them being levelled and re profiled.
Agreed :thumbup:
Edit - Beaten to it by Andy. Listen to Andy!
Luke W
Re: Buzzing fret
Post by awjoe »
Good advice, all - thank you. I like this guitar, so it's off to a luthier.
awjoe
Re: Buzzing fret
Post by Dynamic Mike »
Murray B wrote:Just the one fret?
On all the strings?
Which fret?
Are you 100% sure it's not just a resonance elsewhere on the guitar? Have you tried a different tuning to see if it moves? Sometimes just re-stringing is worth a try in case it's a duff winding.
Dynamic Mike
Posts: 5291 Joined: Sun Dec 31, 2006 12:00 am
Why do bad things mostly seem to happen to people who light up a room when they enter it?
Re: Buzzing fret
Post by JRC1 »
awjoe wrote:Good advice, all - thank you. I like this guitar, so it's off to a luthier.
good choice, dont mess with things you arent 100% confident doing and in my experience with acoustics its either going to be the neck needs an adjustment or the bridge has become worn and will have to be recut or a new one cut for the guitar and those are not easy jobs if you havent done a lot before.
JRC1
Posts: 31 Joined: Wed Dec 06, 2017 6:29 pm
Re: Buzzing fret
Post by awjoe »
On all the strings?
Which fret?
I heard this thing recently - the moment that nylon strings fall reliably into tune for a couple days on end is the moment you should start to think about changing strings. Good joke, but it says something. Long story short, I'll see what happens the next time I change strings, and I'm really curious about the tuning change idea as well. Aside from having fun in a new tuning, it provides information about how the strings act on that guitar.
No, it's not a resonance.
awjoe
Re: Buzzing fret
Post by awjoe »
No adjustments on a classical neck.
I'd be willing to swap out bridges, but I'm not going deeper than that. There are people who are paid good money to do that sort of thing. If they've done it before, they're better at it than I am.
awjoe
Re: Buzzing fret
Post by JRC1 »
Unfortunately for classical is that the only "adjustment" on a neck is a neck reset.
JRC1
Re: Buzzing fret
Not quite true. You can reset a neck by removing it and refitting it. But there is also the option of removing the back of the guitar, adjusting the neck/body angle, and then refitting the back.
OK, so you have to refit the binding and then refinish. But it shows there's more than one way to skin that cat. ;)
Re: Buzzing fret
Post by JRC1 »
zenguitar wrote:Not quite true. You can reset a neck by removing it and refitting it. But there is also the option of removing the back of the guitar, adjusting the neck/body angle, and then refitting the back.
ok got me there, but I was going with the leastish work.
JRC1
Re: Buzzing fret
For a classical guitar with a slipper heel it's the only option. And related to how the neck angle would have been set during construction.
And in terms of work required, it's no more than removing and refitting a glued neck joint. Just a different set of problems to solve. It's actually a very elegant solution as you have much finer control of the neck/body angle and you can avoid disturbing a well made neck joint.
Re: Buzzing fret
Post by awjoe »
Andy, I'll be going into my luthier's pretending I know something now. :headbang:
awjoe
Re: Buzzing fret
Good for you :thumbup:
It's the follow-up questions you have to worry about ;)
Re: Buzzing fret
Post by Wamdeler »
I had something similar not too long ago, apparently the neck angle and nut were issues. Nothing a good luthier can't fix!
Wamdeler
Posts: 4 Joined: Sat Feb 06, 2021 5:30 pm
