USB to MIDI detects on laptop but doesn't work Windows 10
Post by PianoGuy »
So I tried to connect my keyboard to my laptop via midi to USB cable, it detects in device manager, but for some reason, it doesn't detect it as a midi. It works perfectly fine on my PC, so I think it could be an issue with the USB port on my laptop or Windows 10 itself, but my computer only has one USB port with two USB-C ports couldn't test a different port. I tried all possible solutions, and nothing has worked so far. I have noticed that the wdma_usb.inf for the USB driver on my laptop doesn't install.
This is my laptop's USB properties:
This is my PC's USB properties:
I'm guessing there has to be something preventing the usbaudio from starting up and it has to do with wdma_usb.inf. I tried replacing the file and still had no luck so I hope you guys can help. There could be the possibility of it not working because of it's Window's version. My laptop has a latest version of Windows while my PC has a older version so this could be the issue as well.
PianoGuy
Posts: 2 Joined: Thu Feb 04, 2021 1:47 am
Re: USB to MIDI detects on laptop but doesn't work Windows 10
Post by CS70 »
What is the event viewer saying ?
Post by PianoGuy »
CS70 wrote:What is the event viewer saying ?
So the device starts on the laptop but doesn't install while on my computer it fully installs. I'm guessing something stops it from installing.
PianoGuy
